Can't update or uninstall Adobe Air
Nov 26, 2012 10:57 PM
Had a problem with the previous update and used the Windows Install Clean Up which worked fine. Latest update is not working and IPlayer desktop died along with it. Tried Microsft Fix IT as suggested in these forums and it couldn't find any error. I have tried uninstalling and doesn't work, presented with the following:
"This application requires a  version of Adfobe AIr which cannot be found..."
Could you give me any help, logs are as below:
[2012-11-27:06:50:40] Runtime Installer begin with version 3.5.0.600 on Windows Vista x86
[2012-11-27:06:50:40] Commandline is:
[2012-11-27:06:50:40] No installed runtime detected
[2012-11-27:06:50:43] Relaunching with elevation
[2012-11-27:06:50:43] Launching subprocess with commandline c:\users\rob\appdata\local\temp\air3d39.tmp\adobe air installer.exe -ei
[2012-11-27:06:50:49] Runtime Installer begin with version 3.5.0.600 on Windows 7 x86
[2012-11-27:06:50:49] Commandline is: -stdio \\.\pipe\AIR_5676_0 -ei
[2012-11-27:06:50:49] No installed runtime detected
[2012-11-27:06:50:49] Starting silent runtime install. Installing runtime version 3.5.0.600
[2012-11-27:06:50:50] Installing msi at c:\users\rob\appdata\local\temp\air3d39.tmp\setup.msi with guid {14DC0059-00F1-4F62-BD1A-AB23CD51A95E}
[2012-11-27:06:50:53] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-11-27:06:50:53] Rolling back install of c:\users\rob\appdata\local\temp\air3d39.tmp\setup.msi
[2012-11-27:06:50:53] Rollback complete
[2012-11-27:06:50:53] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-11-27:06:50:53] Runtime Installer end with exit code 7
[2012-11-27:06:50:56] Runtime Installer end with exit code 7
MSI Log:
=== Verbose logging started: 27/11/2012  06:50:50  Build type: SHIP UNICODE 5.00.7600.00  Calling process: C:\Users\Rob\appdata\local\temp\air3d39.tmp\adobe air installer.exe ===
MSI (c) (E8:E8) [06:50:50:111]: Resetting cached policy values
MSI (c) (E8:E8) [06:50:50:111]: Machine policy value 'Debug' is 0
MSI (c) (E8:E8) [06:50:50:111]: ******* RunEngine:
           ******* Product: c:\users\rob\appdata\local\temp\air3d39.tmp\setup.msi
           ******* Action:
           ******* CommandLine: **********
MSI (c) (E8:E8) [06:50:50:112]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (E8:E8) [06:50:50:112]: Grabbed execution mutex.
MSI (c) (E8:E8) [06:50:50:120]: Cloaking enabled.
MSI (c) (E8:E8) [06:50:50:120]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (E8:E8) [06:50:50:125]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (70:E0) [06:50:50:135]: Running installation inside multi-package transaction c:\users\rob\appdata\local\temp\air3d39.tmp\setup.msi
MSI (s) (70:E0) [06:50:50:135]: Grabbed execution mutex.
MSI (s) (70:D8) [06:50:50:136]: Resetting cached policy values
MSI (s) (70:D8) [06:50:50:137]: Machine policy value 'Debug' is 0
MSI (s) (70:D8) [06:50:50:137]: ******* RunEngine:
           ******* Action:
MSI (s) (70:D8) [06:50:50:137]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (70:D8) [06:50:50:138]: Setting cached product context: User non-assigned for product: 0B436121B4F23D11DA3A000CF425DD25
MSI (s) (70:D8) [06:50:50:138]: Using cached product context: User non-assigned for product: 0B436121B4F23D11DA3A000CF425DD25
MSI (s) (70:D8) [06:50:50:138]: Setting cached product context: User non-assigned for product: 1DA44D45380A9B84DBF6FA5D717B7C57
MSI (s) (70:D8) [06:50:50:138]: Using cached product context: User non-assigned for product: 1DA44D45380A9B84DBF6FA5D717B7C57
MSI (s) (70:D8) [06:50:50:138]: Setting cached product context: User non-assigned for product: 3B64B0B9FD01ADA4591010927D4865D3
MSI (s) (70:D8) [06:50:50:138]: Using cached product context: User non-assigned for product: 3B64B0B9FD01ADA4591010927D4865D3
MSI (s) (70:D8) [06:50:50:139]: Setting cached product context: User non-assigned for product: 64C25527B44961E4BB8CD0583FC18100
MSI (s) (70:D8) [06:50:50:139]: Using cached product context: User non-assigned for product: 64C25527B44961E4BB8CD0583FC18100
MSI (s) (70:D8) [06:50:50:139]: Setting cached product context: machine assigned for product: 000021091A0090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:139]: Using cached product context: machine assigned for product: 000021091A0090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:139]: Setting cached product context: machine assigned for product: 00002109411090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:140]: Using cached product context: machine assigned for product: 00002109411090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:140]: Setting cached product context: machine assigned for product: 00002109440090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:140]: Using cached product context: machine assigned for product: 00002109440090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:140]: Setting cached product context: machine assigned for product: 00002109510090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:140]: Using cached product context: machine assigned for product: 00002109510090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:141]: Setting cached product context: machine assigned for product: 00002109511090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:141]: Using cached product context: machine assigned for product: 00002109511090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:141]: Setting cached product context: machine assigned for product: 00002109610090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:141]: Using cached product context: machine assigned for product: 00002109610090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:141]: Setting cached product context: machine assigned for product: 00002109611090400100000000F01FEC
MSI (s) (70:D8) [06:50:50:141]: Using cached product context: machine assigned for product: 00002109611090400100000000F01FEC
MSI (s) (70:D8) [06:50:50:142]: Setting cached product context: machine assigned for product: 00002109711090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:142]: Using cached product context: machine assigned for product: 00002109711090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:142]: Setting cached product context: machine assigned for product: 00002109810090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:142]: Using cached product context: machine assigned for product: 00002109810090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:142]: Setting cached product context: machine assigned for product: 00002109910090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:142]: Using cached product context: machine assigned for product: 00002109910090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:143]: Setting cached product context: machine assigned for product: 00002109A10090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:143]: Using cached product context: machine assigned for product: 00002109A10090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:143]: Setting cached product context: machine assigned for product: 00002109A20000000100000000F01FEC
MSI (s) (70:D8) [06:50:50:143]: Using cached product context: machine assigned for product: 00002109A20000000100000000F01FEC
MSI (s) (70:D8) [06:50:50:143]: Setting cached product context: machine assigned for product: 00002109A20090400100000000F01FEC
MSI (s) (70:D8) [06:50:50:144]: Using cached product context: machine assigned for product: 00002109A20090400100000000F01FEC
MSI (s) (70:D8) [06:50:50:144]: Setting cached product context: machine assigned for product: 00002109AB0090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:144]: Using cached product context: machine assigned for product: 00002109AB0090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:144]: Setting cached product context: machine assigned for product: 00002109B10090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:144]: Using cached product context: machine assigned for product: 00002109B10090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:144]: Setting cached product context: machine assigned for product: 00002109C20090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:145]: Using cached product context: machine assigned for product: 00002109C20090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:145]: Setting cached product context: machine assigned for product: 00002109E60090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:145]: Using cached product context: machine assigned for product: 00002109E60090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:145]: Setting cached product context: machine assigned for product: 00002109F10090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:145]: Using cached product context: machine assigned for product: 00002109F10090400000000000F01FEC
MSI (s) (70:D8) [06:50:50:146]: Setting cached product context: machine assigned for product: 00002109F100A0C00000000000F01FEC
MSI (s) (70:D8) [06:50:50:146]: Using cached product context: machine assigned for product: 00002109F100A0C00000000000F01FEC
MSI (s) (70:D8) [06:50:50:146]: Setting cached product context: machine assigned for product: 00002109F100C0400000000000F01FEC
MSI (s) (70:D8) [06:50:50:146]: Using cached product context: machine assigned for product: 00002109F100C0400000000000F01FEC
MSI (s) (70:D8) [06:50:50:146]: Setting cached product context: machine assigned for product: 00002119030000000000000000F01FEC
MSI (s) (70:D8) [06:50:50:146]: Using cached product context: machine assigned for product: 00002119030000000000000000F01FEC
MSI (s) (70:D8) [06:50:50:147]: Setting cached product context: machine assigned for product: 000021599B0090400100000000F01FEC
MSI (s) (70:D8) [06:50:50:147]: Using cached product context: machine assigned for product: 000021599B0090400100000000F01FEC
MSI (s) (70:D8) [06:50:50:147]: Setting cached product context: machine assigned for product: 00004109500200000000000000F01FEC
MSI (s) (70:D8) [06:50:50:147]: Using cached product context: machine assigned for product: 00004109500200000000000000F01FEC
MSI (s) (70:D8) [06:50:50:147]: Setting cached product context: machine assigned for product: 032440EF5AC97F34B985A55C2AA8F133
MSI (s) (70:D8) [06:50:50:147]: Using cached product context: machine assigned for product: 032440EF5AC97F34B985A55C2AA8F133
MSI (s) (70:D8) [06:50:50:148]: Setting cached product context: machine assigned for product: 076CFAAAB965F2A4284B2449E5D03EFE
MSI (s) (70:D8) [06:50:50:148]: Using cached product context: machine assigned for product: 076CFAAAB965F2A4284B2449E5D03EFE
MSI (s) (70:D8) [06:50:50:148]: Setting cached product context: machine assigned for product: 082C112820B5E7E45BF548A5022794AB
MSI (s) (70:D8) [06:50:50:148]: Using cached product context: machine assigned for product: 082C112820B5E7E45BF548A5022794AB
MSI (s) (70:D8) [06:50:50:148]: Setting cached product context: machine assigned for product: 0B98994D2CB71F7F087123756F7143A7
MSI (s) (70:D8) [06:50:50:148]: Using cached product context: machine assigned for product: 0B98994D2CB71F7F087123756F7143A7
MSI (s) (70:D8) [06:50:50:149]: Setting cached product context: machine assigned for product: 0C41C76FE37DB55C1E231B09A4A107C9
MSI (s) (70:D8) [06:50:50:149]: Using cached product context: machine assigned for product: 0C41C76FE37DB55C1E231B09A4A107C9
MSI (s) (70:D8) [06:50:50:149]: Setting cached product context: machine assigned for product: 0C7EC0FA4E3A37D489B82B1978CEE6A9
MSI (s) (70:D8) [06:50:50:149]: Using cached product context: machine assigned for product: 0C7EC0FA4E3A37D489B82B1978CEE6A9
MSI (s) (70:D8) [06:50:50:149]: Setting cached product context: machine assigned for product: 0CA5B553EEEC5C24DAD4F7C3DF08C663
MSI (s) (70:D8) [06:50:50:149]: Using cached product context: machine assigned for product: 0CA5B553EEEC5C24DAD4F7C3DF08C663
MSI (s) (70:D8) [06:50:50:150]: Setting cached product context: machine assigned for product: 0D756077321A70C3E844C138CE981581
MSI (s) (70:D8) [06:50:50:150]: Using cached product context: machine assigned for product: 0D756077321A70C3E844C138CE981581
MSI (s) (70:D8) [06:50:50:150]: Setting cached product context: machine assigned for product: 0DA8E7241B4A522D38E6CC6B60B894A0
MSI (s) (70:D8) [06:50:50:150]: Using cached product context: machine assigned for product: 0DA8E7241B4A522D38E6CC6B60B894A0
MSI (s) (70:D8) [06:50:50:150]: Setting cached product context: machine assigned for product: 1007C6B46D7C017319E3B52CF3EC196E
MSI (s) (70:D8) [06:50:50:150]: Using cached product context: machine assigned for product: 1007C6B46D7C017319E3B52CF3EC196E
MSI (s) (70:D8) [06:50:50:151]: Setting cached product context: machine assigned for product: 11F12B5E3396B0E42AC597363E0CD711
MSI (s) (70:D8) [06:50:50:151]: Using cached product context: machine assigned for product: 11F12B5E3396B0E42AC597363E0CD711
MSI (s) (70:D8) [06:50:50:151]: Setting cached product context: machine assigned for product: 121100882E7840129F5FCE1CD5CF1A0E
MSI (s) (70:D8) [06:50:50:151]: Using cached product context: machine assigned for product: 121100882E7840129F5FCE1CD5CF1A0E
MSI (s) (70:D8) [06:50:50:151]: Setting cached product context: machine assigned for product: 121396FD0C0402036D5516E215164632
MSI (s) (70:D8) [06:50:50:151]: Using cached product context: machine assigned for product: 121396FD0C0402036D5516E215164632
MSI (s) (70:D8) [06:50:50:152]: Setting cached product context: machine assigned for product: 1271C3A5DE8F0E11A8BF8BCAF6798BE8
MSI (s) (70:D8) [06:50:50:152]: Using cached product context: machine assigned for product: 1271C3A5DE8F0E11A8BF8BCAF6798BE8
MSI (s) (70:D8) [06:50:50:152]: Setting cached product context: machine assigned for product: 14138CB5DD38EB709C04403B5845F040
MSI (s) (70:D8) [06:50:50:152]: Using cached product context: machine assigned for product: 14138CB5DD38EB709C04403B5845F040
MSI (s) (70:D8) [06:50:50:152]: Setting cached product context: machine assigned for product: 151D0FCE0ACBD6E826BDD544BDA48363
MSI (s) (70:D8) [06:50:50:153]: Using cached product context: machine assigned for product: 151D0FCE0ACBD6E826BDD544BDA48363
MSI (s) (70:D8) [06:50:50:153]: Setting cached product context: machine assigned for product: 17AB347E5595B024AA2576050845DA66
MSI (s) (70:D8) [06:50:50:153]: Using cached product context: machine assigned for product: 17AB347E5595B024AA2576050845DA66
MSI (s) (70:D8) [06:50:50:153]: Setting cached product context: machine assigned for product: 18555481990E8AB4CBB63FB4F26006C0
