Fade Fill option doesn't show in Photoshop CS6
Nov 26, 2012 12:43 PM
Tags: #photoshop #fill
Why do I not get the option to "fade fill" when I use the ALT/Backspace keyboard shortcut to fill a layer.  If I use the menu option Edit/Fill.. to perform the fill I am given the option to "fade fill"
    Nov 26, 2012 11:42 AM   in reply to ClevelandPh0T0
    When you Edit>Fill you get an option for Opacity. When you alt+backspace to fill with foreground color and immediately go to Edit menu, you should see the Fade Fill option there.
    Nov 26, 2012 12:12 PM   in reply to ClevelandPh0T0
    Odd. It works here. Are you deselecting after Alt+Backspace?
    Try trashing your preferences. Quit Photoshop and hold down the shift+alt+control key AS you relaunch Photoshop (shift+opt+command on a Mac). You'll get a small dialog to confirm you wan to reset your preferences.
    It shouldn't make a difference... but I'm on a Mac using opt+delete keys to Fill with Foreground Color. Should be the same on PC, but maybe not?
    Nov 26, 2012 1:40 PM   in reply to ClevelandPh0T0
    Hi there! You’ve posted your question in a forum that is for beginners trying to learn the basics of Photoshop.  I'm moving your question to the Photoshop General Discussion forum for specialized attention to your situation.
    Nov 26, 2012 2:16 PM   in reply to ClevelandPh0T0
    press CNTL/J to make a new layer with that selection ( new layer is now selected)
    Ok. If you make a new layer via copy, it creates a new layer of the selection but now deselected (ie, no marching ants). Fill via Alt+Backspace and now Edit>Fade Fill is grayed out. OK, I see that here too with those steps.
    So I guess a work-around after Cntl+J, is to go Cntl+A to selected the whole of the new layer, then Alt+Backspace. Now Edit> Fade Fill should be active.
    Nov 26, 2012 2:55 PM   in reply to ClevelandPh0T0
    I'm going to vote for bug on this. Minor bug. I don't see why keyboard shortcut to fill to a layer should have Fade Fill grayed out like this.
    Nov 26, 2012 6:06 PM   in reply to ClevelandPh0T0
    Actually that used to work in the way you want on non background layers in versions 5 and 5.5, but was changed to the present way in the old photoshop 6.
    Why the change i don't know.
    On windows you can also use the keyboard shortcuts of Shift+F5 or Shift+Backspace to bring up the fill dialog.
    You could also record an action for the Edit>Fill with foreground color and then assign a keyboard shortcut to the action, there by skipping the dialog
    and still have the fade (Shift+Ctrl+F) available.
