We are currently working on an architecutre project for which we have to make printed curtains/screens. The maximum of one Curtain
is about 180 meters (600ft). Over the 180 meters we have a pattern, which makes it not so easy to split files into pieces (color gradients, a.m.m.)
Our printing company suggested us to produce everything in a 1:10 scale (1 meter is 10 centimeters) and in 600dpi and they will scale it up with
their rip unit and print it than in 1:1. Final print resolution is therefore 60dpi.
As a start we are doing a 25 meters x 2,5 meters file - which is already super hard on the computer. (all new macs with 16gb ram and adobe creative cloud)
Is there any way of working like with videos - online and offline files? So that we work on a smaller scale and then repeat all the steps on the larger images.
We want to get our workflow optimized as we have to produce 3000 meters of image.
Any Ideas?
Georg Kettele
First thing that comes to mind is to ask: Do you really need that high a resolution? Are people really going to be looking at actual print detail from just a few meters away on a project that's nearly 200 meters wide? In other words, are you actually creating fine image detail that matters at the 60 ppi scale?
The second thing that occurs to me is that a typical computer with just 16GB of RAM doesn't seem a good fit for working on gargantuan images. You've avoided doing the math that matters for the readers here, so I'll do it:
Assuming your full length print will also be 2.5 meters:
So your proposed image at this scale will be 425195 x 5906 pixels == 2.5 gigapixels. Assuming you're using 8 bits/channel mode RGB, that's 7.5 gigabytes to store the image exactly once in RAM.
Keeping in mind you'll need to actually WORK on this image in Photoshop, you'll need at least 10x that RAM (for History states, room to run various tools, etc.) and a LOT of super fast disk storage to be able to swap data to the scratch file. Numbers like 96 GB of RAM and several TB of SSD array storage space come to mind to even begin to think about working on such a huge image.
Any image that takes 7.5 gigabytes in RAM is going to be slow to work on no matter what computer you have today. And if you're hoping to work on an even taller image than 5906 pixels, then you start to get into the realm of computers that haven't been invented yet.
Third thing I'm thinking of is that you may have to divide it into smaller chunks and deal with manually aligning things you want to match up.
Thanks Noel!
I did already the calculation - I know it is big - too big. What my idea was to work like we do on Videos - We have the offline files (low resolution) and the online Files (high resolution)
We do everything on the offline files and then after being done - render the same steps with the online files. Was just wondering if there is a workflow for something like this.
Otherwise we will cut it up into smaller pieces and apply the scaled paths/shapes/adjustment layers on it.
I was hoping there is maybe a better workflow for it.
Thanks Georg
Thanks for the help!
I guess there is no way of working without slicing those images into parts.
If found the tip with the Photoshop proxy editing super helpfull - was searching for the right term all day.
these two videos were also helping a lot:
Guide File Workflow:
http://www.youtube.com/watch?v=GqWrh7OG5yQ&feature=relmfu
http://www.youtube.com/watch?v=-UNXJdTQKuw&feature=relmfu
I will keep solutions posted here
North America
Asia Pacific
