Hi there!
Importing XLS data was discussed a lot already. But I don't want to create table, but I need to import text to the prepared textframes across the document.
Have a look at the IMG below. There will be about 300 such cells. Photo and textframe below. I have XLS file with all the info. And I need this info to be put to that textframes {green in the IMG}. Is the only solution to Copy > Switch to the ID-window > Paste > Delete redundant paragraphs > Switch to the Excell window? It would require a thousands mouse-clicks & keystrokes…
The structure of my textframe looks like this {Microlight was typed manually}:
Each paragraph has source in XLS file:
I understand importing the Excel table when i wan to create ID table. But I have just a bunch of textfields...
Thank you!
This might be a job for Data Merge, or a commercial catalog plugin, but the merged celss are going to be a real problem, I think. Exporting as a text file from Excel and just palcing it may also work, with the same caveat about merged cells, and a probable need to use find/change to remove tabs.
North America
Asia Pacific
