Packaging error in CS5.5
Nov 29, 2012 12:06 PM
Tags: #cs5.5 #export #package
Hi there,
I'm trying to package an ID document that I upgraded from CS4 to CS5
and later to 5.5 on another machine. When packaging I get an error saying:
Cannot copy necessary linked file(s). The free diskspace is not an issue:
I have at least 480 Gb free space. Then I tried to make an idml and turn
that into a .indd doc and package that but I get the same error.
I'm sure it's something in the file as I have packaged larger documents
over the same network but those were native CS5.5 docs. Is there a way
to check/edit the document under the hood or something?
TIA.
    Nov 29, 2012 2:58 PM   in reply to motiondude
    First, do the links show as up to date? ID won't package links it can't find.
    Second, do any of the links have "illegal" characters in the name or path?
    Nov 29, 2012 4:04 PM   in reply to motiondude
    Exporting to .idml should strip out unused plugin information. See Remove minor corruption by exporting
    Nov 29, 2012 4:32 PM   in reply to motiondude
    Try copying the links to a local folder and then relinking to that folder. Both can be done from the Links panel menu.
    Nov 29, 2012 4:54 PM   in reply to motiondude
    You can troubleshoot fonts followng the guidlines here: Troubleshoot fonts | Mac OS X and Troubleshoot font problems | Windows
    It's still sounding like the problem might be in a filename on one of the links.
    Nov 29, 2012 5:11 PM   in reply to motiondude
    Are you patched to 7.5.3?
