Hello. I've got a big space appearing above my title line in this page. http://www.sarahpellerdesign.com/jordan/schooner.html See how there is a lot of white space above the words "Schooner Adventuress"? So, I went to the code and saw this on line 56: <p>& n b s p;</p> (put spaces in there, otherwise it won't show up)
I tried to delete that line and it resulted in the entire page below the nav bar shifting over to the right, so that it is sort of "attached" to the right end of the nav bar. When I preview it in the Chrome browser, it looks like nothing's changed, but it remains shifted to the right in dreamweaver. Unfortunately, in that position, I can't get to the content. It's stuck off the side of the page and I can't scroll over to it.
Anyone know how to fix this?
Thanks!
Hi Sarah -
Code view is a better place to delete unwanted code precisely.
In design view you can accidently remove more than you intended and disrupt your layout.
You also have some wonky partial table code at the very bottom.
<table width="850" border="0" align="center" cellpadding="0" cellspacing="0">
<tr> </tr>
</table>
After you remove it, run your URL through the validator at
Thank you both for your comments. Unfortunately, I'm still having the same troubles. I know that I can delete that weird bit of code in the code view. Only problem is that when I do, the page moves out of range and I can't get in there in case I want to edit again. See how it looks here:
And I can't get in there to change/see the text and images. Notice no scroll bar. Also, usually the page will shift into its rightful place if I click outside of the tables, but this one isn't budging... Is this just unfixable? Do I need to just work on the code side? I really prefer to see the layout.
So, I fixed the errors and ran the new page through the validator and it passed with no errors. This page: http://sarahpellerdesign.com/jordan/wildlandtest2.html
But it is still totally messy in the design view of Dreamweaver. I can't understand where I'm going wrong...
Thanks so much for your help!
North America
Asia Pacific