MSI (s) (70:D8) [06:50:50:153]: Using cached product context: machine assigned for product: 18555481990E8AB4CBB63FB4F26006C0
MSI (s) (70:D8) [06:50:50:153]: Setting cached product context: machine assigned for product: 190FA771458751643872CA57816F7228
MSI (s) (70:D8) [06:50:50:154]: Using cached product context: machine assigned for product: 190FA771458751643872CA57816F7228
MSI (s) (70:D8) [06:50:50:154]: Setting cached product context: machine assigned for product: 1A4908760526B674A9FF34674EF831C5
MSI (s) (70:D8) [06:50:50:154]: Using cached product context: machine assigned for product: 1A4908760526B674A9FF34674EF831C5
MSI (s) (70:D8) [06:50:50:154]: Setting cached product context: machine assigned for product: 1af2a8da7e60d0b429d7e6453b3d0182
MSI (s) (70:D8) [06:50:50:154]: Using cached product context: machine assigned for product: 1af2a8da7e60d0b429d7e6453b3d0182
MSI (s) (70:D8) [06:50:50:154]: Setting cached product context: machine assigned for product: 1C955A13D4E9B324D93D436A5C937825
MSI (s) (70:D8) [06:50:50:154]: Using cached product context: machine assigned for product: 1C955A13D4E9B324D93D436A5C937825
MSI (s) (70:D8) [06:50:50:154]: Setting cached product context: machine assigned for product: 1CB9255CFB2C8E446BA21019D30780C1
MSI (s) (70:D8) [06:50:50:154]: Using cached product context: machine assigned for product: 1CB9255CFB2C8E446BA21019D30780C1
MSI (s) (70:D8) [06:50:50:155]: Setting cached product context: machine assigned for product: 1D034B0FAA6BD374B960AAD30DF10D8B
MSI (s) (70:D8) [06:50:50:155]: Using cached product context: machine assigned for product: 1D034B0FAA6BD374B960AAD30DF10D8B
MSI (s) (70:D8) [06:50:50:155]: Setting cached product context: machine assigned for product: 1F764691F11C67F458B88521DA8CB349
MSI (s) (70:D8) [06:50:50:155]: Using cached product context: machine assigned for product: 1F764691F11C67F458B88521DA8CB349
MSI (s) (70:D8) [06:50:50:155]: Setting cached product context: machine assigned for product: 2246F5BCE205C7743BD152CE8E8F926E
MSI (s) (70:D8) [06:50:50:155]: Using cached product context: machine assigned for product: 2246F5BCE205C7743BD152CE8E8F926E
MSI (s) (70:D8) [06:50:50:155]: Setting cached product context: machine assigned for product: 26CEF00243C306D4C98ECE73E2100CF8
MSI (s) (70:D8) [06:50:50:155]: Using cached product context: machine assigned for product: 26CEF00243C306D4C98ECE73E2100CF8
MSI (s) (70:D8) [06:50:50:155]: Setting cached product context: machine assigned for product: 2A7527EE2A93F2D4D9CA9F2FB5A81E8D
MSI (s) (70:D8) [06:50:50:156]: Using cached product context: machine assigned for product: 2A7527EE2A93F2D4D9CA9F2FB5A81E8D
MSI (s) (70:D8) [06:50:50:156]: Setting cached product context: machine assigned for product: 2B0163E6D0340BE4183EB2758E9BEDD8
MSI (s) (70:D8) [06:50:50:156]: Using cached product context: machine assigned for product: 2B0163E6D0340BE4183EB2758E9BEDD8
MSI (s) (70:D8) [06:50:50:156]: Setting cached product context: machine assigned for product: 2D81F1C57B6F24248B305B7A688481D5
MSI (s) (70:D8) [06:50:50:156]: Using cached product context: machine assigned for product: 2D81F1C57B6F24248B305B7A688481D5
MSI (s) (70:D8) [06:50:50:156]: Setting cached product context: machine assigned for product: 31A9CC5F75C68494578AA3C2293A81B3
MSI (s) (70:D8) [06:50:50:156]: Using cached product context: machine assigned for product: 31A9CC5F75C68494578AA3C2293A81B3
MSI (s) (70:D8) [06:50:50:157]: Setting cached product context: machine assigned for product: 39930B001A5F1B74C945CEF8DBDD1EE7
MSI (s) (70:D8) [06:50:50:157]: Using cached product context: machine assigned for product: 39930B001A5F1B74C945CEF8DBDD1EE7
MSI (s) (70:D8) [06:50:50:157]: Setting cached product context: machine assigned for product: 3A965F1674614F6B808C040A11388172
MSI (s) (70:D8) [06:50:50:157]: Using cached product context: machine assigned for product: 3A965F1674614F6B808C040A11388172
MSI (s) (70:D8) [06:50:50:157]: Setting cached product context: machine assigned for product: 3D04254D3B6B9FF42B3445CE3E1E0066
MSI (s) (70:D8) [06:50:50:157]: Using cached product context: machine assigned for product: 3D04254D3B6B9FF42B3445CE3E1E0066
MSI (s) (70:D8) [06:50:50:158]: Setting cached product context: machine assigned for product: 3F450F3170B051D4E9085CB594A65B75
MSI (s) (70:D8) [06:50:50:158]: Using cached product context: machine assigned for product: 3F450F3170B051D4E9085CB594A65B75
MSI (s) (70:D8) [06:50:50:158]: Setting cached product context: machine assigned for product: 4314AE291D01A814191EA5403531A183
MSI (s) (70:D8) [06:50:50:158]: Using cached product context: machine assigned for product: 4314AE291D01A814191EA5403531A183
MSI (s) (70:D8) [06:50:50:158]: Setting cached product context: machine assigned for product: 46A934DE810F4DD4B85A23D858BA90BA
MSI (s) (70:D8) [06:50:50:158]: Using cached product context: machine assigned for product: 46A934DE810F4DD4B85A23D858BA90BA
MSI (s) (70:D8) [06:50:50:159]: Setting cached product context: machine assigned for product: 46B5A9879DD95AB419A50FCFA0B1B7EF
MSI (s) (70:D8) [06:50:50:159]: Using cached product context: machine assigned for product: 46B5A9879DD95AB419A50FCFA0B1B7EF
MSI (s) (70:D8) [06:50:50:159]: Setting cached product context: machine assigned for product: 4A4869755DDD3AC4E98AB77E9D95D34B
MSI (s) (70:D8) [06:50:50:159]: Using cached product context: machine assigned for product: 4A4869755DDD3AC4E98AB77E9D95D34B
MSI (s) (70:D8) [06:50:50:159]: Setting cached product context: machine assigned for product: 4A5F135D6F8103149B4A19976D3E94CF
MSI (s) (70:D8) [06:50:50:159]: Using cached product context: machine assigned for product: 4A5F135D6F8103149B4A19976D3E94CF
MSI (s) (70:D8) [06:50:50:159]: Setting cached product context: machine assigned for product: 4A9D4F432C248434EB4F5E358C54947E
MSI (s) (70:D8) [06:50:50:159]: Using cached product context: machine assigned for product: 4A9D4F432C248434EB4F5E358C54947E
MSI (s) (70:D8) [06:50:50:159]: Setting cached product context: machine assigned for product: 4C013CB4898B2E645BBF8BA503AA1724
MSI (s) (70:D8) [06:50:50:159]: Using cached product context: machine assigned for product: 4C013CB4898B2E645BBF8BA503AA1724
MSI (s) (70:D8) [06:50:50:160]: Setting cached product context: machine assigned for product: 4C0F36A7B2B6C496DE270D766021CB92
MSI (s) (70:D8) [06:50:50:160]: Using cached product context: machine assigned for product: 4C0F36A7B2B6C496DE270D766021CB92
MSI (s) (70:D8) [06:50:50:160]: Setting cached product context: machine assigned for product: 4ccf9caae9dddda409c15b94a670bae2
MSI (s) (70:D8) [06:50:50:160]: Using cached product context: machine assigned for product: 4ccf9caae9dddda409c15b94a670bae2
MSI (s) (70:D8) [06:50:50:160]: Setting cached product context: machine assigned for product: 4E42866C3BBC1584BBF38EFC6D539032
MSI (s) (70:D8) [06:50:50:160]: Using cached product context: machine assigned for product: 4E42866C3BBC1584BBF38EFC6D539032
MSI (s) (70:D8) [06:50:50:160]: Setting cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120613FF
MSI (s) (70:D8) [06:50:50:160]: Using cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120613FF
MSI (s) (70:D8) [06:50:50:160]: Setting cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120770FF
MSI (s) (70:D8) [06:50:50:161]: Using cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120770FF
MSI (s) (70:D8) [06:50:50:161]: Setting cached product context: machine assigned for product: 4EA42A62D9304AC4784BF268140602FF
MSI (s) (70:D8) [06:50:50:161]: Using cached product context: machine assigned for product: 4EA42A62D9304AC4784BF268140602FF
MSI (s) (70:D8) [06:50:50:161]: Setting cached product context: machine assigned for product: 5054FF8D77956114D84EA27F71E407CA
MSI (s) (70:D8) [06:50:50:161]: Using cached product context: machine assigned for product: 5054FF8D77956114D84EA27F71E407CA
MSI (s) (70:D8) [06:50:50:161]: Setting cached product context: machine assigned for product: 52744B0D6663D294EB6F85A741DBB99D
MSI (s) (70:D8) [06:50:50:161]: Using cached product context: machine assigned for product: 52744B0D6663D294EB6F85A741DBB99D
MSI (s) (70:D8) [06:50:50:161]: Setting cached product context: machine assigned for product: 5315E951AEB47B25C8CD28F3E16D8D5A
MSI (s) (70:D8) [06:50:50:161]: Using cached product context: machine assigned for product: 5315E951AEB47B25C8CD28F3E16D8D5A
MSI (s) (70:D8) [06:50:50:161]: Setting cached product context: machine assigned for product: 547FD6E4E99CF909CB0F7B2CA4155EE6
MSI (s) (70:D8) [06:50:50:162]: Using cached product context: machine assigned for product: 547FD6E4E99CF909CB0F7B2CA4155EE6
MSI (s) (70:D8) [06:50:50:162]: Setting cached product context: machine assigned for product: 54B52D44E0C5781276932EAFE0A8EFD1
MSI (s) (70:D8) [06:50:50:162]: Using cached product context: machine assigned for product: 54B52D44E0C5781276932EAFE0A8EFD1
MSI (s) (70:D8) [06:50:50:162]: Setting cached product context: machine assigned for product: 592CED6D0A88AFC5B0928CDF0F19FF3D
MSI (s) (70:D8) [06:50:50:162]: Using cached product context: machine assigned for product: 592CED6D0A88AFC5B0928CDF0F19FF3D
MSI (s) (70:D8) [06:50:50:162]: Setting cached product context: machine assigned for product: 59AFD9586A4EDC848BE83A4E388EB944
MSI (s) (70:D8) [06:50:50:162]: Using cached product context: machine assigned for product: 59AFD9586A4EDC848BE83A4E388EB944
MSI (s) (70:D8) [06:50:50:162]: Setting cached product context: machine assigned for product: 59D0F562388A261740857B08586B6B39
MSI (s) (70:D8) [06:50:50:162]: Using cached product context: machine assigned for product: 59D0F562388A261740857B08586B6B39
MSI (s) (70:D8) [06:50:50:163]: Setting cached product context: machine assigned for product: 5D06B511BDBBE094FAE260D4733AEC10
MSI (s) (70:D8) [06:50:50:163]: Using cached product context: machine assigned for product: 5D06B511BDBBE094FAE260D4733AEC10
MSI (s) (70:D8) [06:50:50:163]: Setting cached product context: machine assigned for product: 5ED62A6B5B2F85D45907F47C060EF0DC
MSI (s) (70:D8) [06:50:50:163]: Using cached product context: machine assigned for product: 5ED62A6B5B2F85D45907F47C060EF0DC
MSI (s) (70:D8) [06:50:50:163]: Setting cached product context: machine assigned for product: 60EA627A3AAA1D34783E075F0113F440
MSI (s) (70:D8) [06:50:50:163]: Using cached product context: machine assigned for product: 60EA627A3AAA1D34783E075F0113F440
MSI (s) (70:D8) [06:50:50:164]: Setting cached product context: machine assigned for product: 64059B1FAD9ECEFC248A8C226464AA23
MSI (s) (70:D8) [06:50:50:164]: Using cached product context: machine assigned for product: 64059B1FAD9ECEFC248A8C226464AA23
MSI (s) (70:D8) [06:50:50:164]: Setting cached product context: machine assigned for product: 647AD9B41EA50AB40978DB1B26428209
MSI (s) (70:D8) [06:50:50:164]: Using cached product context: machine assigned for product: 647AD9B41EA50AB40978DB1B26428209
MSI (s) (70:D8) [06:50:50:164]: Setting cached product context: machine assigned for product: 676C6FEA2A7D7844DBB4B1DE712B925B
MSI (s) (70:D8) [06:50:50:164]: Using cached product context: machine assigned for product: 676C6FEA2A7D7844DBB4B1DE712B925B
MSI (s) (70:D8) [06:50:50:165]: Setting cached product context: machine assigned for product: 67D6ECF5CD5FBA732B8B22BAC8DE1B4D
MSI (s) (70:D8) [06:50:50:165]: Using cached product context: machine assigned for product: 67D6ECF5CD5FBA732B8B22BAC8DE1B4D
MSI (s) (70:D8) [06:50:50:165]: Setting cached product context: machine assigned for product: 68AB67CA7DA73301B744AA0100000010
MSI (s) (70:D8) [06:50:50:165]: Using cached product context: machine assigned for product: 68AB67CA7DA73301B744AA0100000010
MSI (s) (70:D8) [06:50:50:165]: Setting cached product context: machine assigned for product: 6A469D3AA1147184D985C58B08F894E4
MSI (s) (70:D8) [06:50:50:165]: Using cached product context: machine assigned for product: 6A469D3AA1147184D985C58B08F894E4
MSI (s) (70:D8) [06:50:50:166]: Setting cached product context: machine assigned for product: 6A47CE31707462D49B9B1E3704F3B380
MSI (s) (70:D8) [06:50:50:166]: Using cached product context: machine assigned for product: 6A47CE31707462D49B9B1E3704F3B380
MSI (s) (70:D8) [06:50:50:166]: Setting cached product context: machine assigned for product: 6D02C9913D0101243B16740602F965EA
MSI (s) (70:D8) [06:50:50:166]: Using cached product context: machine assigned for product: 6D02C9913D0101243B16740602F965EA
MSI (s) (70:D8) [06:50:50:166]: Setting cached product context: machine assigned for product: 6E58EC68CABDDFF39B774E7BF9389C90
MSI (s) (70:D8) [06:50:50:167]: Using cached product context: machine assigned for product: 6E58EC68CABDDFF39B774E7BF9389C90
MSI (s) (70:D8) [06:50:50:167]: Setting cached product context: machine assigned for product: 6E815EB96CCE9A53884E7857C57002F0
MSI (s) (70:D8) [06:50:50:167]: Using cached product context: machine assigned for product: 6E815EB96CCE9A53884E7857C57002F0
MSI (s) (70:D8) [06:50:50:167]: Setting cached product context: machine assigned for product: 6F171E2C85B91EC4B7B86BF90AE4AB8B
MSI (s) (70:D8) [06:50:50:167]: Using cached product context: machine assigned for product: 6F171E2C85B91EC4B7B86BF90AE4AB8B
MSI (s) (70:D8) [06:50:50:167]: Setting cached product context: machine assigned for product: 703563AF369161D4DB4411C3F830A7DA
MSI (s) (70:D8) [06:50:50:168]: Using cached product context: machine assigned for product: 703563AF369161D4DB4411C3F830A7DA
MSI (s) (70:D8) [06:50:50:168]: Setting cached product context: machine assigned for product: 70F3D331855DEC64088E4F7DD5BBDA36
MSI (s) (70:D8) [06:50:50:168]: Using cached product context: machine assigned for product: 70F3D331855DEC64088E4F7DD5BBDA36
MSI (s) (70:D8) [06:50:50:168]: Setting cached product context: machine assigned for product: 71963502FD2E9D544BF1A90CACFF4EA8
MSI (s) (70:D8) [06:50:50:168]: Using cached product context: machine assigned for product: 71963502FD2E9D544BF1A90CACFF4EA8
MSI (s) (70:D8) [06:50:50:169]: Setting cached product context: machine assigned for product: 71ECED675FCB04698245C30A9438A404
MSI (s) (70:D8) [06:50:50:169]: Using cached product context: machine assigned for product: 71ECED675FCB04698245C30A9438A404
MSI (s) (70:D8) [06:50:50:169]: Setting cached product context: machine assigned for product: 734EF03F54E0904D6F92D56869A05619
MSI (s) (70:D8) [06:50:50:169]: Using cached product context: machine assigned for product: 734EF03F54E0904D6F92D56869A05619
MSI (s) (70:D8) [06:50:50:169]: Setting cached product context: machine assigned for product: 766F6333940964D4896BC447E3BE5C1B
