.MTS files from Panasonic GH2 camera show noise artifacts
Nov 24, 2012 2:27 PM
If I load .MTS media files from my Panasonic GH2 camera onto the timeline of Premiere Pro CS6 (Win7 on PC) on some footage I get a wierd noise/artifact appearing in the footage on playback and also if i render the timeline out.
The artifacts look like a 'rain' of digital noise appearing in certain dark areas of the footage (issue doesn't happen on well lit scenes)
If I use Media Player Classic to play back the .MTS footage outside of PP CS6 the footage plays back 100% ok.
If I transcode the .MTS files into DNxHD format using Adobe Media Encoder the problem persists.
However ....if I transcode the .MTS files into DNxHD format using a 3rd party transcoder (5DtoRGB) the problem is resolved and the DNxHD files work 100% ok in PP CS6
It is as though both PP CS6 and also Adobe Encoder are not interpretting the .MTS file structure ok (?) and introducing artifacts.
It seems that some dev work is needed to resolve the handling of .MTS files by Adobe (?)
Can anyone please assist?
Replies 1 2 3 Previous Next
    Nov 24, 2012 2:30 PM   in reply to skydragon01
    I've seen this once before.  It turned out the artifacts were indeed in the original footage, as they also showed up when played by VLC.
    I've never seen anything like it with my own GH2 footage.
    Nov 25, 2012 9:41 AM   in reply to skydragon01
    I'd say a) is your issue.  You may want to have the camera serviced.
    Nov 30, 2012 3:45 AM   in reply to Jim Simon
    I have the same problem.  But can't get ffmbc to run.  I am so glad someone else posted this.  I thought I was nuts.  Any other traction on a resolution?
    Nov 30, 2012 3:53 AM   in reply to jimmiesner
    I double checked my files in vlc and those files do not have artifacts but they are prominent in premiere.  Please help.
    Nov 30, 2012 5:27 AM   in reply to skydragon01
    Can you upload a file?
    Nov 30, 2012 8:11 AM   in reply to skydragon01
    I do not see much of the 'rain' in the VLC player.
    But the 'rain' is visable in Pro and AE. Also very visible in QT. Its not just visible in the underxposed area but its all over the picture
    There is also a faint green vertical line on the left side of the image.
    Nov 30, 2012 8:15 AM   in reply to Ann Bens
    Again pointing to the issue being with the actual footage, not PP's handling of it.
    Feb 18, 2013 3:09 PM   in reply to Jim Simon
    I use the GH2 with PP CS6 and the digital rain is a real, consistent problem. It is not in the source file, it occurs in rendering of shadow areas. The problem has a workaround, which is to resample the footage to another codec, such as Cineform. I'm assuming the problem is in the mainconcept decoder. There is only a slight loss in quality from using an intermediate codec, but it is a bug of some sort.
    Feb 18, 2013 4:58 PM   in reply to DrDave42
    It has been in the few that I've checked.  (And apparently the one Ann checked as well.)
    Feb 18, 2013 5:30 PM   in reply to Jim Simon
    Well, then the people who have the problem can still fix it using the workaround, and the people who don't have the problem don't need to use the workaound. It would be nice if there is no need to resample the source file, nothing is perfect. I think most people who have the proble--and this is more than a few people--just decided to convert to an intermediate codec; I use Cineform, but I see several people are using 5D2RGB and prores to solve the problem. I'm happy to upload some particularly vivid examples, I don't use Vimeo because they resample the source files. However, I'm resigned to resampling, I don't have hours and hours to go over each clip to see if they have noise added.
    Feb 18, 2013 6:26 PM   in reply to DrDave42
    Here are two files, the first is the Cineform intermediary solution
    https://truck.it/p/mOaWfQTQsN
    The Second is the AVCHD file encoded directly from PP6
    https://truck.it/p/jMrhW0Zc00
    Feb 18, 2013 10:18 PM   in reply to DrDave42
    You shouldn't have to, though.  I'm saying something may be wrong with your camera if it's recording those artifacts, because in several hundred hours worth of shots using stock firmware and half a dozen patches, I have never had it.
