boenracing
Save command not overwriting automatically?
Nov 30, 2012 10:39 AM
Tags: #save #as #overwrite
I haven't had this problem before (CS5, CS5.5). But when i started using CS6 i noticed that each time i open a project in InDesign, edited it somehow, and then press Ctrl+S to save it, it doesn't automatically overwrite the file. Instead it opens the Save As window in a completly different folder on my computer and then i have to find the folder and file i was working on, click on it and then InDesign asks me if i want to overwrite the file. Why doesn't it just overwrite the file to begin with, after all i pressed Save, not Save as?
Would really appreciate some help...
Thanks...
    Nov 30, 2012 10:51 AM   in reply to boenracing
    If the file is from an older version it's usually throwing a monkey wrench in the system. I'd save a copy to the desktop next time it happens and see what happens after that.
    Nov 30, 2012 11:27 AM   in reply to boenracing
    This is normal and a safety feature for legacy files opened in a newer version. It prevents you from accidentally (though not purposefully) overwriting and rendering it no longer openable in the original version. As far as ID is concerned, a file saved in any earlier version is essentailly opened as a copy, though it differs from the normal open as a copy behavior by retaining the previous name and appending (Converted) in the interface. Once saved in a new version, this will stop until the next new version comes along (it even happens sometimes with sevice patches).
    I recoomend that you do not overwrite legacy files, though it's OK to do so with files from the same version of ID if it comes up.
    Dec 1, 2012 4:20 AM   in reply to boenracing
    That's definitetly not normal. Could be network related in some way or, more likely, some sort of conflict with another program you run in the background.
    Dec 1, 2012 4:35 AM   in reply to Peter Spier
    Not normal but I'm seeing it, too. Hit or miss so I have no clue what's causing it.
    Bob
    Dec 1, 2012 4:41 AM   in reply to Bob Levine
    Want to bet it's Suitcase?
    Dec 1, 2012 4:49 AM   in reply to Peter Spier
    Actually I think it's a Win8 thing. But like I said, it's so hit or miss I can't be sure.
    Bob
    Dec 1, 2012 4:56 AM   in reply to Bob Levine
    I think we've had some Mac users reporting this, too. Might not be the same problem, of course.
    Dec 3, 2012 1:05 AM   in reply to Peter Spier
    @Peter – I can remember one occasion with several files deliverd by a customer who is on Windows. I'm on Mac OS X 10.6.8. Thiese files were pulled out of a data base used by a Censhare ECMS workflow system. At that time, I think they were on Windows XP with InDesign CS4. I never found a solution other than resaving several times with Save As or exporting to IDML.
    Uwe