MSI (s) (70:D8) [06:50:50:169]: Using cached product context: machine assigned for product: 766F6333940964D4896BC447E3BE5C1B
MSI (s) (70:D8) [06:50:50:170]: Setting cached product context: machine assigned for product: 775F634D5961F2D4B844CA679CE90020
MSI (s) (70:D8) [06:50:50:170]: Using cached product context: machine assigned for product: 775F634D5961F2D4B844CA679CE90020
MSI (s) (70:D8) [06:50:50:170]: Setting cached product context: machine assigned for product: 77AE5BD341A49CE4B8CF37CB48B8ED37
MSI (s) (70:D8) [06:50:50:170]: Using cached product context: machine assigned for product: 77AE5BD341A49CE4B8CF37CB48B8ED37
MSI (s) (70:D8) [06:50:50:170]: Setting cached product context: machine assigned for product: 7B292C385A83B0447A137070E0186AF4
MSI (s) (70:D8) [06:50:50:170]: Using cached product context: machine assigned for product: 7B292C385A83B0447A137070E0186AF4
MSI (s) (70:D8) [06:50:50:171]: Setting cached product context: machine assigned for product: 7BD4C90EC03660F46A13E87A329932FA
MSI (s) (70:D8) [06:50:50:171]: Using cached product context: machine assigned for product: 7BD4C90EC03660F46A13E87A329932FA
MSI (s) (70:D8) [06:50:50:171]: Setting cached product context: machine assigned for product: 7E0BA6F1DDC839B4A832AAE92BEFCF4E
MSI (s) (70:D8) [06:50:50:171]: Using cached product context: machine assigned for product: 7E0BA6F1DDC839B4A832AAE92BEFCF4E
MSI (s) (70:D8) [06:50:50:171]: Setting cached product context: machine assigned for product: 7F80AB91827CC964A853FBDB6333EB80
MSI (s) (70:D8) [06:50:50:171]: Using cached product context: machine assigned for product: 7F80AB91827CC964A853FBDB6333EB80
MSI (s) (70:D8) [06:50:50:172]: Setting cached product context: machine assigned for product: 7FE52D11CF5885B428878495938C36F7
MSI (s) (70:D8) [06:50:50:172]: Using cached product context: machine assigned for product: 7FE52D11CF5885B428878495938C36F7
MSI (s) (70:D8) [06:50:50:172]: Setting cached product context: machine assigned for product: 80D32D2DE01D6D3488C3870E2BCAC96C
MSI (s) (70:D8) [06:50:50:172]: Using cached product context: machine assigned for product: 80D32D2DE01D6D3488C3870E2BCAC96C
MSI (s) (70:D8) [06:50:50:172]: Setting cached product context: machine assigned for product: 82D6625F2B0E0314FB5CEE51A55D41CD
MSI (s) (70:D8) [06:50:50:172]: Using cached product context: machine assigned for product: 82D6625F2B0E0314FB5CEE51A55D41CD
MSI (s) (70:D8) [06:50:50:173]: Setting cached product context: machine assigned for product: 84b9c17023c712640acaf308593282f8
MSI (s) (70:D8) [06:50:50:173]: Using cached product context: machine assigned for product: 84b9c17023c712640acaf308593282f8
MSI (s) (70:D8) [06:50:50:173]: Setting cached product context: machine assigned for product: 875BCCE3E405A7F48A4BFCF4B339B944
MSI (s) (70:D8) [06:50:50:173]: Using cached product context: machine assigned for product: 875BCCE3E405A7F48A4BFCF4B339B944
MSI (s) (70:D8) [06:50:50:173]: Setting cached product context: machine assigned for product: 8E30DAA956F42ED4F8C6B170C9C05812
MSI (s) (70:D8) [06:50:50:173]: Using cached product context: machine assigned for product: 8E30DAA956F42ED4F8C6B170C9C05812
MSI (s) (70:D8) [06:50:50:174]: Setting cached product context: machine assigned for product: 928D954C0FF0012C2BFB38BD36CFD116
MSI (s) (70:D8) [06:50:50:174]: Using cached product context: machine assigned for product: 928D954C0FF0012C2BFB38BD36CFD116
MSI (s) (70:D8) [06:50:50:174]: Setting cached product context: machine assigned for product: 9322D015E2C6B754590984E55C259DD4
MSI (s) (70:D8) [06:50:50:174]: Using cached product context: machine assigned for product: 9322D015E2C6B754590984E55C259DD4
MSI (s) (70:D8) [06:50:50:174]: Setting cached product context: machine assigned for product: 934DF9520B3163100D0AAF98BB5038D1
MSI (s) (70:D8) [06:50:50:174]: Using cached product context: machine assigned for product: 934DF9520B3163100D0AAF98BB5038D1
MSI (s) (70:D8) [06:50:50:175]: Setting cached product context: machine assigned for product: 93BAD29AC2E44034A96BCB446EB8552E
MSI (s) (70:D8) [06:50:50:175]: Using cached product context: machine assigned for product: 93BAD29AC2E44034A96BCB446EB8552E
MSI (s) (70:D8) [06:50:50:175]: Setting cached product context: machine assigned for product: 97B0E634BFC2F5E439081EC7B1520D5C
MSI (s) (70:D8) [06:50:50:175]: Using cached product context: machine assigned for product: 97B0E634BFC2F5E439081EC7B1520D5C
MSI (s) (70:D8) [06:50:50:175]: Setting cached product context: machine assigned for product: 9A4666D624338494B9E730E4EF63F6F0
MSI (s) (70:D8) [06:50:50:176]: Using cached product context: machine assigned for product: 9A4666D624338494B9E730E4EF63F6F0
MSI (s) (70:D8) [06:50:50:176]: Setting cached product context: machine assigned for product: 9FC8002245B22204FA8DB3D7248CE9B6
MSI (s) (70:D8) [06:50:50:176]: Using cached product context: machine assigned for product: 9FC8002245B22204FA8DB3D7248CE9B6
MSI (s) (70:D8) [06:50:50:176]: Setting cached product context: machine assigned for product: A57765D93F393A44082948E08362ED03
MSI (s) (70:D8) [06:50:50:176]: Using cached product context: machine assigned for product: A57765D93F393A44082948E08362ED03
MSI (s) (70:D8) [06:50:50:177]: Setting cached product context: machine assigned for product: A6C64DD86500CEF47BA082BB611A1FF1
MSI (s) (70:D8) [06:50:50:177]: Using cached product context: machine assigned for product: A6C64DD86500CEF47BA082BB611A1FF1
MSI (s) (70:D8) [06:50:50:177]: Setting cached product context: machine assigned for product: A7E111539B30CE524F431ADC799670CF
MSI (s) (70:D8) [06:50:50:177]: Using cached product context: machine assigned for product: A7E111539B30CE524F431ADC799670CF
MSI (s) (70:D8) [06:50:50:177]: Setting cached product context: machine assigned for product: ADDC9F256F629944090ED6DD6E2D52C9
MSI (s) (70:D8) [06:50:50:177]: Using cached product context: machine assigned for product: ADDC9F256F629944090ED6DD6E2D52C9
MSI (s) (70:D8) [06:50:50:178]: Setting cached product context: machine assigned for product: AFAD45F1162926A45BD9C6F9624BF84E
MSI (s) (70:D8) [06:50:50:178]: Using cached product context: machine assigned for product: AFAD45F1162926A45BD9C6F9624BF84E
MSI (s) (70:D8) [06:50:50:178]: Setting cached product context: machine assigned for product: B09563757C631884E5EB9F3B090F7047
MSI (s) (70:D8) [06:50:50:178]: Using cached product context: machine assigned for product: B09563757C631884E5EB9F3B090F7047
MSI (s) (70:D8) [06:50:50:178]: Setting cached product context: machine assigned for product: B0C43BE845FA562F48C4E3F69AEAF2DC
MSI (s) (70:D8) [06:50:50:178]: Using cached product context: machine assigned for product: B0C43BE845FA562F48C4E3F69AEAF2DC
MSI (s) (70:D8) [06:50:50:179]: Setting cached product context: machine assigned for product: b25099274a207264182f8181add555d0
MSI (s) (70:D8) [06:50:50:179]: Using cached product context: machine assigned for product: b25099274a207264182f8181add555d0
MSI (s) (70:D8) [06:50:50:179]: Setting cached product context: machine assigned for product: B402F3A6C32323E78F097A03788627D8
MSI (s) (70:D8) [06:50:50:179]: Using cached product context: machine assigned for product: B402F3A6C32323E78F097A03788627D8
MSI (s) (70:D8) [06:50:50:179]: Setting cached product context: machine assigned for product: B6ACDB9A3563B764CA384963D73AFB3E
MSI (s) (70:D8) [06:50:50:179]: Using cached product context: machine assigned for product: B6ACDB9A3563B764CA384963D73AFB3E
MSI (s) (70:D8) [06:50:50:180]: Setting cached product context: machine assigned for product: B7573E6B77E5519368A6CCCFB4D891C4
MSI (s) (70:D8) [06:50:50:180]: Using cached product context: machine assigned for product: B7573E6B77E5519368A6CCCFB4D891C4
MSI (s) (70:D8) [06:50:50:180]: Setting cached product context: machine assigned for product: BA67B20212B1E4342A9887D867D7A3C7
MSI (s) (70:D8) [06:50:50:180]: Using cached product context: machine assigned for product: BA67B20212B1E4342A9887D867D7A3C7
MSI (s) (70:D8) [06:50:50:180]: Setting cached product context: machine assigned for product: BAF5E720674195C4AA4B23FE82253099
MSI (s) (70:D8) [06:50:50:180]: Using cached product context: machine assigned for product: BAF5E720674195C4AA4B23FE82253099
MSI (s) (70:D8) [06:50:50:181]: Setting cached product context: machine assigned for product: BBC7B38C637C64FB8923A7D9709E9DC4
MSI (s) (70:D8) [06:50:50:181]: Using cached product context: machine assigned for product: BBC7B38C637C64FB8923A7D9709E9DC4
MSI (s) (70:D8) [06:50:50:181]: Setting cached product context: machine assigned for product: BD5868FDE422AA74997BF7DCF7213F86
MSI (s) (70:D8) [06:50:50:181]: Using cached product context: machine assigned for product: BD5868FDE422AA74997BF7DCF7213F86
MSI (s) (70:D8) [06:50:50:181]: Setting cached product context: machine assigned for product: BFF8CCA148D950C44AED2DA8B99C6189
MSI (s) (70:D8) [06:50:50:181]: Using cached product context: machine assigned for product: BFF8CCA148D950C44AED2DA8B99C6189
MSI (s) (70:D8) [06:50:50:181]: Setting cached product context: machine assigned for product: C14037C917BAD599EE7C4B9E049FF363
MSI (s) (70:D8) [06:50:50:181]: Using cached product context: machine assigned for product: C14037C917BAD599EE7C4B9E049FF363
MSI (s) (70:D8) [06:50:50:182]: Setting cached product context: machine assigned for product: c1c4f01781cc94c4c8fb1542c0981a2a
MSI (s) (70:D8) [06:50:50:182]: Using cached product context: machine assigned for product: c1c4f01781cc94c4c8fb1542c0981a2a
MSI (s) (70:D8) [06:50:50:182]: Setting cached product context: machine assigned for product: C1E16264D0E5E484C8CCF7773057BF2A
MSI (s) (70:D8) [06:50:50:182]: Using cached product context: machine assigned for product: C1E16264D0E5E484C8CCF7773057BF2A
MSI (s) (70:D8) [06:50:50:182]: Setting cached product context: machine assigned for product: C2AB8AF6B25027048B2E32202C86EBE9
MSI (s) (70:D8) [06:50:50:182]: Using cached product context: machine assigned for product: C2AB8AF6B25027048B2E32202C86EBE9
MSI (s) (70:D8) [06:50:50:182]: Setting cached product context: machine assigned for product: C42CF3A20CE691545AB2DF4AAEB9D242
MSI (s) (70:D8) [06:50:50:182]: Using cached product context: machine assigned for product: C42CF3A20CE691545AB2DF4AAEB9D242
MSI (s) (70:D8) [06:50:50:182]: Setting cached product context: machine assigned for product: C43F149BA63FF6A49AC7055B49E854F1
MSI (s) (70:D8) [06:50:50:182]: Using cached product context: machine assigned for product: C43F149BA63FF6A49AC7055B49E854F1
MSI (s) (70:D8) [06:50:50:183]: Setting cached product context: machine assigned for product: C5F1DFA5ADF8C314FA831F7EDB017DF2
MSI (s) (70:D8) [06:50:50:183]: Using cached product context: machine assigned for product: C5F1DFA5ADF8C314FA831F7EDB017DF2
MSI (s) (70:D8) [06:50:50:183]: Setting cached product context: machine assigned for product: C6C6B4370474F674BBC07FFA64E9BD2B
MSI (s) (70:D8) [06:50:50:183]: Using cached product context: machine assigned for product: C6C6B4370474F674BBC07FFA64E9BD2B
MSI (s) (70:D8) [06:50:50:183]: Setting cached product context: machine assigned for product: C953167FDEC9EA54A915D96650DC554C
MSI (s) (70:D8) [06:50:50:183]: Using cached product context: machine assigned for product: C953167FDEC9EA54A915D96650DC554C
MSI (s) (70:D8) [06:50:50:184]: Setting cached product context: machine assigned for product: CC133055B43CF494CBAD73ECE46F9E42
MSI (s) (70:D8) [06:50:50:184]: Using cached product context: machine assigned for product: CC133055B43CF494CBAD73ECE46F9E42
MSI (s) (70:D8) [06:50:50:184]: Setting cached product context: machine assigned for product: CC3CDDBEA343DD0C97ABA8210D2AAC01
MSI (s) (70:D8) [06:50:50:184]: Using cached product context: machine assigned for product: CC3CDDBEA343DD0C97ABA8210D2AAC01
MSI (s) (70:D8) [06:50:50:184]: Setting cached product context: machine assigned for product: CF454FAAAC2892F4BA13A60149587EE6
MSI (s) (70:D8) [06:50:50:184]: Using cached product context: machine assigned for product: CF454FAAAC2892F4BA13A60149587EE6
MSI (s) (70:D8) [06:50:50:184]: Setting cached product context: machine assigned for product: CFD2C1F142D260E3CB8B271543DA9F98
MSI (s) (70:D8) [06:50:50:184]: Using cached product context: machine assigned for product: CFD2C1F142D260E3CB8B271543DA9F98
MSI (s) (70:D8) [06:50:50:185]: Setting cached product context: machine assigned for product: D1DD8E7FDFB9BB83685AEB3F310BC015
MSI (s) (70:D8) [06:50:50:185]: Using cached product context: machine assigned for product: D1DD8E7FDFB9BB83685AEB3F310BC015
MSI (s) (70:D8) [06:50:50:185]: Setting cached product context: machine assigned for product: D4B9F933BC00C1C4EB8DCE689ABA06A2
MSI (s) (70:D8) [06:50:50:185]: Using cached product context: machine assigned for product: D4B9F933BC00C1C4EB8DCE689ABA06A2
MSI (s) (70:D8) [06:50:50:185]: Setting cached product context: machine assigned for product: D7314F9862C648A4DB8BE2A5B47BE100
MSI (s) (70:D8) [06:50:50:185]: Using cached product context: machine assigned for product: D7314F9862C648A4DB8BE2A5B47BE100
MSI (s) (70:D8) [06:50:50:185]: Setting cached product context: machine assigned for product: D7E18DD182D0BEC4782B0C144ACF2B51
MSI (s) (70:D8) [06:50:50:185]: Using cached product context: machine assigned for product: D7E18DD182D0BEC4782B0C144ACF2B51
MSI (s) (70:D8) [06:50:50:185]: Setting cached product context: machine assigned for product: D8EF64479F1C24D4AAEAD5CB5E68506A
MSI (s) (70:D8) [06:50:50:185]: Using cached product context: machine assigned for product: D8EF64479F1C24D4AAEAD5CB5E68506A
MSI (s) (70:D8) [06:50:50:186]: Setting cached product context: machine assigned for product: DBA18E807F972C9488F1DFC60B796539
MSI (s) (70:D8) [06:50:50:186]: Using cached product context: machine assigned for product: DBA18E807F972C9488F1DFC60B796539
MSI (s) (70:D8) [06:50:50:186]: Setting cached product context: machine assigned for product: DF41901B21884A74581A05CFEDF7F133
MSI (s) (70:D8) [06:50:50:186]: Using cached product context: machine assigned for product: DF41901B21884A74581A05CFEDF7F133
MSI (s) (70:D8) [06:50:50:186]: Setting cached product context: machine assigned for product: DFC90B5F2B0FFA63D84FD16F6BF37C4B
MSI (s) (70:D8) [06:50:50:186]: Using cached product context: machine assigned for product: DFC90B5F2B0FFA63D84FD16F6BF37C4B
MSI (s) (70:D8) [06:50:50:186]: Setting cached product context: machine assigned for product: E08F45ADC1622A148A5545A941F4F295
MSI (s) (70:D8) [06:50:50:186]: Using cached product context: machine assigned for product: E08F45ADC1622A148A5545A941F4F295
