There is a bug in Dreamweaver CS6 where the HTML5 code hints (and maybe others) stop working when you install the ColdFusion 10 extensions for Dreamweaver. If you uninstall the ColdFusion extensions then the HTML5 code hints work again.
I want to keep a copy of the HTML5 code hints and then 'paste' them back in after installtion the Coldfusion extensions so that Dreamweaver has all the code hints it should have. Why Adobe didn't bother to test their software for code hinting is beyond me, especially when Coldfusion is one of their own products! But anyway does anyone know where the HTML5 code hints are stored for tags like <header> and <footer> ?
The overall control of code hints for tag-based languages is in a file called C:\Program Files (x86)\Adobe\Adobe Dreamweaver CS6\configuration\TagLibraries\TagLibraries.vtm. It's in a similar location on other operating systems.
However, any changes to tag-based code hints are loaded from the TagLibraries folder in your personal configuration folder (see http://forums.adobe.com/thread/494812 for its location on different operating systems).
I suspect that what has happened is that whoever created the ColdFusion 10 code hints extension added the new CF tags to an old version of TagLibraries.vtm. That would explain why HTML5 code hints disappear. Dreamweaver always uses the version of TagLibraries.vtm in your personal configuration folder if it exists. As soon as you uninstall the CF10 code hints, Dreamweaver deletes TagLibraries.vtm from your personal configuration folder, and reverts to using the default version in the main program configuration folder.
Since you're comfortable coding with ColdFusion, you should probably have little difficulty editing the version of TagLibraries.vtm in your personal configuration folder. Just copy the first <taglibrary> element from the default TagLibraries.vtm and use it to replace the one created by the CF10 extension. You should then have both CF10 and HTML5 code hints.
I'm pretty sure that will fix the issue for you. But you should file a bug report concerning the extension. The ColdFusion team is completely separate from the DW one, and from what I hear, they don't communicate much. It should be a trivial matter for the CF team to update their extension.
Thanks David, I managed to fix the bug now. I combined the two TagLibraries.vtm files and made one proper one.
I submitted the bug twice to the Dreamweaver guys but if they are not in any communication with ColdFusion then I think that is enough confirmation to me that ColdFusion is on its death-bed.
I could understand if say the Illustrator team didn't communicate much with the ColdFusion team, but DW and CF should be like a married couple. You've got an amazing front-end web design tool which isn't in communication with an equally amazing back-end language and they're both made by the same company? At the same time they offshored all of CF to India therefore effectively isolating it from the main HQ. To me it sounds as if CF might eventually be sold off to another company.
North America
Asia Pacific
