hkjhht
Help!My Acrobat XPro crashed after I downloaded a pdf file but it saved itself as .ASPX
Nov 25, 2012 10:08 AM
As said, I downloaded a pdf file from web and liked to save it , but it saved itself as .ASPX. I was unaware of this, then I found the saved files could not be opened by XPro, and within second, the XPro failed to boot up.
I uninstalled the program, used the cleaning software, and tried to reinstall Acrobat X again. But this time, it did not work!
Very frustrated!! The disk showed that I had the XPro installed and did not enable reinstallation.
Please help, my assignment due day is coming!!!
Attached the summary report:-
Many thanks in advance!
hkjhht
    Nov 25, 2012 11:28 AM   in reply to hkjhht
    From the screen shot of your install log it appears you received a 1603 error.  Please try the steps listed in Error 1603 | Install | CS5 products - http://helpx.adobe.com/creative-suite/kb/error-1603-install-cs5-produc ts.html.
    You may also want to review your install logs in greater detail by following the steps listed at Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5 -cs5.html.
    Finally your initial issue sounds more like an issue with the site you were trying to download the PDF from.  Instead of offering you a PDF they offered you an ASPX file.  I would try a different web browser once you have Acrobat reinstalled.  It is either an issue with the site or your web browser.  Try a different web browser if the problem continues.