MSI (s) (70:D8) [06:50:50:186]: Setting cached product context: machine assigned for product: E4A35D8A1A77E32E3A69D6C9682A2F37
MSI (s) (70:D8) [06:50:50:186]: Using cached product context: machine assigned for product: E4A35D8A1A77E32E3A69D6C9682A2F37
MSI (s) (70:D8) [06:50:50:187]: Setting cached product context: machine assigned for product: E6C73FFB537D784493C072E130A06AC2
MSI (s) (70:D8) [06:50:50:187]: Using cached product context: machine assigned for product: E6C73FFB537D784493C072E130A06AC2
MSI (s) (70:D8) [06:50:50:187]: Setting cached product context: machine assigned for product: E8957B708BF159A1A7035F435A75624B
MSI (s) (70:D8) [06:50:50:187]: Using cached product context: machine assigned for product: E8957B708BF159A1A7035F435A75624B
MSI (s) (70:D8) [06:50:50:187]: Setting cached product context: machine assigned for product: E97A59ECCF4EFFF4A857920FB449F22F
MSI (s) (70:D8) [06:50:50:187]: Using cached product context: machine assigned for product: E97A59ECCF4EFFF4A857920FB449F22F
MSI (s) (70:D8) [06:50:50:187]: Setting cached product context: machine assigned for product: EA2B394116202D741BAA4FAD0D6F4CB8
MSI (s) (70:D8) [06:50:50:187]: Using cached product context: machine assigned for product: EA2B394116202D741BAA4FAD0D6F4CB8
MSI (s) (70:D8) [06:50:50:187]: Setting cached product context: machine assigned for product: EB36D9F2198A93E4FA3B47204D6808C0
MSI (s) (70:D8) [06:50:50:187]: Using cached product context: machine assigned for product: EB36D9F2198A93E4FA3B47204D6808C0
MSI (s) (70:D8) [06:50:50:188]: Setting cached product context: machine assigned for product: EEDB8CDDCACDD4042875E3D8B4874276
MSI (s) (70:D8) [06:50:50:188]: Using cached product context: machine assigned for product: EEDB8CDDCACDD4042875E3D8B4874276
MSI (s) (70:D8) [06:50:50:188]: Setting cached product context: machine assigned for product: EFEE0228DC83E77358593193D847A0EC
MSI (s) (70:D8) [06:50:50:188]: Using cached product context: machine assigned for product: EFEE0228DC83E77358593193D847A0EC
MSI (s) (70:D8) [06:50:50:188]: Setting cached product context: machine assigned for product: F132F0B0A6ECD384AA32773B467F9571
MSI (s) (70:D8) [06:50:50:188]: Using cached product context: machine assigned for product: F132F0B0A6ECD384AA32773B467F9571
MSI (s) (70:D8) [06:50:50:188]: Setting cached product context: machine assigned for product: F26615EF6F8D5B34999D4D98A40FF038
MSI (s) (70:D8) [06:50:50:188]: Using cached product context: machine assigned for product: F26615EF6F8D5B34999D4D98A40FF038
MSI (s) (70:D8) [06:50:50:188]: Setting cached product context: machine assigned for product: F377200735A22F9E1E16BDD3ADF050EB
MSI (s) (70:D8) [06:50:50:189]: Using cached product context: machine assigned for product: F377200735A22F9E1E16BDD3ADF050EB
MSI (s) (70:D8) [06:50:50:189]: Setting cached product context: machine assigned for product: F4E3B286A696ED244AC1C470AE61874B
MSI (s) (70:D8) [06:50:50:189]: Using cached product context: machine assigned for product: F4E3B286A696ED244AC1C470AE61874B
MSI (s) (70:D8) [06:50:50:189]: Setting cached product context: machine assigned for product: F5E89A6B7A6DBF64E9D9F1B74F3494C1
MSI (s) (70:D8) [06:50:50:189]: Using cached product context: machine assigned for product: F5E89A6B7A6DBF64E9D9F1B74F3494C1
MSI (s) (70:D8) [06:50:50:190]: Setting cached product context: machine assigned for product: F6071111A6667304777712318267D401
MSI (s) (70:D8) [06:50:50:190]: Using cached product context: machine assigned for product: F6071111A6667304777712318267D401
MSI (s) (70:D8) [06:50:50:190]: Setting cached product context: machine assigned for product: F60730A4A66673047777F5728467D401
MSI (s) (70:D8) [06:50:50:190]: Using cached product context: machine assigned for product: F60730A4A66673047777F5728467D401
MSI (s) (70:D8) [06:50:50:190]: Setting cached product context: machine assigned for product: F81CA3C7B91F2804D831D70683840EC6
MSI (s) (70:D8) [06:50:50:190]: Using cached product context: machine assigned for product: F81CA3C7B91F2804D831D70683840EC6
MSI (s) (70:D8) [06:50:50:191]: Setting cached product context: machine assigned for product: F92F4A37CA13DBE4AAB1C05C1FC8F838
MSI (s) (70:D8) [06:50:50:191]: Using cached product context: machine assigned for product: F92F4A37CA13DBE4AAB1C05C1FC8F838
MSI (s) (70:D8) [06:50:50:193]: SRSetRestorePoint skipped for this transaction.
MSI (s) (70:D8) [06:50:50:193]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\ Explorer 3: 2
MSI (s) (70:D8) [06:50:50:196]: File will have security applied from OpCode.
MSI (s) (70:D8) [06:50:50:201]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'c:\users\rob\appdata\local\temp\air3d39.tmp\setup.msi' against software restriction policy
MSI (s) (70:D8) [06:50:50:201]: SOFTWARE RESTRICTION POLICY: c:\users\rob\appdata\local\temp\air3d39.tmp\setup.msi has a digital signature
MSI (s) (70:D8) [06:50:50:256]: SOFTWARE RESTRICTION POLICY: c:\users\rob\appdata\local\temp\air3d39.tmp\setup.msi is permitted to run at the 'unrestricted' authorization level.
MSI (s) (70:D8) [06:50:50:256]: End dialog not enabled
MSI (s) (70:D8) [06:50:50:256]: Original package ==> c:\users\rob\appdata\local\temp\air3d39.tmp\setup.msi
MSI (s) (70:D8) [06:50:50:256]: Package we're running from ==> c:\Windows\Installer\51d5cec.msi
MSI (s) (70:D8) [06:50:50:258]: APPCOMPAT: Compatibility mode property overrides found.
MSI (s) (70:D8) [06:50:50:258]: APPCOMPAT: looking for appcompat database entry with ProductCode '{14DC0059-00F1-4F62-BD1A-AB23CD51A95E}'.
MSI (s) (70:D8) [06:50:50:258]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (70:D8) [06:50:50:263]: MSCOREE not loaded loading copy from system32
MSI (s) (70:D8) [06:50:50:268]: Machine policy value 'TransformsSecure' is 0
MSI (s) (70:D8) [06:50:50:268]: User policy value 'TransformsAtSource' is 0
MSI (s) (70:D8) [06:50:50:268]: Machine policy value 'DisablePatch' is 0
MSI (s) (70:D8) [06:50:50:268]: Machine policy value 'AllowLockdownPatch' is 0
MSI (s) (70:D8) [06:50:50:268]: Machine policy value 'DisableLUAPatching' is 0
MSI (s) (70:D8) [06:50:50:268]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (s) (70:D8) [06:50:50:268]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI (s) (70:D8) [06:50:50:269]: APPCOMPAT: looking for appcompat database entry with ProductCode '{14DC0059-00F1-4F62-BD1A-AB23CD51A95E}'.
MSI (s) (70:D8) [06:50:50:269]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (70:D8) [06:50:50:269]: Transforms are not secure.
MSI (s) (70:D8) [06:50:50:269]: Note: 1: 2205 2:  3: Control
MSI (s) (70:D8) [06:50:50:269]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\Rob\AppData\Local\Temp\MSI38408.LOG'.
MSI (s) (70:D8) [06:50:50:269]: Command Line: CURRENTDIRECTORY=C:\Users\Rob\Downloads CLIENTUILEVEL=3 MSICLIENTUSESEXTERNALUI=1 CLIENTPROCESSID=6888
MSI (s) (70:D8) [06:50:50:269]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{0C8F1352-A5B9-4AAD-9E45-612DBB4F5E97}'.
MSI (s) (70:D8) [06:50:50:269]: Product Code passed to Engine.Initialize:           ''
MSI (s) (70:D8) [06:50:50:269]: Product Code from property table before transforms: '{14DC0059-00F1-4F62-BD1A-AB23CD51A95E}'
MSI (s) (70:D8) [06:50:50:269]: Product Code from property table after transforms:  '{14DC0059-00F1-4F62-BD1A-AB23CD51A95E}'
MSI (s) (70:D8) [06:50:50:269]: Product not registered: beginning first-time install
MSI (s) (70:D8) [06:50:50:269]: Product {14DC0059-00F1-4F62-BD1A-AB23CD51A95E} is not managed.
MSI (s) (70:D8) [06:50:50:269]: MSI_LUA: Credential prompt not required, user is an admin
MSI (s) (70:D8) [06:50:50:270]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (s) (70:D8) [06:50:50:270]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (s) (70:D8) [06:50:50:270]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (70:D8) [06:50:50:270]: Adding new sources is allowed.
MSI (s) (70:D8) [06:50:50:270]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (s) (70:D8) [06:50:50:270]: Package name extracted from package path: 'setup.msi'
MSI (s) (70:D8) [06:50:50:270]: Package to be registered: 'setup.msi'
MSI (s) (70:D8) [06:50:50:270]: Note: 1: 2205 2:  3: Error
MSI (s) (70:D8) [06:50:50:271]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (s) (70:D8) [06:50:50:271]: Machine policy value 'DisableMsi' is 0
MSI (s) (70:D8) [06:50:50:272]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (70:D8) [06:50:50:272]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (70:D8) [06:50:50:272]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI (s) (70:D8) [06:50:50:272]: Running product '{14DC0059-00F1-4F62-BD1A-AB23CD51A95E}' with elevated privileges: Product is assigned.
MSI (s) (70:D8) [06:50:50:272]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\Rob\Downloads'.
MSI (s) (70:D8) [06:50:50:272]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '3'.
MSI (s) (70:D8) [06:50:50:272]: PROPERTY CHANGE: Adding MSICLIENTUSESEXTERNALUI property. Its value is '1'.
MSI (s) (70:D8) [06:50:50:272]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '6888'.
MSI (s) (70:D8) [06:50:50:272]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
MSI (s) (70:D8) [06:50:50:273]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is 'a22b50bb9ccf8342a74b096ecaaba87d'.
MSI (s) (70:D8) [06:50:50:273]: RESTART MANAGER: Session opened.
MSI (s) (70:D8) [06:50:50:273]: TRANSFORMS property is now:
MSI (s) (70:D8) [06:50:50:273]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (s) (70:D8) [06:50:50:275]: SHELL32::SHGetFolderPath returned: C:\Users\Rob\AppData\Roaming
MSI (s) (70:D8) [06:50:50:277]: SHELL32::SHGetFolderPath returned: C:\Users\Rob\Favorites
MSI (s) (70:D8) [06:50:50:278]: SHELL32::SHGetFolderPath returned: C:\Users\Rob\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (s) (70:D8) [06:50:50:280]: SHELL32::SHGetFolderPath returned: C:\Users\Rob\Documents
MSI (s) (70:D8) [06:50:50:281]: SHELL32::SHGetFolderPath returned: C:\Users\Rob\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (s) (70:D8) [06:50:50:283]: SHELL32::SHGetFolderPath returned: C:\Users\Rob\AppData\Roaming\Microsoft\Windows\Recent
MSI (s) (70:D8) [06:50:50:285]: SHELL32::SHGetFolderPath returned: C:\Users\Rob\AppData\Roaming\Microsoft\Windows\SendTo
MSI (s) (70:D8) [06:50:50:286]: SHELL32::SHGetFolderPath returned: C:\Users\Rob\AppData\Roaming\Microsoft\Windows\Templates
MSI (s) (70:D8) [06:50:50:286]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (s) (70:D8) [06:50:50:288]: SHELL32::SHGetFolderPath returned: C:\Users\Rob\AppData\Local
MSI (s) (70:D8) [06:50:50:289]: SHELL32::SHGetFolderPath returned: C:\Users\Rob\Pictures
MSI (s) (70:D8) [06:50:50:292]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (70:D8) [06:50:50:294]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (70:D8) [06:50:50:295]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs
MSI (s) (70:D8) [06:50:50:297]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu
MSI (s) (70:D8) [06:50:50:298]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (s) (70:D8) [06:50:50:301]: SHELL32::SHGetFolderPath returned: C:\Users\Rob\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (70:D8) [06:50:50:303]: SHELL32::SHGetFolderPath returned: C:\Users\Rob\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (70:D8) [06:50:50:304]: SHELL32::SHGetFolderPath returned: C:\Users\Rob\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
MSI (s) (70:D8) [06:50:50:306]: SHELL32::SHGetFolderPath returned: C:\Users\Rob\AppData\Roaming\Microsoft\Windows\Start Menu
MSI (s) (70:D8) [06:50:50:308]: SHELL32::SHGetFolderPath returned: C:\Users\Rob\Desktop
MSI (s) (70:D8) [06:50:50:310]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (s) (70:D8) [06:50:50:310]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI (s) (70:D8) [06:50:50:311]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (s) (70:D8) [06:50:50:316]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (s) (70:D8) [06:50:50:316]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (s) (70:D8) [06:50:50:316]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (s) (70:D8) [06:50:50:316]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (s) (70:D8) [06:50:50:316]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Rob'.
MSI (s) (70:D8) [06:50:50:317]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (s) (70:D8) [06:50:50:317]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'c:\Windows\Installer\51d5cec.msi'.
MSI (s) (70:D8) [06:50:50:317]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'c:\users\rob\appdata\local\temp\air3d39.tmp\setup.msi'.
MSI (s) (70:D8) [06:50:50:317]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (s) (70:D8) [06:50:50:317]: EEUI - Disabling MsiEmbeddedUI due to existing external or embedded UI
MSI (s) (70:D8) [06:50:50:317]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic install
MSI (s) (70:D8) [06:50:50:317]: Note: 1: 2205 2:  3: PatchPackage
MSI (s) (70:D8) [06:50:50:317]: Machine policy value 'DisableRollback' is 0
MSI (s) (70:D8) [06:50:50:317]: User policy value 'DisableRollback' is 0
MSI (s) (70:D8) [06:50:50:317]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
=== Logging started: 27/11/2012  06:50:50 ===
MSI (s) (70:D8) [06:50:50:318]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (s) (70:D8) [06:50:50:318]: Doing action: INSTALL
MSI (s) (70:D8) [06:50:50:318]: Note: 1: 2205 2:  3: ActionText
Action start 06:50:50: INSTALL.
MSI (s) (70:D8) [06:50:50:318]: Running ExecuteSequence
MSI (s) (70:D8) [06:50:50:318]: Doing action: FindRelatedProducts
Action start 06:50:50: FindRelatedProducts.
MSI (s) (70:D8) [06:50:50:319]: Doing action: ValidateProductID
MSI (s) (70:D8) [06:50:50:319]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:50: FindRelatedProducts. Return value 1.
Action start 06:50:50: ValidateProductID.
MSI (s) (70:D8) [06:50:50:320]: Doing action: SetSHAREDADDINFOLDER
MSI (s) (70:D8) [06:50:50:320]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:50: ValidateProductID. Return value 1.
MSI (s) (70:D8) [06:50:50:320]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'SetSHAREDADDINFOLDER'
MSI (s) (70:D8) [06:50:50:320]: PROPERTY CHANGE: Modifying SHAREDADDINFOLDER property. Its current value is '(computed)'. Its new value: 'C:\Program Files (x86)\Adobe\Flash Player\AddIns\airappinstaller'.
Action start 06:50:50: SetSHAREDADDINFOLDER.
MSI (s) (70:D8) [06:50:50:321]: Doing action: CostInitialize
MSI (s) (70:D8) [06:50:50:321]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:50: SetSHAREDADDINFOLDER. Return value 1.
