jarhtmd
Images aren't completely visible after loading in Photoshop CS6
Nov 26, 2012 9:27 PM
Tags: #issue #image #install #layers #cs6
I've been using CS3.  Without un-installing CS3, I installed CS6 . . . actually both 64bit & 32bit.  I had several problems when running.  For example, images often were not completely visible after loading . . . part of the image showed as transparent.  I could duplicate the layer & all was ok, with both the new & original layers.  This hasn't been a major problem, but is a nuisance & indicates that something is not right.  Several features even cause "Photoshop CS6 has stopped working".  Thankfully, I could always fall back to CS3 when a problem cropped up, altho' it was a pain having to save so often.
I deactivated CS6 and uninstalled (via Control Panel).  I then re-installed, installed updates & re-activated . . . same problem when images load.  I just re-installed, so I haven't had a chance to test other things.
I've postponed installing Lightroom4, hoping to solve CS6 problems first.
Any suggestions?
    Nov 26, 2012 9:51 PM   in reply to jarhtmd
    Update your video card driver from the GPU maker's website.
    You've got an older version of the driver that has serious bugs in it.
