kaybee272
Help wanted with splitting multi image page
Nov 25, 2012 2:42 PM
I have a document (a user manual that had bee scanned ?) and combined on single pages.
There are 2 pages in the file and each page contains 16 page images in a 6 across by 3 down grid.
I would like to extract each page image so I end up with one file of 32 pages. I have searched and searched but can not find info.
Page split is no problem it is the images on each page
Anyone any ideas please
Keith
Windows 8
Akrobat XI
    Nov 26, 2012 3:14 AM   in reply to kaybee272
    In Acrobat you can duplicate and crop the pages.
    You can also save the pages as TIFF files, extract the images with a graphic editor (Photoshop), and create a new PDF document from the images.
    Nov 26, 2012 9:45 AM   in reply to kaybee272
    You could also use the Export All Images command under the Document Processing panel to grab just the images. Then use the Combine dialog to create rebuild them back into a 32-page document.
    Nov 26, 2012 11:27 AM   in reply to LoriAUC
    This will work when you have 16 images on every page.
    Nov 26, 2012 12:23 PM   in reply to kaybee272
    It sounds like the images my not be defined as 6 images in 3 rows. You can check this by opening the Content pane and looking for the images. The exact height and width will be specified.
    If you select the Edit Text & Images command do you see frames around each image? If so, can you right-click over an image to select the Save Image As command?