MSI (s) (70:D8) [06:50:50:321]: Machine policy value 'MaxPatchCacheSize' is 10
MSI (s) (70:D8) [06:50:50:322]: Baseline: Sorting baselines for {14DC0059-00F1-4F62-BD1A-AB23CD51A95E}.
MSI (s) (70:D8) [06:50:50:322]: Baseline: New baseline 3.5.0 from transaction.
MSI (s) (70:D8) [06:50:50:322]: Baseline: Sorted order Native: Order 0.
MSI (s) (70:D8) [06:50:50:322]: Baseline Data Table:
MSI (s) (70:D8) [06:50:50:322]: ProductCode: {14DC0059-00F1-4F62-BD1A-AB23CD51A95E} Version: 3.5.0 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI (s) (70:D8) [06:50:50:322]: Baseline File Table:
MSI (s) (70:D8) [06:50:50:345]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'c:\'.
MSI (s) (70:D8) [06:50:50:346]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI (s) (70:D8) [06:50:50:346]: Note: 1: 2205 2:  3: Patch
MSI (s) (70:D8) [06:50:50:346]: Note: 1: 2205 2:  3: PatchPackage
MSI (s) (70:D8) [06:50:50:346]: Note: 1: 2205 2:  3: MsiPatchHeaders
MSI (s) (70:D8) [06:50:50:346]: Note: 1: 2205 2:  3: __MsiPatchFileList
MSI (s) (70:D8) [06:50:50:346]: Note: 1: 2228 2:  3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
MSI (s) (70:D8) [06:50:50:346]: Delta compression fallback method for this product transaction is 'MSI 2.0 legacy obsolescence'
Action start 06:50:50: CostInitialize.
MSI (s) (70:D8) [06:50:50:347]: Doing action: FileCost
MSI (s) (70:D8) [06:50:50:347]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:50: CostInitialize. Return value 1.
MSI (s) (70:D8) [06:50:50:348]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (70:D8) [06:50:50:348]: Note: 1: 2205 2:  3: Class
MSI (s) (70:D8) [06:50:50:348]: Note: 1: 2205 2:  3: Extension
MSI (s) (70:D8) [06:50:50:348]: Note: 1: 2205 2:  3: TypeLib
Action start 06:50:50: FileCost.
MSI (s) (70:D8) [06:50:50:348]: Doing action: CostFinalize
MSI (s) (70:D8) [06:50:50:348]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:50: FileCost. Return value 1.
MSI (s) (70:D8) [06:50:50:349]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (s) (70:D8) [06:50:50:349]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (s) (70:D8) [06:50:50:349]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (s) (70:D8) [06:50:50:349]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (s) (70:D8) [06:50:50:349]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (s) (70:D8) [06:50:50:349]: Note: 1: 2205 2:  3: Patch
MSI (s) (70:D8) [06:50:50:349]: Note: 1: 2205 2:  3: Condition
MSI (s) (70:D8) [06:50:50:349]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'c:\'.
MSI (s) (70:D8) [06:50:50:350]: PROPERTY CHANGE: Modifying WindowsFolder property. Its current value is 'C:\Windows\'. Its new value: 'c:\Windows\'.
MSI (s) (70:D8) [06:50:50:366]: PROPERTY CHANGE: Modifying SHAREDADDINFOLDER property. Its current value is 'C:\Program Files (x86)\Adobe\Flash Player\AddIns\airappinstaller'. Its new value: 'c:\Program Files (x86)\Adobe\Flash Player\AddIns\airappinstaller\'.
MSI (s) (70:D8) [06:50:50:366]: PROPERTY CHANGE: Modifying CommonFilesFolder property. Its current value is 'C:\Program Files (x86)\Common Files\'. Its new value: 'c:\Program Files (x86)\Common Files\'.
MSI (s) (70:D8) [06:50:50:366]: PROPERTY CHANGE: Adding AIR property. Its value is 'c:\Program Files (x86)\Common Files\Adobe AIR\'.
MSI (s) (70:D8) [06:50:50:366]: PROPERTY CHANGE: Adding Versions property. Its value is 'c:\Program Files (x86)\Common Files\Adobe AIR\Versions\'.
MSI (s) (70:D8) [06:50:50:366]: PROPERTY CHANGE: Adding Version property. Its value is 'c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\'.
MSI (s) (70:D8) [06:50:50:366]: PROPERTY CHANGE: Adding Resources property. Its value is 'c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\'.
MSI (s) (70:D8) [06:50:50:366]: PROPERTY CHANGE: Adding WebKitLic property. Its value is 'c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\WebKit\'.
MSI (s) (70:D8) [06:50:50:366]: Target path resolution complete. Dumping Directory table...
MSI (s) (70:D8) [06:50:50:366]: Note: target paths subject to change (via custom actions or browsing)
MSI (s) (70:D8) [06:50:50:366]: Dir (target): Key: TARGETDIR          , Object: c:\
MSI (s) (70:D8) [06:50:50:366]: Dir (target): Key: WindowsFolder          , Object: c:\Windows\
MSI (s) (70:D8) [06:50:50:366]: Dir (target): Key: SHAREDADDINFOLDER          , Object: c:\Program Files (x86)\Adobe\Flash Player\AddIns\airappinstaller\
MSI (s) (70:D8) [06:50:50:366]: Dir (target): Key: CommonFilesFolder          , Object: c:\Program Files (x86)\Common Files\
MSI (s) (70:D8) [06:50:50:366]: Dir (target): Key: AIR          , Object: c:\Program Files (x86)\Common Files\Adobe AIR\
MSI (s) (70:D8) [06:50:50:366]: Dir (target): Key: Versions          , Object: c:\Program Files (x86)\Common Files\Adobe AIR\Versions\
MSI (s) (70:D8) [06:50:50:366]: Dir (target): Key: Version          , Object: c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\
MSI (s) (70:D8) [06:50:50:366]: Dir (target): Key: Resources          , Object: c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\
MSI (s) (70:D8) [06:50:50:366]: Dir (target): Key: WebKitLic          , Object: c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\WebKit\
MSI (s) (70:D8) [06:50:50:366]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI (s) (70:D8) [06:50:50:366]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (70:D8) [06:50:50:366]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
Action start 06:50:50: CostFinalize.
MSI (s) (70:D8) [06:50:50:709]: Doing action: MigrateFeatureStates
MSI (s) (70:D8) [06:50:50:709]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:50: CostFinalize. Return value 1.
Action start 06:50:50: MigrateFeatureStates.
MSI (s) (70:D8) [06:50:50:710]: Doing action: InstallValidate
MSI (s) (70:D8) [06:50:50:710]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:50: MigrateFeatureStates. Return value 0.
MSI (s) (70:D8) [06:50:50:711]: PROPERTY CHANGE: Deleting MsiRestartManagerSessionKey property. Its current value is 'a22b50bb9ccf8342a74b096ecaaba87d'.
MSI (s) (70:D8) [06:50:50:711]: Note: 1: 2205 2:  3: Dialog
MSI (s) (70:D8) [06:50:50:711]: Feature: Runtime; Installed: Absent;   Request: Local;   Action: Local
MSI (s) (70:D8) [06:50:50:711]: Feature: Management; Installed: Absent;   Request: Local;   Action: Local
MSI (s) (70:D8) [06:50:50:711]: Component: Runtime; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (70:D8) [06:50:50:711]: Component: FileTypeRegistration; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (70:D8) [06:50:50:711]: Component: ARPRegistration; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (70:D8) [06:50:50:711]: Component: template.msi; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (70:D8) [06:50:50:711]: Component: template.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (70:D8) [06:50:50:711]: Component: Sentinel; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (70:D8) [06:50:50:711]: Component: AppInstaller; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (70:D8) [06:50:50:711]: Component: WebKit; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (70:D8) [06:50:50:711]: Component: WebKitLicenses; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (70:D8) [06:50:50:711]: Component: FlashPlugin; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (70:D8) [06:50:50:711]: Component: Setup; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (70:D8) [06:50:50:711]: Component: RootCertificate; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (70:D8) [06:50:50:711]: Component: TimestampingRootCertificate; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (70:D8) [06:50:50:711]: Component: AIRAppInstaller; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (70:D8) [06:50:50:711]: Component: DRMADOBECPVoucher; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI (s) (70:D8) [06:50:50:711]: Component: DRM; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI (s) (70:D8) [06:50:50:711]: Component: DRM15; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (70:D8) [06:50:50:711]: Component: DRMAIRVoucher; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI (s) (70:D8) [06:50:50:711]: Component: __WebKitLicenses65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI (s) (70:D8) [06:50:50:711]: Component: __AIRAppInstaller65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI (s) (70:D8) [06:50:50:711]: Component: __FileTypeRegistration65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI (s) (70:D8) [06:50:50:711]: Component: __ARPRegistration65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI (s) (70:D8) [06:50:50:711]: Note: 1: 2205 2:  3: BindImage
MSI (s) (70:D8) [06:50:50:711]: Note: 1: 2205 2:  3: ProgId
MSI (s) (70:D8) [06:50:50:711]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (70:D8) [06:50:50:711]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (70:D8) [06:50:50:711]: Note: 1: 2205 2:  3: Extension
MSI (s) (70:D8) [06:50:50:711]: Note: 1: 2205 2:  3: Font
MSI (s) (70:D8) [06:50:50:711]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (70:D8) [06:50:50:711]: Note: 1: 2205 2:  3: Class
MSI (s) (70:D8) [06:50:50:711]: Note: 1: 2205 2:  3: Icon
MSI (s) (70:D8) [06:50:50:711]: Note: 1: 2205 2:  3: TypeLib
Action start 06:50:50: InstallValidate.
MSI (s) (70:D8) [06:50:50:712]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI (s) (70:D8) [06:50:50:936]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (s) (70:D8) [06:50:50:937]: Note: 1: 2205 2:  3: BindImage
MSI (s) (70:D8) [06:50:50:937]: Note: 1: 2205 2:  3: ProgId
MSI (s) (70:D8) [06:50:50:937]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (70:D8) [06:50:50:937]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (70:D8) [06:50:50:937]: Note: 1: 2205 2:  3: Extension
MSI (s) (70:D8) [06:50:50:937]: Note: 1: 2205 2:  3: Font
MSI (s) (70:D8) [06:50:50:937]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (70:D8) [06:50:50:937]: Note: 1: 2205 2:  3: Class
MSI (s) (70:D8) [06:50:50:937]: Note: 1: 2205 2:  3: Icon
MSI (s) (70:D8) [06:50:50:937]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (70:D8) [06:50:50:938]: Note: 1: 2727 2:
MSI (s) (70:D8) [06:50:50:939]: Note: 1: 2205 2:  3: FilesInUse
MSI (s) (70:D8) [06:50:50:967]: Note: 1: 2727 2:
MSI (s) (70:D8) [06:50:50:967]: Doing action: SetARPINSTALLLOCATION
MSI (s) (70:D8) [06:50:50:967]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:50: InstallValidate. Return value 1.
MSI (s) (70:D8) [06:50:50:968]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'SetARPINSTALLLOCATION'
MSI (s) (70:D8) [06:50:50:968]: PROPERTY CHANGE: Adding ARPINSTALLLOCATION property. Its value is 'c:\Program Files (x86)\Common Files\Adobe AIR\'.
Action start 06:50:50: SetARPINSTALLLOCATION.
MSI (s) (70:D8) [06:50:50:968]: Doing action: InstallInitialize
MSI (s) (70:D8) [06:50:50:968]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:50: SetARPINSTALLLOCATION. Return value 1.
MSI (s) (70:D8) [06:50:50:969]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (70:D8) [06:50:50:969]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (70:D8) [06:50:50:969]: BeginTransaction: Locking Server
MSI (s) (70:D8) [06:50:50:969]: SRSetRestorePoint skipped for this transaction.
MSI (s) (70:D8) [06:50:50:969]: Server not locked: locking for product {14DC0059-00F1-4F62-BD1A-AB23CD51A95E}
Action start 06:50:50: InstallInitialize.
MSI (s) (70:D8) [06:50:51:027]: Doing action: ProcessComponents
MSI (s) (70:D8) [06:50:51:027]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:51: InstallInitialize. Return value 1.
MSI (s) (70:D8) [06:50:51:028]: Note: 1: 2205 2:  3: MsiPatchCertificate
MSI (s) (70:D8) [06:50:51:028]: LUA patching is disabled: missing MsiPatchCertificate table
MSI (s) (70:D8) [06:50:51:028]: Resolving source.
MSI (s) (70:D8) [06:50:51:028]: Resolving source to launched-from source.
MSI (s) (70:D8) [06:50:51:028]: Setting launched-from source as last-used.
MSI (s) (70:D8) [06:50:51:028]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'c:\users\rob\appdata\local\temp\air3d39.tmp\'.
MSI (s) (70:D8) [06:50:51:028]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'c:\users\rob\appdata\local\temp\air3d39.tmp\'.
MSI (s) (70:D8) [06:50:51:028]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{14DC0059-00F1-4F62-BD1A-AB23CD51A95E}'.
MSI (s) (70:D8) [06:50:51:028]: SOURCEDIR ==> c:\users\rob\appdata\local\temp\air3d39.tmp\
MSI (s) (70:D8) [06:50:51:028]: SOURCEDIR product ==> {14DC0059-00F1-4F62-BD1A-AB23CD51A95E}
MSI (s) (70:D8) [06:50:51:028]: Determining source type
MSI (s) (70:D8) [06:50:51:029]: Source type from package 'setup.msi': 0
MSI (s) (70:D8) [06:50:51:029]: Source path resolution complete. Dumping Directory table...
MSI (s) (70:D8) [06:50:51:029]: Dir (source): Key: TARGETDIR          , Object: c:\users\rob\appdata\local\temp\air3d39.tmp\          , LongSubPath:           , ShortSubPath:
MSI (s) (70:D8) [06:50:51:029]: Dir (source): Key: WindowsFolder          , Object: c:\users\rob\appdata\local\temp\air3d39.tmp\          , LongSubPath:           , ShortSubPath:
MSI (s) (70:D8) [06:50:51:029]: Dir (source): Key: SHAREDADDINFOLDER          , Object: c:\users\rob\appdata\local\temp\air3d39.tmp\          , LongSubPath:           , ShortSubPath:
MSI (s) (70:D8) [06:50:51:029]: Dir (source): Key: CommonFilesFolder          , Object: c:\users\rob\appdata\local\temp\air3d39.tmp\          , LongSubPath:           , ShortSubPath:
MSI (s) (70:D8) [06:50:51:029]: Dir (source): Key: AIR          , Object: c:\users\rob\appdata\local\temp\air3d39.tmp\Adobe AIR\          , LongSubPath: Adobe AIR\          , ShortSubPath: AIR\
MSI (s) (70:D8) [06:50:51:029]: Dir (source): Key: Versions          , Object: c:\users\rob\appdata\local\temp\air3d39.tmp\Adobe AIR\Versions\          , LongSubPath: Adobe AIR\Versions\          , ShortSubPath: AIR\Versions\
MSI (s) (70:D8) [06:50:51:029]: Dir (source): Key: Version          , Object: c:\users\rob\appdata\local\temp\air3d39.tmp\Adobe AIR\Versions\1.0\          , LongSubPath: Adobe AIR\Versions\1.0\          , ShortSubPath: AIR\Versions\Version\
MSI (s) (70:D8) [06:50:51:029]: Dir (source): Key: Resources          , Object: c:\users\rob\appdata\local\temp\air3d39.tmp\Adobe AIR\Versions\1.0\Resources\          , LongSubPath: Adobe AIR\Versions\1.0\Resources\          , ShortSubPath: AIR\Versions\Version\R\
MSI (s) (70:D8) [06:50:51:029]: Dir (source): Key: WebKitLic          , Object: c:\users\rob\appdata\local\temp\air3d39.tmp\Adobe AIR\Versions\1.0\Resources\WebKit\          , LongSubPath: Adobe AIR\Versions\1.0\Resources\WebKit\          , ShortSubPath: AIR\Versions\Version\R\R2\
MSI (s) (70:D8) [06:50:51:029]: Note: 1: 2205 2:  3: ActionText
MSI (s) (70:D8) [06:50:51:030]: Note: 1: 2205 2:  3: ActionText
MSI (s) (70:D8) [06:50:51:034]: Note: 1: 2205 2:  3: ActionText
Action start 06:50:51: ProcessComponents.