    Feb 18, 2013 10:43 PM   in reply to Jim Simon
    Well, you could say that there are a number of cameras that have a problem--like a large batch with an identical design flaw--but you would not be able to repair it because it only shows up in videos with a combination of high bitrate and short GOP. You would never be able to cover that under warranty. The camera company would simply say it is PP CS6 fault, and no one could blame them for saying so since every other NLE can handle it with no problems. After all, it doesn't show up in playback.
    Feb 19, 2013 9:49 AM   in reply to DrDave42
    The fact that the artifacts do show up outside of PP is pretty strong evidence that it isn't PP CS6 fault, though.  The fact that clips which do have the problem show it in PP for me, but my own clips do not is also pretty strong evidence that there is something wrong with those clips.
    Now why the artifacts show up in some software but not others is a valid question to ask.  For those with the problem, it might be worth finding an answer.
    Feb 19, 2013 4:33 PM   in reply to Jim Simon
    They only show up in PP, as far as I can tell. To see if your camera can repeat the issue, you have to set the parameters to highlight the problem.
    Feb 20, 2013 2:08 PM   in reply to DrDave42
    I've seen the artifacts in VLC and Ann saw them in QuickTime, so it's not just PP.
    I'm happy to do more testing with my camera, but you'll have to be more specific about 'parameters'.
    Feb 20, 2013 11:25 AM   in reply to Jim Simon
    What did you think of the samples I uploaded?
    Feb 20, 2013 12:34 PM   in reply to DrDave42
    I see the 'rain' in the avchd clip but not in the CF clip (both played on VLC and PP)
    Feb 25, 2013 5:42 PM   in reply to Ann Bens
    Hi guys.  Just wanting to pitch in here as I found this post and I am having exaclty the same problems.  Here is my post today on Creative Cow.  It appears to be a problem with the Mainconcept filers used by PP which needs to be fixed.  I got thhat information from this post and my post follows:
    http://personal-view.com/talks/discussion/5120/please-help-problem-wit h-my-gh2-footage/p2  post near the bottom by "willyfan".
    Here is my experience.
    The problem is rain like artifacts on GH2 MTS files when viewed and exported from PP CS6 (I haven't tried but apparently cs5.5 was the same). I have taken some clips and you can view them with the links at the bottom of this post. The rain like effect builds up over 1 second then disappears then builds again cyclically every 1 second. Guessing this is GOP related??
    If you view the original material in VLC the first second shows the effect then it disappears and you just have the normal background noise but no obvious cycling rain. I have tried both stock 1.1 GH2 firmware and with higher bit rate set via ptools but the effect is the same even with stock firmware.
    Import into PP and you can see it on source and program monitor, it does not show if you set the monitors to half res. However the export does show the effect.
    If I transcode the MTS via FFMBC to prores the prores files plays fine from the vert start, shows fine in PP when imported and exports fine too.
    So this relates to some sort of comparability issue between PP (and AE I am told) and the GH2 MTS files.
    If anyone else has come across this can you tell me how you resolved it. Obviously I can pre convert to prores prior to import the PP but that negates the huge advantage of native support on the PP timeline and wastes a lot of time.
    Files below of 2 sec clip if you want to have a look but any ideas guys?
    Cheers
    Andy
    Original GH2 MTS 1280/50F under exposed to show effect
    https://mega.co.nz/#!WgpkBZrb!RlDm6n2xeq-bGI4t4UDnhHXmiaAZKRERg_YqxvXH KIA
    Exported MP4 from PP CS6.0.3
    https://mega.co.nz/#!38IxGQjA!WwAjaiIW7KF7lgoDkquGokrdutZqdDrvTEorl4o6 dks
    Original MTS converted to ProRes via FFMPEG, imported to PP then exported.
    https://mega.co.nz/#!zsg3xL5Q!d8Sj1QZfLdQh6h6XMJfIJXvIuVEl69X5bCF6eGFd 2aY
    Feb 25, 2013 6:35 PM   in reply to andynz222
    That's unlikely, as my own GH2 clips have never shows these artifacts.  Further, neither VLC nor QuickTime require the MainConcept filter to play the clips, yet those programs do also show the artifacts.  I've also recently learned that at least one user is seeing these artifacts using Sony Vegas.
