CountryLiv
Where are my shortcut keys?
Nov 29, 2012 9:02 PM
Tags: #cs6 #shortcut_keys
I was using the free trial of SC6, migrated all my settings and such from SC3, and everything worked super good for the 30 days. Enter day 31 when I decide to go ahead and buy SC6, now the program is not working correctly!! What happened to my shortcut keys that were there before I bought my copy? This makes absolutely no sense since there were not suppose to be any program changes!  Help! I need my programmed keys!
    Nov 29, 2012 11:23 PM   in reply to CountryLiv
    What do you mean? Are only the shortcuts M.I.A. or is something else wrong? How did you serialize/ activate? Did you reinstall the program or just input the serial in the trial?
    Mylenium
    Nov 29, 2012 11:32 PM   in reply to CountryLiv
    If you still have CS3 installed you should be able to manually transfer the kys-file if Edit > Presets > Migrate Presets should not work out.
    Are any of the Presets you have edited since you started using CS6 still intact in Photoshop? If so you may want to save them.
    Nov 30, 2012 3:42 AM   in reply to CountryLiv
    Just to make sure, if you have sufficient disk space there is no need to uninstall the older version.
