I want to make high-quality DVD(Blu-ray Format) with premiere.
But, when I used Ecore and select Blu-ray to exported the image disk.
(want burning the DVD from toaster).The DVD was video only.(The menu has not been played).
If changed to DVD to exported the image disk, it was ok, the menu has been played.
Did I lost step or wrong way?
thank you
li
A BluRay disc and a DVD disc are the same size, but they are completely different
Some reading that may help
Encore http://tv.adobe.com/show/learn-encore-cs4/
Authoring http://www.videocopilot.net/tutorials/dvd_authoring/
Encore Tutorial http://www.precomposed.com/blog/2009/05/encore-tutorial/
And more Encore http://library.creativecow.net/articles/devis_andrew/
Do you want to put your video onto a DVD or Bluray disk? It must be one or the other. If it is DVD, it cannot be high definition, only standard defintion (720x480 for NTSC).
I understand you want to have a menu.
So you add a menu. then add your video "as timeline." LInk a button on the menu to your timeline.
Some time ago I wrote down some notes... this is for a DVD, but the steps are the same for a BluRay, except with HiDef video and menu
http://www.pacifier.com/~jtsmith/Encore.txt - a very simple process
thank you for your answers and document~
I hope make the Blu-ray Disc(have menu).
I tied it with bulid>disc:format:Blu-ray/Output:Blu-ray Disc, but when I played it with Blu-ray player, it have not menu.
So, I use same video test it with DVD , the menu can be played with player.
I hope confirm with does Encore can output the Blu-ray with the menu and how to do this.
thank you very much.
Did you set the menu to be First Play?
If you do there is no problem with menus operating in Blu-ray disks. I do this all the time, usually with a Main Menu, with up to four Sub-menus.
The only problem I ever have is with the navigation within a menu. Encore has button routing set at automatic as default, and the automatic setting is not much use as it excludes , Next, Previous, and Main buttons!
Effectively, I post this because I hope help other one to solve this issue.
So at first I didn't not very clearly understand about it.
The issue point is hope export AVCHD disk form Premiere/Encore.
(Premiere Element can export AVCHD file).
Now, I thought the Premiere/Encore can't export AVCHD disk.
The menu describe form in the other one, I think is not issue point and maybe operate mistake.
thank you!
North America
Asia Pacific