    I'm telling you guys, all the evidence points to the problem being in the clips.
    Feb 25, 2013 6:48 PM   in reply to Jim Simon
    Hi Jim
    The clips play fine in VLC but not PP so if, as you say, Mainconcept is not used in VLC that would point all the more to it being a compatabilty issue with PP and the MTS's.
    I have 2 different GH2's bought at different times from differnet suppliers but both exhibit the identical problems.  Whilst I can understand there could be problems with the clip, ffmpeg seems to have no such trouble giving me a perfect prores transcode so the filters in PP are an issue in this situation.
    Cheers
    Andy
    Feb 25, 2013 6:51 PM   in reply to Jim Simon
    I took the trouble to upload two files which show the difference, and after viewing those files, if anyone still does not think this is an issue, then that of course is the nature of subjective observation.
    What we do know, is that the problem goes away if you render the video using 5.5, or use an intermediary codec. I find the idea that if the camera is at fault, the fact that 5.5 knows this, but version 6 does not, an intriguing idea, but I can't see how it would work. Since there is a simple workaround, like many things, it is better to work around it.
    Feb 25, 2013 6:56 PM   in reply to andynz222
    They don't.  At least, the clips I've checked do show the artifacts in VLC as well.  And Ann has seen them in the QuickTime player.  And Sony Vegas shows them as well.
    It is curious why some software will show the artifacts and not others.  It's a thread worth pulling.  But the totality of evidence so far still points to the problem being with the actual clip.
    Feb 25, 2013 6:59 PM   in reply to DrDave42
    I'd not be happy with that, myself.  I'd want to find out exactly why they appear and get it fixed.  'Cause like I said, in 8 months of using my GH2, in a few hundred hours worth of footage, I've never once seen those artifacts.
    Feb 25, 2013 7:14 PM   in reply to Jim Simon
    If you downloaded my files, and they look the same in VLC, then that would be an unusual piece of the puzzle, but no one else has made that observation. It is also unusual that CS5.5 works fine, and CS6 doesn't. I'm not disagreeing with you, everyone has different systems, monitors, etc. My examples were made in a very large room with large areas of shadows, which highlight the "rain" or whatever. Outdoors, you don't see it. I don't want to speak for Ann, but she looked at my clips and echoed back rain in one, not the other. That's what I get and a bunch of people who work in my area. If you get the same rain in both of my clips, then I can't explain that.
    I appreciate it that she took the time to look at my clips, and I appreciate everyone's opinion here, of course.
    I bought CS6 for Speedgrade and hopefully a better AVCHD experience. I have no sour grapes. I found Speedgrade unusable, but I love the new three-way color corrector in V6. So, great upgrade for me. My AVCHD experience needs a workaround for some clips. I do my pullldown in AE, it works perfect. I do my pulldown in Premiere, not as good. So, no problem. I use AE for pulldown, it looks great.
    I would prefer it if everything worked perfect, but this is a great product. I only posted this because I spent hours trying to fix this problem, and I wanted to save some people some grief. If you don't get this unusual digital rain, that is way cool. And if it is the camera that is at fault, or the program, you can just use Premiere 5.5, which also has the advantage that it handles the file spanning.
    Feb 25, 2013 7:27 PM   in reply to DrDave42
    Ann did, as reported in post 20.
    She saw them in the original, but not the converted.  That's not unexpected.  It follows the idea that some software shows the artifacts (PP, VLC, QuickTime and Vegas), but not others (my preferred KM Player does not show it).  That seems very odd to me.  But I don't know enough about how the software works to explain it.
    Feb 25, 2013 8:09 PM   in reply to Jim Simon
    I just tried my clips in CS5 and the fault is not there, just normal low level noise.  So CS5 does handle the files ok and CS6 does not.  What ever the reason CS6 is less capable in this particular aspect than earlier versions.
