Kristian2760
PSE8 and PSE1
Nov 27, 2012 12:13 AM
Is it possible to have both PSE8 and PSE11 installed on the same PC
Kristian
    Nov 27, 2012 12:19 AM   in reply to Kristian2760
    For questions regarding Photoshop Elements pleaase refer to the Photoshop Elements Forum.
    http://forums.adobe.com/community/photoshop_elements
    Nov 27, 2012 12:38 AM   in reply to Kristian2760
    Yes, they should both run on the same computer, as they are totally separate programs.
    Nov 27, 2012 4:34 AM   in reply to Kristian2760
    If it helps, I have PSE8 and Photoshop CS6 on the same computer.
    As R_Kelly says, they are completely seperate and, therefore, should run just the same, and independently of each other. However, I did have a slight issue, initially, in that I had to reset PSE8's scanner settings, in preferences, as, curiously, it lost connection to the default scanner after installing Photoshop CS6. Simply by selecting a different scanner option, then selecting the original scanner option again, cured this and I've had no further problems.
