ADE 2.0 always crashes
Nov 27, 2012 5:46 PM
Tags: #crash #ade
Unlike many posts I am able to install ADE 2.0 on a Windows 7 32 bit computer with all updates.  However whenever I try to run it opens but any click will crash the program.I have uninstalled and reinstalled and still get the same crash.
    Nov 28, 2012 8:52 AM   in reply to markcarrara_from_NM
    Moving this discussion to the Adobe Digital Editions forum.
    Do you receive any specific error messages when Adobe Digital Editions 2.0 crashes?  What have you tried so far to resolve your difficulties?
    Nov 28, 2012 4:33 PM   in reply to Jeff A Wright
    Same here. ADE 2.0 keeps crashing with Win 7 Enterprise 32 bits. No specific error message. Tried uninstall and reinstall. Tried download exe with another browser. Tried click under properties under the general tab unblock button next to security. Nothing seems to work. Please advise. Appreciate help.
    Nov 28, 2012 4:50 PM   in reply to hugojmcp
    Adobe Digital Editions is a fairly simple application.  Did you have it working previously on this computer?  If so what changed?  Have you tried booting into selective start up with your start up items and third party services disabled?
    Nov 30, 2012 7:02 AM   in reply to markcarrara_from_NM
    What we see on the screen can be misleading.  If an error report is being
    sent to Microsoft, it usually means that some parameters associated with
    the application have caused a failure.  This can be from the software being
    run or from Windows if it's not updated to the 'proper' spec's (which is a
    term for Microsoft goofs).  Can't tell which it is, but if you're not
    getting any response from Microsoft after the error report, then it's most
    likely to be parameters affecting ADE.  I'm assuming (dangerous) that
    you're running Windows 7, and if so, then you may need to adjust its
    parameters to let ADE access the Internet and download ebooks.
    Unfortunately, I'm not a Win 7 expert, so I can't tell you exactly how to
    check those parameters and reset them.
    On Thu, Nov 29, 2012 at 7:32 PM, markcarrara_from_NM <
    Mar 22, 2013 10:57 AM   in reply to Jeff A Wright
    I also see this on XP.
    My machine is a developer machine, so I get a dialog box from Windows which shows an exception and asks me if I want to start a debugger.
    The exception is an ArgumentsOutofBoundsException.
    THis looks like a Java or .Net exception. Is there a specific .Net version that is needed?
    I need ADE 2.0 because it has support for the B&N Nook. The earlier versions don't.
    Please fix this!