    Understanding where errors are creaping in is mine field these days but I think this is worth investigating by Adobe.  As DrDave says, in a lot of shots you wont see the fault, however it stood out like "dogs bits" on a shoot done last week with a speaker in front of a mid coloured painted wall, ie, pretty much constant area of low saturation colour.  The test I did today and posted as above is of our office wall under exposed on purpose the show the fault and it is really really obvious and really unusable.
    So having spent the day investigating and following the paths of other people I have a work around which is reassuring however there is a problem which has been introduced in CS6 and I think it is worth looking into the downgrade in performance in this area.  Hey don't get me wrong,I love Premiere CS6, beats the pants of everything else out there but it has its bugs like everything and the speed attraction of native support of MTS files is lost and I am back to pre rendering.  Can we help Adobe investigate and find if not a solution then a reason??
    Cheers
    Andy
    PS DR Dave I jsut checked your clip encoded via CS6, and I can some of the effect but please guys have a look at the clips I did, they are only a few seconds long but the problem is as clear as night and day, you really can't miss it.
    Feb 25, 2013 8:29 PM   in reply to Jim Simon
    There are two files that I posted, one is rendered using Cineform, one is rendered by dropping the AVCHD file on the timeline. The one that Premiere CS 6 rendered has the noise, the one that used the intermediary codec and then was rendered does not have the noise. There is no noise in the original, that is, the original is identical to the Cineform.
    Most people who look at the two files will see a difference. If it is important to you, as it seems to be, just take a moment to look at the two files.
    Feb 26, 2013 8:33 AM   in reply to andynz222
    Again, given that the issue shows up in several other programs, it is almost certainly with the clips themselves.  Which points to a camera malfunction.  More so that not all GH2 will exhibit the artifacts.
    Feb 26, 2013 8:34 AM   in reply to DrDave42
    Post it.
    Feb 26, 2013 10:40 AM   in reply to Jim Simon
    Jim.  I see this fault only in PP CS6, I do not see it anywhere else including in VLC.
    Jim.  I have done so above with my MTS clip on Mega storage.
    Feb 26, 2013 11:07 AM   in reply to Jim Simon
    Totally wrong.
    Its the programs and the way they handle the mts codec on decode. Hacked GH2 footage goes beyond Profile High Level 4 in bitrate. Adobe and other programmes decoder is unble to read the hi bitrate data correctly - probably decoding it to the confines of the lower elements of profile. Adobe, VLC and the likes  should look into it.
    WMP users should dowload K-lite encoder pack which has a better decoder than Adobe's.
    Feb 26, 2013 12:14 PM   in reply to NickDriftwood
    That's generally bad advice around here, Nick.  K-Lite has a history of messing up Adobe's software.
    Feb 26, 2013 3:38 PM   in reply to NickDriftwood
    Not sure that explains it.  The artifacts have shown up for folks even when using the stock 1.1 firmware.  And they don't show up for every camera.
    I still believe the issue is in the clips themselves.  Or at least, a combination of clip and software.
    Feb 26, 2013 12:17 PM   in reply to andynz222
    Yes, you did.  And I did see the artifacts in VLC.  But DrDave hasn't yet uploaded the original MTS.
    Feb 26, 2013 12:35 PM   in reply to Jim Simon
    Hi Jim
    so you are saying you downloaded my original MTS clip, played it in VLC and you saw the rain effet throughout the clip?  I see a short bit at the front then it disappears.  If we are seeing different things wit the same clip and VLC then that confuses things.  What ever I render out of PP CS6 I see the effect in every player.  Pre-render via Prores does not.  I am running CS6 Windows 7 64bit.
    Nick thanks for the comments but apart from setting PAL/NTSC and disable record lenth limitation in ptools 1.1 I am running stock bit rate.  The effet happened with stock bit rate and set to average 25mbs.
    Cheers
    Andy
1 2 3 Previous Next
Actions