MSI (s) (70:D8) [06:50:51:038]: Doing action: UnpublishFeatures
MSI (s) (70:D8) [06:50:51:038]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:51: ProcessComponents. Return value 1.
Action start 06:50:51: UnpublishFeatures.
MSI (s) (70:D8) [06:50:51:040]: Doing action: RemoveRegistryValues
MSI (s) (70:D8) [06:50:51:040]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:51: UnpublishFeatures. Return value 1.
Action start 06:50:51: RemoveRegistryValues.
MSI (s) (70:D8) [06:50:51:041]: Doing action: RemoveDuplicateFiles
MSI (s) (70:D8) [06:50:51:041]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:51: RemoveRegistryValues. Return value 1.
Action start 06:50:51: RemoveDuplicateFiles.
MSI (s) (70:D8) [06:50:51:043]: Doing action: RemoveFiles
MSI (s) (70:D8) [06:50:51:043]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:51: RemoveDuplicateFiles. Return value 1.
MSI (s) (70:D8) [06:50:51:044]: Note: 1: 2205 2:  3: RemoveFile
Action start 06:50:51: RemoveFiles.
MSI (s) (70:D8) [06:50:51:044]: Doing action: InstallFiles
MSI (s) (70:D8) [06:50:51:044]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:51: RemoveFiles. Return value 0.
MSI (s) (70:D8) [06:50:51:045]: The file represented by File table key 'SentinelFile' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:046]: The file represented by File table key 'air.swf' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:046]: The file represented by File table key 'template.msi' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:046]: The file represented by File table key 'template.exe' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:046]: The file represented by File table key 'LGPL.txt' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:046]: The file represented by File table key 'Notice.txt' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:046]: The file represented by File table key 'Setup.swf' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:046]: The file represented by File table key 'styles.swf' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:046]: The file represented by File table key 'Adobe.cer' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:046]: The file represented by File table key 'Thawte.cer' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:047]: The file represented by File table key 'digest.s' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:047]: The file represented by File table key 'adobecp.vch' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:047]: The file represented by File table key 'adobecp.dll' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:047]: The file represented by File table key 'AdobeAIR.vch' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:047]: The file represented by File table key 'AdobeAIR.dll' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:047]: The file represented by File table key 'air.exe' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:047]: The file represented by File table key 'WebKit.dll' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:047]: The file represented by File table key 'NPSWF32.dll' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:047]: The file represented by File table key 'Setup.exe' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:047]: The file represented by File table key 'airappinstaller.exe' has no eligible binary patches
MSI (s) (70:D8) [06:50:51:048]: The file represented by File table key 'adobecp15.dll' has no eligible binary patches
Action start 06:50:51: InstallFiles.
MSI (s) (70:D8) [06:50:51:048]: Note: 1: 2205 2:  3: Patch
MSI (s) (70:D8) [06:50:51:049]: Note: 1: 2228 2:  3: Patch 4: SELECT `Patch`.`File_`, `Patch`.`Header`, `Patch`.`Attributes`, `Patch`.`Sequence`, `Patch`.`StreamRef_` FROM `Patch` WHERE `Patch`.`File_` = ? AND `Patch`.`#_MsiActive`=? ORDER BY `Patch`.`Sequence`
MSI (s) (70:D8) [06:50:51:049]: Note: 1: 2205 2:  3: Error
MSI (s) (70:D8) [06:50:51:049]: Note: 1: 2228 2:  3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1302
MSI (s) (70:D8) [06:50:51:049]: Note: 1: 2205 2:  3: MsiSFCBypass
MSI (s) (70:D8) [06:50:51:049]: Note: 1: 2228 2:  3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
MSI (s) (70:D8) [06:50:51:049]: Note: 1: 2205 2:  3: MsiPatchHeaders
MSI (s) (70:D8) [06:50:51:049]: Note: 1: 2228 2:  3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
MSI (s) (70:D8) [06:50:51:049]: Note: 1: 2205 2:  3: PatchPackage
MSI (s) (70:D8) [06:50:51:098]: Note: 1: 2205 2:  3: Patch
MSI (s) (70:D8) [06:50:51:098]: Note: 1: 2228 2:  3: Patch 4: SELECT `Patch`.`Sequence`, `Patch`.`PatchSize`, `Patch`.`Attributes`, `Patch`.`Header`, `Patch`.`StreamRef_` FROM `File`,`Patch`,`Component` WHERE `File`=? AND `File`=`File_` AND `Component`=`Component_` ORDER BY `Patch`.`Sequence`
MSI (s) (70:D8) [06:50:51:099]: Note: 1: 2205 2:  3: Patch
MSI (s) (70:D8) [06:50:51:099]: Note: 1: 2228 2:  3: Patch 4: SELECT `Patch`.`Sequence`, `Patch`.`PatchSize`, `Patch`.`Attributes`, `Patch`.`Header`, `Patch`.`StreamRef_` FROM `File`,`Patch`,`Component` WHERE `File`=? AND `File`=`File_` AND `Component`=`Component_` ORDER BY `Patch`.`Sequence`
MSI (s) (70:D8) [06:50:51:153]: Note: 1: 2205 2:  3: Patch
MSI (s) (70:D8) [06:50:51:153]: Note: 1: 2228 2:  3: Patch 4: SELECT `Patch`.`Sequence`, `Patch`.`PatchSize`, `Patch`.`Attributes`, `Patch`.`Header`, `Patch`.`StreamRef_` FROM `File`,`Patch`,`Component` WHERE `File`=? AND `File`=`File_` AND `Component`=`Component_` ORDER BY `Patch`.`Sequence`
MSI (s) (70:D8) [06:50:51:204]: Note: 1: 2205 2:  3: Patch
MSI (s) (70:D8) [06:50:51:204]: Note: 1: 2228 2:  3: Patch 4: SELECT `Patch`.`Sequence`, `Patch`.`PatchSize`, `Patch`.`Attributes`, `Patch`.`Header`, `Patch`.`StreamRef_` FROM `File`,`Patch`,`Component` WHERE `File`=? AND `File`=`File_` AND `Component`=`Component_` ORDER BY `Patch`.`Sequence`
MSI (s) (70:D8) [06:50:51:206]: Note: 1: 2205 2:  3: Patch
MSI (s) (70:D8) [06:50:51:206]: Note: 1: 2228 2:  3: Patch 4: SELECT `Patch`.`Sequence`, `Patch`.`PatchSize`, `Patch`.`Attributes`, `Patch`.`Header`, `Patch`.`StreamRef_` FROM `File`,`Patch`,`Component` WHERE `File`=? AND `File`=`File_` AND `Component`=`Component_` ORDER BY `Patch`.`Sequence`
MSI (s) (70:D8) [06:50:51:210]: Note: 1: 2205 2:  3: Patch
MSI (s) (70:D8) [06:50:51:210]: Note: 1: 2228 2:  3: Patch 4: SELECT `Patch`.`Sequence`, `Patch`.`PatchSize`, `Patch`.`Attributes`, `Patch`.`Header`, `Patch`.`StreamRef_` FROM `File`,`Patch`,`Component` WHERE `File`=? AND `File`=`File_` AND `Component`=`Component_` ORDER BY `Patch`.`Sequence`
MSI (s) (70:D8) [06:50:51:212]: Note: 1: 2205 2:  3: Patch
MSI (s) (70:D8) [06:50:51:212]: Note: 1: 2228 2:  3: Patch 4: SELECT `Patch`.`Sequence`, `Patch`.`PatchSize`, `Patch`.`Attributes`, `Patch`.`Header`, `Patch`.`StreamRef_` FROM `File`,`Patch`,`Component` WHERE `File`=? AND `File`=`File_` AND `Component`=`Component_` ORDER BY `Patch`.`Sequence`
MSI (s) (70:D8) [06:50:51:214]: Doing action: DuplicateFiles
MSI (s) (70:D8) [06:50:51:214]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:51: InstallFiles. Return value 1.
Action start 06:50:51: DuplicateFiles.
MSI (s) (70:D8) [06:50:51:217]: Doing action: WriteRegistryValues
MSI (s) (70:D8) [06:50:51:217]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:51: DuplicateFiles. Return value 1.
Action start 06:50:51: WriteRegistryValues.
MSI (s) (70:D8) [06:50:51:222]: Doing action: RegisterUser
MSI (s) (70:D8) [06:50:51:222]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:51: WriteRegistryValues. Return value 1.
Action start 06:50:51: RegisterUser.
MSI (s) (70:D8) [06:50:51:224]: Doing action: RegisterProduct
MSI (s) (70:D8) [06:50:51:224]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:51: RegisterUser. Return value 1.
MSI (s) (70:D8) [06:50:51:225]: Note: 1: 2205 2:  3: Error
MSI (s) (70:D8) [06:50:51:225]: Note: 1: 2228 2:  3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1302
Action start 06:50:51: RegisterProduct.
MSI (s) (70:D8) [06:50:51:227]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
MSI (s) (70:D8) [06:50:51:227]: Doing action: PublishFeatures
MSI (s) (70:D8) [06:50:51:227]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:51: RegisterProduct. Return value 1.
Action start 06:50:51: PublishFeatures.
MSI (s) (70:D8) [06:50:51:229]: Doing action: PublishProduct
MSI (s) (70:D8) [06:50:51:229]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:51: PublishFeatures. Return value 1.
MSI (s) (70:D8) [06:50:51:231]: Note: 1: 2205 2:  3: Icon
MSI (s) (70:D8) [06:50:51:231]: Note: 1: 2228 2:  3: Icon 4: SELECT `Name`, `Data` FROM `Icon`
Action start 06:50:51: PublishProduct.
MSI (s) (70:D8) [06:50:51:232]: Doing action: InstallExecute
MSI (s) (70:D8) [06:50:51:232]: Note: 1: 2205 2:  3: ActionText
Action ended 06:50:51: PublishProduct. Return value 1.
MSI (s) (70:D8) [06:50:51:233]: Running Script: C:\Windows\Installer\MSI87B4.tmp
MSI (s) (70:D8) [06:50:51:233]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
MSI (s) (70:D8) [06:50:51:235]: Machine policy value 'DisableRollback' is 0
MSI (s) (70:D8) [06:50:51:242]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installe r\Rollback\Scripts 3: 2
MSI (s) (70:D8) [06:50:51:245]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1098593882,LangId=1 033,Platform=0,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4 ,ScriptAttributes=1)
Action start 06:50:51: InstallExecute.
MSI (s) (70:D8) [06:50:51:245]: Executing op: ProductInfo(ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},Product Name=Adobe AIR,PackageName=setup.msi,Language=1033,Version=50659328,Assignment=1 ,ObsoleteArg=0,,,PackageCode={0C8F1352-A5B9-4AAD-9E45-612DBB4F5E97},,, InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFlags =3)
MSI (s) (70:D8) [06:50:51:245]: Executing op: DialogInfo(Type=0,Argument=1033)
MSI (s) (70:D8) [06:50:51:246]: Executing op: DialogInfo(Type=1,Argument=Adobe AIR)
MSI (s) (70:D8) [06:50:51:246]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDes cription=Removing backup files,CleanupTemplate=File: [1])
MSI (s) (70:D8) [06:50:51:246]: Executing op: SetBaseline(Baseline=0,)
MSI (s) (70:D8) [06:50:51:246]: Executing op: SetBaseline(Baseline=1,)
MSI (s) (70:D8) [06:50:51:246]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
MSI (s) (70:D8) [06:50:51:246]: Executing op: ProgressTotal(Total=18,Type=1,ByteEquivalent=24000)
MSI (s) (70:D8) [06:50:51:246]: Executing op: ComponentRegister(ComponentId={701D2A09-14BE-45F8-9233-1CE0ED0023A9}, KeyPath=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Adobe AIR.dll,State=3,,Disk=1,SharedDllRefCount=2,BinaryType=0)
MSI (s) (70:D8) [06:50:51:247]: WIN64DUALFOLDERS: Substitution in 'c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Adobe AIR.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (70:D8) [06:50:51:248]: Executing op: ComponentRegister(ComponentId={95CB0A23-64ED-4832-8C2C-8E1671678EA8}, KeyPath=02:\Software\Adobe\Adobe AIR\FileTypeRegistration\,State=3,,Disk=1,SharedDllRefCount=0,BinaryT ype=0)
MSI (s) (70:D8) [06:50:51:250]: Executing op: ComponentRegister(ComponentId={12055C63-FC8C-4CC0-81A5-38E057039902}, KeyPath=02:\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe AIR\UninstallString,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (70:D8) [06:50:51:252]: Executing op: ComponentRegister(ComponentId={8E61C856-01FD-4B39-9D18-90B226C2013C}, KeyPath=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\template.msi,State=3,,Disk=1,SharedDllRefC ount=2,BinaryType=0)
MSI (s) (70:D8) [06:50:51:252]: WIN64DUALFOLDERS: Substitution in 'c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\template.msi' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (70:D8) [06:50:51:254]: Executing op: ComponentRegister(ComponentId={F748231B-0260-4E35-BFB8-7FACFDCE1711}, KeyPath=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\template.exe,State=3,,Disk=1,SharedDllRefC ount=2,BinaryType=0)
MSI (s) (70:D8) [06:50:51:254]: WIN64DUALFOLDERS: Substitution in 'c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\template.exe' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (70:D8) [06:50:51:256]: Executing op: ComponentRegister(ComponentId={DC74C3C6-CAB8-4C49-BE18-5B1DCD0D197E}, KeyPath=c:\Program Files (x86)\Common Files\Adobe AIR\sentinel,State=3,,Disk=1,SharedDllRefCount=2,BinaryType=0)
MSI (s) (70:D8) [06:50:51:256]: WIN64DUALFOLDERS: Substitution in 'c:\Program Files (x86)\Common Files\Adobe AIR\sentinel' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (70:D8) [06:50:51:258]: Executing op: ComponentRegister(ComponentId={F5EE0D89-3BC5-4752-9EBB-533B036EA809}, KeyPath=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Adobe AIR Application Installer.exe,State=3,,Disk=1,SharedDllRefCount=2,BinaryType=0)
MSI (s) (70:D8) [06:50:51:258]: WIN64DUALFOLDERS: Substitution in 'c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Adobe AIR Application Installer.exe' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (70:D8) [06:50:51:259]: Executing op: ComponentRegister(ComponentId={5281ED57-AD60-4235-A34D-F7571E28FC4C}, KeyPath=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\WebKit.dll,State=3,,Disk=1,SharedDllRefCou nt=2,BinaryType=0)
MSI (s) (70:D8) [06:50:51:260]: WIN64DUALFOLDERS: Substitution in 'c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\WebKit.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (70:D8) [06:50:51:261]: Executing op: ComponentRegister(ComponentId={F3E9B8B2-943C-4CD1-B8DC-E55758A9A845}, KeyPath=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\WebKit\LGPL License.txt,State=3,,Disk=1,SharedDllRefCount=2,BinaryType=0)
MSI (s) (70:D8) [06:50:51:261]: WIN64DUALFOLDERS: Substitution in 'c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\WebKit\LGPL License.txt' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (70:D8) [06:50:51:263]: Executing op: ComponentRegister(ComponentId={7A5778CF-5BD0-4931-8224-43B630C24273}, KeyPath=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\NPSWF32.dll,State=3,,Disk=1,SharedDllRefCo unt=2,BinaryType=0)
MSI (s) (70:D8) [06:50:51:263]: WIN64DUALFOLDERS: Substitution in 'c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\NPSWF32.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (70:D8) [06:50:51:265]: Executing op: ComponentRegister(ComponentId={1A511B10-11FC-4CAB-9C48-68641F09CF00}, KeyPath=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe AIR Updater.exe,State=3,,Disk=1,SharedDllRefCount=2,BinaryType=0)
MSI (s) (70:D8) [06:50:51:265]: WIN64DUALFOLDERS: Substitution in 'c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe AIR Updater.exe' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (70:D8) [06:50:51:267]: Executing op: ComponentRegister(ComponentId={76C2FC36-B864-4E7A-9C96-F9B80CDE9A13}, KeyPath=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe Root Certificate.cer,State=3,,Disk=1,SharedDllRefCount=2,BinaryType=0)
MSI (s) (70:D8) [06:50:51:291]: WIN64DUALFOLDERS: Substitution in 'c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe Root Certificate.cer' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (70:D8) [06:50:51:293]: Executing op: ComponentRegister(ComponentId={5E6626CD-4343-4FF9-8DB0-CFB62473037E}, KeyPath=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\Thawte Root Certificate.cer,State=3,,Disk=1,SharedDllRefCount=2,BinaryType=0)
MSI (s) (70:D8) [06:50:51:314]: WIN64DUALFOLDERS: Substitution in 'c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\Thawte Root Certificate.cer' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (70:D8) [06:50:51:316]: Executing op: ComponentRegister(ComponentId={7B2F9BE9-D1F1-4E4D-9AF0-AD085F073B33}, KeyPath=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\airappinstaller.exe,State=3,,Disk=1,Shared DllRefCount=2,BinaryType=0)
MSI (s) (70:D8) [06:50:51:317]: WIN64DUALFOLDERS: Substitution in 'c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\airappinstaller.exe' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (70:D8) [06:50:51:318]: Executing op: ComponentRegister(ComponentId={4E0C3DA9-8FD3-487A-92EB-DDE2CDC7EEAA}, ,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (70:D8) [06:50:51:320]: Executing op: ComponentRegister(ComponentId={060F1E52-BC43-4D4D-9DAD-197E00DCD5C9}, ,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (70:D8) [06:50:51:322]: Executing op: ComponentRegister(ComponentId={4E7390B9-0423-46B8-AED6-39BB3FB2C8FE}, KeyPath=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\AdobeCP15.dll,State=3,,Disk=1,SharedDllRef Count=2,BinaryType=0)
MSI (s) (70:D8) [06:50:51:322]: WIN64DUALFOLDERS: Substitution in 'c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\AdobeCP15.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (70:D8) [06:50:51:324]: Executing op: ComponentRegister(ComponentId={91DAC761-D04A-4404-BC97-E62936576E30}, KeyPath=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe AIR.vch,State=3,,Disk=1,SharedDllRefCount=2,BinaryType=0)
MSI (s) (70:D8) [06:50:51:347]: WIN64DUALFOLDERS: Substitution in 'c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe AIR.vch' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (70:D8) [06:50:51:349]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
MSI (s) (70:D8) [06:50:51:349]: Executing op: ProgressTotal(Total=45942446,Type=0,ByteEquivalent=1)
MSI (s) (70:D8) [06:50:51:349]: Executing op: SetTargetFolder(Folder=c:\Program Files (x86)\Common Files\Adobe AIR\)
MSI (s) (70:D8) [06:50:51:349]: Executing op: SetSourceFolder(Folder=1\AIR\|Adobe AIR\)
MSI (s) (70:D8) [06:50:51:349]: Executing op: ChangeMedia(,MediaPrompt=Please insert the disk: ,,BytesPerTick=65536,CopierType=0,,,,,,IsFirstPhysicalMedia=1)
MSI (s) (70:D8) [06:50:51:349]: Executing op: FileCopy(SourceName=sentinel,SourceCabKey=SentinelFile,DestName=senti nel,Attributes=512,FileSize=11,PerTick=65536,,VerifyMedia=1,,,,,CheckC RC=0,,,InstallMode=62914560,HashOptions=0,HashPart1=-1608728155,HashPa rt2=-1204748780,HashPart3=-375235064,HashPart4=-996773537,,)
MSI (s) (70:D8) [06:50:51:351]: File: c:\Program Files (x86)\Common Files\Adobe AIR\sentinel;          Overwrite;          Won't patch;          REINSTALLMODE specifies all files to be overwritten
MSI (s) (70:D8) [06:50:51:351]: Source for file 'sentinel' is uncompressed, at 'c:\users\rob\appdata\local\temp\air3d39.tmp\Adobe AIR\'.
