Deenakim423
Help importing After Effects file to Flash
Nov 29, 2012 8:16 AM
Tags: #flash #after_effects #swf_not_opening #flv_to_swf
I am making a web banner for my company to submit to another company who will be uploading it for us on the web. We have the file in After Effects and I have imported it to Flash using both a swf file and then as a FLV file. In both versions, it opens great on my computer because the source file is connected to the resulting SWF. However, when I submit just the SWF file to the company, they cannot open it. They only see a blank white banner.
What am I doing wrong?
The file size has to be under 40K, so I have to use the method that I had been doing - FLV from After Effects to Flash - which makes a 36K SWF. However, it just won't open on anyone's computer and I can't send both the FLV source file and the resulting SWF to the company because they can only use the SWF.
Any help would be appreciated. Thank you!
    Nov 29, 2012 12:52 PM   in reply to Deenakim423
    - Export the video from AE to a FLV video file
    - Open a new Flash document at the same frame rate and correct size for your banner
    - In Flash, File->Import->Import to Stage, select the .flv video file produced by AE
    - Select "Embed FLV in SWF and play in timeline", click Next
    - Symbol type: Embedded Video, leave all 3 boxes checked (instance on stage, expand timeline, include audio), click Next
    - Click Finish
    You will see your FLV on the timeline. If you wish it to loop, do nothing but File->Publish if the version of Flash Player selection is fine.
    If you don't want it to loop then insert a new layer in the Timeline. On the last frame of the video in the new layer above right-click on that frame and insert a blank keyframe. Click that blank keyframe, open your Actions panel (F9). Put this code:
    stop();
    Nov 30, 2012 6:36 AM   in reply to Deenakim423
    That's exactly what the process above will do. Note the step:
    What that means is store the video inside the SWF itself. You will only have a single SWF file when done. You do not need the FLV externally.
    I can embed it and give you a SWF with the FLV embedded to prove it if you like. Just shoot me a private message with a download link to the FLV and tell me which version of Flash Player you'd like to target. I will use the instructions above and produce a single SWF that plays the video with no further files needed.
