toanimate
CS4 Bug - Rotating jpg gets bounding box stretched and center shifted
Nov 26, 2012 7:29 PM
Tags: #bug #box #rotation #rotating #bounding #stretch
CS4 Bug - Rotating jpg gets center stretched and size expanded.
What happens is I have a jpeg in a separate layer. I then shrink it to overlay on another layer. I begin to shrink and rotate it, and then at some point (seemingly a certain angle) during rotation the image's bounding box gets stretched like 500% or some gross number. How do I stop this from happening?
    Nov 26, 2012 7:36 PM   in reply to toanimate
    upgrade.
    CS4 will never be fixed or repaired.
    I can't reproduce this with your rundimentary steps.
    Nov 26, 2012 11:27 PM   in reply to toanimate
    Well you can't resize and rotate in one step.. so there are steps missing in your description.
    To properly file a bug and allow other users to confirm it is indeed a bug you need to clearly define exact steps which produce the unexpected behavior. This allows any other user to follow those exact steps and either confirm or deny the problem.
    Nov 27, 2012 11:09 AM   in reply to toanimate
    *sigh*
    HOW do you resize? To what degree?
    HOW do you rotate?
    Describe EXACT steps as if describing it to someone who has never touched Illustrator.
    Nov 27, 2012 12:30 PM   in reply to toanimate
    Scott means; which tools do you use to scale and rotate?
    For example I always use S for Scale and R for Rotate, but some people prefer to use bounding boxes.
    Depends on what you are used to.