MSI (s) (70:D8) [06:50:51:353]: Re-applying security from existing file.
MSI (s) (70:D8) [06:50:51:356]: Verifying accessibility of file: sentinel
MSI (s) (70:D8) [06:50:51:359]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:51:360]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:51:361]: File will have security applied from OpCode.
MSI (s) (70:D8) [06:50:51:362]: Executing op: SetTargetFolder(Folder=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\)
MSI (s) (70:D8) [06:50:51:362]: Executing op: SetSourceFolder(Folder=1\AIR\Versions\Version\|Adobe AIR\Versions\1.0\)
MSI (s) (70:D8) [06:50:51:362]: Executing op: RegisterSharedComponentProvider(,,File=AdobeAIR.dll,Component={701D2A 09-14BE-45F8-9233-1CE0ED0023A9},ComponentVersion=3.5.0.600,ProductCode ={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},ProductVersion=3.5.0,PatchSize =0,PatchAttributes=0,PatchSequence=0,SharedComponent=0,IsFullFile=0)
MSI (s) (70:D8) [06:50:51:367]: Executing op: FileCopy(SourceName=AIR.dll|Adobe AIR.dll,SourceCabKey=AdobeAIR.dll,DestName=Adobe AIR.dll,Attributes=512,FileSize=19104896,PerTick=65536,,VerifyMedia=1 ,,,,,CheckCRC=0,Version=3.5.0.600,Language=1033,InstallMode=62914560,, ,,,,,)
MSI (s) (70:D8) [06:50:51:368]: File: c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Adobe AIR.dll;          Overwrite;          Won't patch;          REINSTALLMODE specifies all files to be overwritten
MSI (s) (70:D8) [06:50:51:369]: Source for file 'Adobe AIR.dll' is uncompressed, at 'c:\users\rob\appdata\local\temp\air3d39.tmp\Adobe AIR\Versions\1.0\'.
MSI (s) (70:D8) [06:50:51:371]: Re-applying security from existing file.
MSI (s) (70:D8) [06:50:51:375]: Verifying accessibility of file: Adobe AIR.dll
MSI (s) (70:D8) [06:50:51:899]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:51:900]: File will have security applied from OpCode.
MSI (s) (70:D8) [06:50:52:042]: Executing op: RegisterSharedComponentProvider(,,File=air.exe,Component={F5EE0D89-3B C5-4752-9EBB-533B036EA809},ComponentVersion=3.5.0.600,ProductCode={14D C0059-00F1-4F62-BD1A-AB23CD51A95E},ProductVersion=3.5.0,PatchSize=0,Pa tchAttributes=0,PatchSequence=0,SharedComponent=0,IsFullFile=0)
MSI (s) (70:D8) [06:50:52:047]: Executing op: FileCopy(SourceName=air.exe|Adobe AIR Application Installer.exe,SourceCabKey=air.exe,DestName=Adobe AIR Application Installer.exe,Attributes=512,FileSize=131200,PerTick=65536,,VerifyMed ia=1,,,,,CheckCRC=0,Version=3.5.0.600,Language=1033,InstallMode=629145 60,,,,,,,)
MSI (s) (70:D8) [06:50:52:049]: File: c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Adobe AIR Application Installer.exe;          Overwrite;          Won't patch;          REINSTALLMODE specifies all files to be overwritten
MSI (s) (70:D8) [06:50:52:049]: Source for file 'Adobe AIR Application Installer.exe' is uncompressed, at 'c:\users\rob\appdata\local\temp\air3d39.tmp\Adobe AIR\Versions\1.0\'.
MSI (s) (70:D8) [06:50:52:052]: Re-applying security from existing file.
MSI (s) (70:D8) [06:50:52:057]: Verifying accessibility of file: Adobe AIR Application Installer.exe
MSI (s) (70:D8) [06:50:52:116]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:52:117]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:52:118]: File will have security applied from OpCode.
MSI (s) (70:D8) [06:50:52:129]: Executing op: FileCopy(SourceName=air.swf|Adobe AIR Application Installer.swf,SourceCabKey=air.swf,DestName=Adobe AIR Application Installer.swf,Attributes=512,FileSize=736683,PerTick=65536,,VerifyMed ia=1,,,,,CheckCRC=0,,,InstallMode=62914560,HashOptions=0,HashPart1=-12 33492735,HashPart2=475248911,HashPart3=-684551204,HashPart4=1330337087 ,,)
MSI (s) (70:D8) [06:50:52:131]: File: c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Adobe AIR Application Installer.swf;          Overwrite;          Won't patch;          REINSTALLMODE specifies all files to be overwritten
MSI (s) (70:D8) [06:50:52:131]: Source for file 'Adobe AIR Application Installer.swf' is uncompressed, at 'c:\users\rob\appdata\local\temp\air3d39.tmp\Adobe AIR\Versions\1.0\'.
MSI (s) (70:D8) [06:50:52:133]: Re-applying security from existing file.
MSI (s) (70:D8) [06:50:52:137]: Verifying accessibility of file: Adobe AIR Application Installer.swf
MSI (s) (70:D8) [06:50:52:141]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:52:142]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:52:143]: File will have security applied from OpCode.
MSI (s) (70:D8) [06:50:52:302]: Executing op: SetTargetFolder(Folder=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\)
MSI (s) (70:D8) [06:50:52:302]: Executing op: SetSourceFolder(Folder=1\AIR\Versions\Version\R\|Adobe AIR\Versions\1.0\Resources\)
MSI (s) (70:D8) [06:50:52:302]: Executing op: FileCopy(SourceName=template.msi,SourceCabKey=template.msi,DestName=t emplate.msi,Attributes=512,FileSize=20480,PerTick=65536,,VerifyMedia=1 ,,,,,CheckCRC=0,,,InstallMode=62914560,HashOptions=0,HashPart1=-154961 8677,HashPart2=1486351455,HashPart3=-1726132026,HashPart4=1070777563,, )
MSI (s) (70:D8) [06:50:52:304]: File: c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\template.msi;          Overwrite;          Won't patch;          REINSTALLMODE specifies all files to be overwritten
MSI (s) (70:D8) [06:50:52:304]: Source for file 'template.msi' is uncompressed, at 'c:\users\rob\appdata\local\temp\air3d39.tmp\Adobe AIR\Versions\1.0\Resources\'.
MSI (s) (70:D8) [06:50:52:306]: Re-applying security from existing file.
MSI (s) (70:D8) [06:50:52:311]: Verifying accessibility of file: template.msi
MSI (s) (70:D8) [06:50:52:314]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:52:315]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:52:317]: File will have security applied from OpCode.
MSI (s) (70:D8) [06:50:52:320]: Executing op: FileCopy(SourceName=template.exe,SourceCabKey=template.exe,DestName=t emplate.exe,Attributes=512,FileSize=59392,PerTick=65536,,VerifyMedia=1 ,,,,,CheckCRC=0,,,InstallMode=62914560,HashOptions=0,HashPart1=1620129 3,HashPart2=1510560032,HashPart3=-1630651345,HashPart4=683626339,,)
MSI (s) (70:D8) [06:50:52:322]: File: c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\template.exe;          Overwrite;          Won't patch;          REINSTALLMODE specifies all files to be overwritten
MSI (s) (70:D8) [06:50:52:322]: Source for file 'template.exe' is uncompressed, at 'c:\users\rob\appdata\local\temp\air3d39.tmp\Adobe AIR\Versions\1.0\Resources\'.
MSI (s) (70:D8) [06:50:52:325]: Re-applying security from existing file.
MSI (s) (70:D8) [06:50:52:329]: Verifying accessibility of file: template.exe
MSI (s) (70:D8) [06:50:52:342]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:52:343]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:52:344]: File will have security applied from OpCode.
MSI (s) (70:D8) [06:50:52:356]: Executing op: RegisterSharedComponentProvider(,,File=WebKit.dll,Component={5281ED57 -AD60-4235-A34D-F7571E28FC4C},ComponentVersion=6531.9.0.0,ProductCode= {14DC0059-00F1-4F62-BD1A-AB23CD51A95E},ProductVersion=3.5.0,PatchSize= 0,PatchAttributes=0,PatchSequence=0,SharedComponent=0,IsFullFile=0)
MSI (s) (70:D8) [06:50:52:356]: Note: 1: 1402 2: UNKNOWN\Components\75DE182506DA53243AD47F75E182CFC4\9500CD411F0026F4D BA1BA32DC159AE5 3: 5
MSI (s) (70:D8) [06:50:52:357]: Note: 1: 2205 2:  3: Error
MSI (s) (70:D8) [06:50:52:357]: Note: 1: 2228 2:  3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1402
MSI (s) (70:D8) [06:50:52:357]: Note: 1: 2228 2:  3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1709
MSI (s) (70:D8) [06:50:52:357]: Product: Adobe AIR -- Error 1402. Could not open key: UNKNOWN\Components\75DE182506DA53243AD47F75E182CFC4\9500CD411F0026F4D BA1BA32DC159AE5.  System error 5.  Verify that you have sufficient access to that key, or contact your support personnel.
MSI (s) (70:D8) [06:50:52:360]: User policy value 'DisableRollback' is 0
MSI (s) (70:D8) [06:50:52:360]: Machine policy value 'DisableRollback' is 0
Action ended 06:50:52: InstallExecute. Return value 3.
