I have a CD copy (NOT a digital download) of Premiere Elements 10. After installing the program, I also installed the additional content (DVD menus, movie themes etc.). The first time I ran Premiere, this content was available to use, but on running the program for a second time, a message is displayed on startup stating that only a reduced set of content has been installed.
I've tried uninstalling and re-installing the content - same problem, its available on first use, but not subsequent use. I've even tried uninstalling and re-installing the entire program - again, same problem.
All the online help I can find with regards this problem relates to a download copy of the program, but that doesn't apply in my case.
Any suggestions as to how to resolve this?
Problem solved (I think!)
I noticed during yet another re-installation that while the program file was installed to C:\Program Files\, the content was installed to C:\Program Files (X86)\.
By changing the installtion path of the content to C:\Program Files\ (the same destination as the program file), the error has - so far - not come back.
Good news!
The x86 is for a 32-bit version of the program, and if you have installed, and are using the 64-bit version, but install the Additional Functional Content into a folder for the 32-bit version, PrE will not be able to find it. The Functional Content is the exact same, between the two versions, but the location Path will make a difference.
Personally, I think that Adobe needs to rework the installer routine for the Additional Functional Content, to survey the installation of the program, and if it is 64-bit, then install the Additional Functional Content where THAT program will look for the material. Otherwise, I think that the installer routine should pop-up a message, directing the user exactly where to install, based on their program version. This could be a simple warning, or even better, a drop-down menu, to select the location.
Unfortunately, installer routines are usually written by another department, than the one coding for the program, or maybe even an out-of-house service, so maybe the installer writers just do not know the differences. With a two OS version of the program, with different Paths, they SHOULD be informed, and provide an easy (for the user) way to get it right. Just MHO.
North America
Asia Pacific
