I am trying to add a link to an image in a tm_slider banner slideshow image. The a href tag isn't working. Adding it through add behavior also did not work. Adding a hotspot to the .png also did not work. Any suggestions?
First things first. Fix your HTML errors.
http://validator.w3.org/check?verbose=1&uri=https%3A%2F%2Fmicounties.o rg%2F
And on lines 709 & 727 of style.css, you have used invalid property:values. Delete them.
.cse .gsc-control-cse div,
.gsc-control-cse div {
position: normal;
.cse .gsc-resultsHeader,
.gsc-resultsHeader {
border: block;
When you get your code errors sorted & uploaded, post back.
Nancy O.
44 errors is unacceptable. You're using an HTML5 doc type which is
a) not the same as HTML4 or XHTML1 and
b) much less forgiving of code errors.
On line 117 you have this:
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
Which should be changed to this.
<meta charset="utf-8">
And again on line 137,
Delete it.
You have carelessly used <br /> instead of <br> throughout your document.
You have <br /> inside lists (not allowed). If you need more padding between list items use CSS line-height, not break tags.
You have style tags inside <div> tags. Styles don't belong there. They belong in your style sheet.
Finally, you have used ampersands in your folder and filenames. Special characters should never be used in folder/ filenames. On the web, it's OK to use dashes - or underscores _ but no spaces or special characters (@#$%^&*+) which are used by programming languages .
Keep working.
Nancy O.
Here's the portion of the code in the js file that refrences using the a href tag. I'm wondering if an option needs activating or identifying.
paginationFu:function(){
var _=this
if(_.pagination===false)
return false
if(_.pagination===true)
_.pags=$('<ul></ul>')
.addClass(_.paginationCl)
.appendTo(_.me),
$(_.itms).each(function(i){
var li=$('<li></li>'),
a=$('<a href="#"></a>')
.text(_.pagNums?i+1:'')
.appendTo(li)
.bind(_.changeEv,function(){
_.changeFu(i)
return false
_.pags.append(li)
_.pags=_.pags.find('li'),
_.pags.eq(_.n).addClass(_.currCl)
else
_.pags=$(_.pagination)
I sure appreciate your help! Thank you!
For some reason, your page doesn't like </a> tags in the TMSlider. I don't know why that is.
Try replacing what you have now on lines 249 - 253 with this code and see if it works for you.
<div class="slider">
<ul class="items">
<li><a href="events.php"><img src="images/page1-slide2update.png" alt="New Commissioner Workshops 2012" /></li>
<li><a href="about.php"><img src="images/page1-slide1update.png" alt="Grand Rapids, Michigan" /></li>
</ul>
</div>
Good luck!
Nancy O.
Thanks, Nancy! It didn't work - thinking of coming up with a work around. Client wants the images in the slider to link but I just can't get that working right. All tips and forums point to the a href tag but like you said for some reason the slider isn't liking it.
Thanks so much for all your tips, though. After two days - I think it's time for an alternate solution.
I purchased a license for WowSlider, decided I liked it better. Troubleshooted nearly all issues (menu hiding behind slider was resolved by resetting z-index for the menu to 101, WowSlider is set to 100). However, issues continue with the menu. I even set z-index to 999 and added a bunch more z-index values to different parts of the menu in css.
I've narrowed it down to it being related to having multiple jquery objects on a page. I have a conflict with the Superfish menu and the WowSlider - only on the homepage, where WowSlider is. The forums suggest inserting the following noconflict code which I did but it made the menu fail completely.
jQuery.noConflict();
var $j = jQuery;
</script>
I need to do more with this noconflict command but can't find an example I understand. Your expert advice most appreciated. I'm hoping I'm close.
Thanks.
North America
Asia Pacific