MSI (s) (70:D8) [06:50:52:361]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1098593882,LangId=1 033,Platform=0,ScriptType=2,ScriptMajorVersion=21,ScriptMinorVersion=4 ,ScriptAttributes=1)
MSI (s) (70:D8) [06:50:52:361]: Executing op: DialogInfo(Type=0,Argument=1033)
MSI (s) (70:D8) [06:50:52:361]: Executing op: DialogInfo(Type=1,Argument=Adobe AIR)
MSI (s) (70:D8) [06:50:52:361]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDes cription=Removing backup files,CleanupTemplate=File: [1])
MSI (s) (70:D8) [06:50:52:361]: Executing op: RegisterBackupFile(File=c:\Config.Msi\51d5cf0.rbf)
MSI (s) (70:D8) [06:50:52:362]: Executing op: RegisterBackupFile(File=c:\Config.Msi\51d5cf1.rbf)
MSI (s) (70:D8) [06:50:52:362]: Executing op: RegisterBackupFile(File=c:\Config.Msi\51d5cf2.rbf)
MSI (s) (70:D8) [06:50:52:362]: Executing op: RegisterBackupFile(File=c:\Config.Msi\51d5cf3.rbf)
MSI (s) (70:D8) [06:50:52:362]: Executing op: RegisterBackupFile(File=c:\Config.Msi\51d5cf4.rbf)
MSI (s) (70:D8) [06:50:52:362]: Executing op: RegisterBackupFile(File=c:\Config.Msi\51d5cf5.rbf)
MSI (s) (70:D8) [06:50:52:362]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
MSI (s) (70:D8) [06:50:52:362]: Executing op: SetTargetFolder(Folder=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\)
MSI (s) (70:D8) [06:50:52:363]: Executing op: ProductInfo(ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},Product Name=Adobe AIR,PackageName=setup.msi,Language=1033,Version=50659328,Assignment=1 ,ObsoleteArg=0,,,PackageCode={0C8F1352-A5B9-4AAD-9E45-612DBB4F5E97},,, InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFlags =3)
MSI (s) (70:D8) [06:50:52:363]: Executing op: FileCopy(SourceName=c:\Config.Msi\51d5cf5.rbf,,DestName=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\template.exe,Attributes=32800,FileSize=593 92,PerTick=0,,VerifyMedia=0,ElevateFlags=3,,,,,,,InstallMode=4194308,, ,,,,,)
MSI (s) (70:D8) [06:50:52:365]: File: c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\template.exe;          Overwrite;          Won't patch;          REINSTALLMODE specifies all files to be overwritten
MSI (s) (70:D8) [06:50:52:368]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:52:385]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:52:386]: Executing op: FileCopy(SourceName=c:\Config.Msi\51d5cf4.rbf,,DestName=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\template.msi,Attributes=32800,FileSize=204 80,PerTick=0,,VerifyMedia=0,ElevateFlags=3,,,,,,,InstallMode=4194308,, ,,,,,)
MSI (s) (70:D8) [06:50:52:402]: File: c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\template.msi;          Overwrite;          Won't patch;          REINSTALLMODE specifies all files to be overwritten
MSI (s) (70:D8) [06:50:52:404]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:52:413]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:52:413]: Executing op: SetTargetFolder(Folder=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\)
MSI (s) (70:D8) [06:50:52:414]: Executing op: FileCopy(SourceName=c:\Config.Msi\51d5cf3.rbf,,DestName=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Adobe AIR Application Installer.swf,Attributes=32800,FileSize=736570,PerTick=0,,VerifyMedia =0,ElevateFlags=3,,,,,,,InstallMode=4194308,,,,,,,)
MSI (s) (70:D8) [06:50:52:421]: File: c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Adobe AIR Application Installer.swf;          Overwrite;          Won't patch;          REINSTALLMODE specifies all files to be overwritten
MSI (s) (70:D8) [06:50:52:424]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:52:596]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:52:597]: Executing op: FileCopy(SourceName=c:\Config.Msi\51d5cf2.rbf,,DestName=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Adobe AIR Application Installer.exe,Attributes=32800,FileSize=129440,PerTick=0,,VerifyMedia =0,ElevateFlags=3,,,,,,,InstallMode=4194308,,,,,,,)
MSI (s) (70:D8) [06:50:52:647]: File: c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Adobe AIR Application Installer.exe;          Overwrite;          Won't patch;          REINSTALLMODE specifies all files to be overwritten
MSI (s) (70:D8) [06:50:52:650]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:52:663]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:52:664]: Executing op: RegisterSharedComponentProvider(,,File=air.exe,Component={F5EE0D89-3B C5-4752-9EBB-533B036EA809},ComponentVersion=3.4.0.2540,ProductCode={14 DC0059-00F1-4F62-BD1A-AB23CD51A95E},ProductVersion=3.4.0,PatchSize=0,P atchAttributes=0,PatchSequence=0,SharedComponent=0,IsFullFile=0)
MSI (s) (70:D8) [06:50:52:669]: Executing op: FileCopy(SourceName=c:\Config.Msi\51d5cf1.rbf,,DestName=c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Adobe AIR.dll,Attributes=32800,FileSize=14315936,PerTick=0,,VerifyMedia=0,E levateFlags=3,,,,,,,InstallMode=4194308,,,,,,,)
MSI (s) (70:D8) [06:50:53:031]: File: c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Adobe AIR.dll;          Overwrite;          Won't patch;          REINSTALLMODE specifies all files to be overwritten
MSI (s) (70:D8) [06:50:53:035]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:53:127]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:53:128]: Executing op: RegisterSharedComponentProvider(,,File=AdobeAIR.dll,Component={701D2A 09-14BE-45F8-9233-1CE0ED0023A9},ComponentVersion=3.4.0.2540,ProductCod e={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},ProductVersion=3.4.0,PatchSiz e=0,PatchAttributes=0,PatchSequence=0,SharedComponent=0,IsFullFile=0)
MSI (s) (70:D8) [06:50:53:135]: Executing op: SetTargetFolder(Folder=c:\Program Files (x86)\Common Files\Adobe AIR\)
MSI (s) (70:D8) [06:50:53:135]: Executing op: FileCopy(SourceName=c:\Config.Msi\51d5cf0.rbf,,DestName=c:\Program Files (x86)\Common Files\Adobe AIR\sentinel,Attributes=32800,FileSize=11,PerTick=0,,VerifyMedia=0,El evateFlags=3,,,,,,,InstallMode=4194308,,,,,,,)
MSI (s) (70:D8) [06:50:53:138]: File: c:\Program Files (x86)\Common Files\Adobe AIR\sentinel;          Overwrite;          Won't patch;          REINSTALLMODE specifies all files to be overwritten
MSI (s) (70:D8) [06:50:53:141]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:53:147]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:53:148]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
MSI (s) (70:D8) [06:50:53:148]: Executing op: ComponentUnregister(ComponentId={91DAC761-D04A-4404-BC97-E62936576E30 },ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},BinaryType=0,)
MSI (s) (70:D8) [06:50:53:169]: Executing op: ComponentUnregister(ComponentId={4E7390B9-0423-46B8-AED6-39BB3FB2C8FE },ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},BinaryType=0,)
MSI (s) (70:D8) [06:50:53:170]: Executing op: ComponentUnregister(ComponentId={060F1E52-BC43-4D4D-9DAD-197E00DCD5C9 },ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},BinaryType=0,)
MSI (s) (70:D8) [06:50:53:170]: Executing op: ComponentUnregister(ComponentId={4E0C3DA9-8FD3-487A-92EB-DDE2CDC7EEAA },ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},BinaryType=0,)
MSI (s) (70:D8) [06:50:53:170]: Executing op: ComponentUnregister(ComponentId={7B2F9BE9-D1F1-4E4D-9AF0-AD085F073B33 },ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},BinaryType=0,)
MSI (s) (70:D8) [06:50:53:171]: Executing op: ComponentUnregister(ComponentId={5E6626CD-4343-4FF9-8DB0-CFB62473037E },ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},BinaryType=0,)
MSI (s) (70:D8) [06:50:53:176]: Executing op: ComponentUnregister(ComponentId={76C2FC36-B864-4E7A-9C96-F9B80CDE9A13 },ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},BinaryType=0,)
MSI (s) (70:D8) [06:50:53:177]: Executing op: ComponentUnregister(ComponentId={1A511B10-11FC-4CAB-9C48-68641F09CF00 },ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},BinaryType=0,)
MSI (s) (70:D8) [06:50:53:178]: Executing op: ComponentUnregister(ComponentId={7A5778CF-5BD0-4931-8224-43B630C24273 },ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},BinaryType=0,)
MSI (s) (70:D8) [06:50:53:179]: Executing op: ComponentUnregister(ComponentId={F3E9B8B2-943C-4CD1-B8DC-E55758A9A845 },ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},BinaryType=0,)
MSI (s) (70:D8) [06:50:53:179]: Executing op: ComponentUnregister(ComponentId={5281ED57-AD60-4235-A34D-F7571E28FC4C },ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},BinaryType=0,)
MSI (s) (70:D8) [06:50:53:180]: Executing op: ComponentUnregister(ComponentId={F5EE0D89-3BC5-4752-9EBB-533B036EA809 },ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},BinaryType=0,)
MSI (s) (70:D8) [06:50:53:180]: Executing op: ComponentUnregister(ComponentId={DC74C3C6-CAB8-4C49-BE18-5B1DCD0D197E },ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},BinaryType=0,)
MSI (s) (70:D8) [06:50:53:181]: Executing op: ComponentUnregister(ComponentId={F748231B-0260-4E35-BFB8-7FACFDCE1711 },ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},BinaryType=0,)
MSI (s) (70:D8) [06:50:53:181]: Executing op: ComponentUnregister(ComponentId={8E61C856-01FD-4B39-9D18-90B226C2013C },ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},BinaryType=0,)
MSI (s) (70:D8) [06:50:53:182]: Executing op: ComponentUnregister(ComponentId={12055C63-FC8C-4CC0-81A5-38E057039902 },ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},BinaryType=0,)
MSI (s) (70:D8) [06:50:53:183]: Executing op: ComponentUnregister(ComponentId={95CB0A23-64ED-4832-8C2C-8E1671678EA8 },ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},BinaryType=0,)
MSI (s) (70:D8) [06:50:53:184]: Executing op: ComponentUnregister(ComponentId={701D2A09-14BE-45F8-9233-1CE0ED0023A9 },ProductKey={14DC0059-00F1-4F62-BD1A-AB23CD51A95E},BinaryType=0,)
MSI (s) (70:D8) [06:50:53:184]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=0)
MSI (s) (70:D8) [06:50:53:184]: Error in rollback skipped.          Return: 5
MSI (s) (70:D8) [06:50:53:190]: Note: 1: 2318 2:
MSI (s) (70:D8) [06:50:53:192]: No System Restore sequence number for this installation.
MSI (s) (70:D8) [06:50:53:192]: Unlocking Server
MSI (s) (70:D8) [06:50:53:251]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
Action ended 06:50:53: INSTALL. Return value 3.
Property(S): ARPINSTALLLOCATION = c:\Program Files (x86)\Common Files\Adobe AIR\
Property(S): SHAREDADDINFOLDER = c:\Program Files (x86)\Adobe\Flash Player\AddIns\airappinstaller\
Property(S): UpgradeCode = {8DA920D5-C41C-42E0-BF31-87BA49984EE4}
Property(S): WebKitLic = c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\WebKit\
Property(S): Resources = c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\
Property(S): Version = c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\
Property(S): Versions = c:\Program Files (x86)\Common Files\Adobe AIR\Versions\
Property(S): AIR = c:\Program Files (x86)\Common Files\Adobe AIR\
Property(S): CommonFilesFolder = c:\Program Files (x86)\Common Files\
Property(S): TARGETDIR = c:\
Property(S): SourceDir = c:\users\rob\appdata\local\temp\air3d39.tmp\
Property(S): Manufacturer = Adobe Systems Incorporated
Property(S): ProductCode = {14DC0059-00F1-4F62-BD1A-AB23CD51A95E}
Property(S): ProductLanguage = 1033
Property(S): ProductName = Adobe AIR
Property(S): ProductVersion = 3.5.0.600
Property(S): REINSTALLMODE = amus
Property(S): ARPSYSTEMCOMPONENT = yes
Property(S): REBOOT = Suppress
Property(S): ALLUSERS = 1
Property(S): SecureCustomProperties = ARPSYSTEMCOMPONENT;REINSTALLMODE;SHAREDADDINFOLDER;UC8DA920D5C41C42E0 BF3187BA49984EE4
Property(S): MsiLogFileLocation = C:\Users\Rob\AppData\Local\Temp\MSI38408.LOG
Property(S): PackageCode = {0C8F1352-A5B9-4AAD-9E45-612DBB4F5E97}
Property(S): ProductState = -1
Property(S): PackagecodeChanging = 1
Property(S): CURRENTDIRECTORY = C:\Users\Rob\Downloads
Property(S): CLIENTUILEVEL = 3
Property(S): MSICLIENTUSESEXTERNALUI = 1
Property(S): CLIENTPROCESSID = 6888
Property(S): VersionDatabase = 200
Property(S): VersionMsi = 5.00
Property(S): VersionNT = 601
Property(S): VersionNT64 = 601
Property(S): WindowsBuild = 7600
Property(S): ServicePackLevel = 0
Property(S): ServicePackLevelMinor = 0
Property(S): MsiNTProductType = 1
Property(S): MsiNTSuitePersonal = 1
Property(S): WindowsFolder = c:\Windows\
Property(S): WindowsVolume = c:\
Property(S): System64Folder = C:\Windows\system32\
Property(S): SystemFolder = c:\Windows\SysWOW64\
Property(S): RemoteAdminTS = 1
Property(S): TempFolder = C:\Users\Rob\AppData\Local\Temp\
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): ProgramFiles64Folder = C:\Program Files\
Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
Property(S): AppDataFolder = C:\Users\Rob\AppData\Roaming\
Property(S): FavoritesFolder = C:\Users\Rob\Favorites\
Property(S): NetHoodFolder = C:\Users\Rob\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): PersonalFolder = C:\Users\Rob\Documents\
Property(S): PrintHoodFolder = C:\Users\Rob\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): RecentFolder = C:\Users\Rob\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): SendToFolder = C:\Users\Rob\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): LocalAppDataFolder = C:\Users\Rob\AppData\Local\
Property(S): MyPicturesFolder = C:\Users\Rob\Pictures\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): FontsFolder = C:\Windows\Fonts\
Property(S): GPTSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): ShellAdvtSupport = 1
Property(S): MsiAMD64 = 6
Property(S): Msix64 = 6
Property(S): Intel = 6
Property(S): PhysicalMemory = 3950
Property(S): VirtualMemory = 4377
Property(S): AdminUser = 1
Property(S): MsiTrueAdminUser = 1
Property(S): LogonUser = Rob
Property(S): UserSID = S-1-5-21-239897419-454332830-1066773327-1000
Property(S): UserLanguageID = 2057
Property(S): ComputerName = ROB-VAIO
Property(S): SystemLanguageID = 2057
Property(S): ScreenX = 1024
Property(S): ScreenY = 768
Property(S): CaptionHeight = 22
Property(S): BorderTop = 1
Property(S): BorderSide = 1
Property(S): TextHeight = 16
Property(S): TextInternalLeading = 3
Property(S): ColorBits = 32
Property(S): TTCSupport = 1
Property(S): Time = 06:50:53
Property(S): Date = 27/11/2012
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
Property(S): RedirectedDllSupport = 2
Property(S): MsiRunningElevated = 1
Property(S): Privileged = 1
Property(S): USERNAME = Rob
Property(S): DATABASE = c:\Windows\Installer\51d5cec.msi
Property(S): OriginalDatabase = c:\users\rob\appdata\local\temp\air3d39.tmp\setup.msi
Property(S): UILevel = 2
Property(S): ACTION = INSTALL
Property(S): ROOTDRIVE = c:\
Property(S): CostingComplete = 1
Property(S): OutOfDiskSpace = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): INSTALLLEVEL = 1
Property(S): SOURCEDIR = c:\users\rob\appdata\local\temp\air3d39.tmp\
Property(S): SourcedirProduct = {14DC0059-00F1-4F62-BD1A-AB23CD51A95E}
Property(S): ProductToBeRegistered = 1
MSI (s) (70:D8) [06:50:53:275]: Note: 1: 1708
MSI (s) (70:D8) [06:50:53:275]: Note: 1: 2205 2:  3: Error
MSI (s) (70:D8) [06:50:53:275]: Note: 1: 2228 2:  3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1708
MSI (s) (70:D8) [06:50:53:276]: Note: 1: 2228 2:  3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1709
MSI (s) (70:D8) [06:50:53:276]: Product: Adobe AIR -- Installation failed.
MSI (s) (70:D8) [06:50:53:276]: Windows Installer installed the product. Product Name: Adobe AIR. Product Version: 3.5.0.600. Product Language: 1033. Manufacturer: Adobe Systems Incorporated. Installation success or error status: 1603.
MSI (s) (70:D8) [06:50:53:278]: Deferring clean up of packages/files, if any exist
MSI (s) (70:D8) [06:50:53:278]: MainEngineThread is returning 1603
MSI (s) (70:E0) [06:50:53:281]: RESTART MANAGER: Session closed.
MSI (s) (70:E0) [06:50:53:281]: No System Restore sequence number for this installation.
=== Logging stopped: 27/11/2012  06:50:53 ===
MSI (s) (70:E0) [06:50:53:286]: User policy value 'DisableRollback' is 0
MSI (s) (70:E0) [06:50:53:286]: Machine policy value 'DisableRollback' is 0
MSI (s) (70:E0) [06:50:53:286]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (70:E0) [06:50:53:286]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installe r\Rollback\Scripts 3: 2
MSI (s) (70:E0) [06:50:53:287]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installe r\Rollback\Scripts 3: 2
MSI (s) (70:E0) [06:50:53:287]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
MSI (s) (70:E0) [06:50:53:288]: Restoring environment variables
MSI (c) (E8:E8) [06:50:53:289]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
MSI (c) (E8:E8) [06:50:53:290]: MainEngineThread is returning 1603
=== Verbose logging stopped: 27/11/2012  06:50:53 ===
  • Chris Campbell
    May 4, 2010
    Nov 28, 2012 6:05 PM   in reply to robidoo
    Thank you for the logs.  It appears that the problem is within the MSI sub install and specifically when it tries to modify a registry key.
    Could you search your registry for "9500CD411F0026F4D BA1BA32DC159AE5" or "75DE182506DA53243AD47F75E182CFC4" to see if they exist?  If they do, can you right click on them and select "permissions" and then list the values that you have in that dialog?
  • Chris Campbell
    May 4, 2010
    Dec 4, 2012 6:19 PM   in reply to robidoo
    Can you try giving the "users" account full control to see if that allows the installer to modify the key?
