I am building an MXML project in Flash Builder 4.5
I have a custom MXML component that contains a TextInput field. I want the custom component to have a change event that triggers a function in the main application.
I created a test project to try and solve this. At the moment, it appears to trigger an event once and then stops. Please take a look and let me know where I am going wrong. Many thanks.
customComponent.mxml
<mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml"
width="40" height="20">
<mx:Script>
<![CDATA[
[Bindable]
public var value:Number;
protected function inputBox_clickHandler(event:KeyboardEvent):void
if (event.keyCode == 38 ) {
keyUp();
if (event.keyCode == 40 ) {
keyDown();
protected function keyUp():void
value = value++;
dispatchEvent(new Event('change'))
protected function keyDown():void
value = value--;
</mx:Script>
<mx:Metadata>
[Event(name="change", type="flash.events.Event")]
</mx:Metadata>
<mx:TextInput id="inputBox" x="0" y="0" width="40" height="20"
text="{value}"
keyDown="inputBox_clickHandler(event)"
change="dispatchEvent(new Event('change'))"
</mx:Canvas>
main.mxml
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
xmlns:CustomComponents="CustomComponents.*"
minWidth="955" minHeight="600" layout="absolute">
<mx:Script>
<![CDATA[
private function changeTestLabel():void
testLabel.text = String(myComponent.value);
</mx:Script>
<CustomComponents:customComponent x="180" y="183"
id="myComponent" value="0"
change="changeTestLabel()">
</CustomComponents:customComponent>
<mx:Label id="testLabel" x="165" y="206" text="Test label"/>
</mx:Application>
I have found the solution to this...
The clue was that it worked the first time a change was made, changing the value to the default '0'.
The problem was that the var value is type Number and the inputBox.text is type String.
I therefore added the following function:
protected function textChange():void
value = Number(inputBox.text);
I also changed the change="dispatchEvent(new Event('change'))" property to
valueCommit="textChange()"
... and that fixed it..
Thanks to all those who took the trouble to look at this
North America
Asia Pacific
