Having issues with Bridge CS6 on my IMac.
I deleted the files out of the application folder since there was no "uninstall" feature. I also deleted the Bridge CS6 extensions out of the Library.
To re-install Bridge, I uninstalled Photoshop CS6 & then re-installed it - no luck. Tried the same thing with InDesign - no luck. Flash - no luck.
So, how do I get Bridge CS6 back on my Mac using Creative Cloud online?
thanks
Morifius007 have you tried uninstalling the applicatons using the uninstallers in Applications/Utilities/Adobe Installers? In your original message you indicated you dragged the applications to the trash as opposed to utilizing the uninstallers. This is likely what has lead to your current difficulties.
This is correct. Bridge is installed as part of Photoshop, Illustrator, InDesign, and Dreamweaver. Please run the uninstaller for each of the applications you have removed and then try reinstalling. You can also install from the trials available on http://www.adobe.com/ to prevent the need to download the install files again via the Adobe Application Manager.
If you are still facing difficulties then I would recommend removing all currently installed Adobe Creative Software and running the Cleaner Tool. You can find details for the use of the Cleaner Tool at CS Cleaner Tool for installation problems | CCM, CS6, CS5.5, CS5, CS4, CS3 - http://helpx.adobe.com/creative-suite/kb/cs5-cleaner-tool-installation -problems.html.
The regular uninstallers may have difficulty uninstalling due to the applications previously being manually removed. I am recommending the complete removal of Adobe Creative software prior to it's use to prevent additional difficulties from arising if you should need to run the Cleaner Tool.
North America
Asia Pacific
