mattpotter28
Moving an 8-bit Picture to Flash
Nov 26, 2012 6:01 AM
Tags: #background #flash #white #8bit
     I'm currently working on a project where I have 8-bit characters running around. I have a problem with transferring the 8-bit character to Flash without it having a white background and without it being blurry. I attached the png file with the Sprites that I'm using. Thanks for the help.
    Nov 26, 2012 6:48 AM   in reply to mattpotter28
    What version of Flash? CS5.5 imported your PNG with transparency just fine.
    If it's a much older version consider GIF with transparency (still 8bit) or just use a 24bit PNG.
    Just a note, I didn't copy/paste it from photoshop or anything like that. I saved the file, then file->imported it so there's no possible complications.
    Nov 27, 2012 6:42 AM   in reply to mattpotter28
    Yep
    Make sure in the Bitmap properties you don't have smoothing checked off and it's lossless PNG.
    Nov 28, 2012 8:08 AM   in reply to mattpotter28
    You're welcome and please mark correct answers so we can filter unanswered questions. Good luck!
