Hi there. I'm using CS5 on a PC. I should preface this by saying it's been a long time since I used a vector graphics program, and when I did, it was Macromedia Freehand.
I am creating an object using the pen tool, and I'd like to adjust the curves on either side of an anchor point independently of one another. There was a function to do this in Freehand, but I can't seem to find it's Illustrator equivalent. Is there a function like this, or is there another way to go about it?
Thanks!
Sandi
Hold Alt while dragging the handle with the white pointer. This turns a smooth anchor point to corner point.
edit: sorry, not while dragging but before dragging, Holding Alt while dragging and after releasing the mouse will create a copy of the curve segment. I didn't see Scott's post but the white pointer (direct selection tool is the official name) is a different tool than the one Scott suggested so, you can do it with either of these tools.
steve fairbairn wrote:
Not really. It converts anchors into corner points and susequent dragging produces symmetrical handles.
Perhaps your version is different than mine, but the Convert Anchor tool used on a symmetrical Bezier handle... converts it to a non-symmetrical handle, no Alt or Option key is needed. Only when click-dragging on the anchor itself is the Alt or Option key needed to break symmetry.
Scott is correct if you use the convert anchor point on a handle the handle will be independent, if you use the direct select tool you need to hold down the option key in order for the handle to move independently.
The error is the preception that because when using the pentool you hold the option key down in order to access the convert anchor point tool which you arer confusing with the function of the direct select tool plus the option key and sustituting the convert anchor point in your recall of the functions.
The fact is that Scott is 100% correct and you are in error.
I am not in error. Sure Scott is right but then so am I.
What I omitted to write in post #4 was that option dragging with the Direct Selection tool allows you to manipulate handles independently of each other.
The Convert Anchor Point tool does the same when used on a handle but when used on an anchor it does exactly what I said in post #4.
I never mentioned the Pen tool.
Sorry for any confusion or misinterpretation I may have caused.
When one has been using Illie for as long as we have it is sometimes difficult to express the obvious in a foolproof fashion :-)
Aw c’mon Wade. Read it better.
I wrote:
(The Convert Anchor tool) converts anchors into corner points and susequent dragging produces symmetrical handles.
Which it does when you click on anchors.
I then wrote:
Option/Alt dragging on an anchor allows you to control each handle independently.
Which it does when you use the Direct Selection tool.
So which bit aren’t you satisfied with?
I agree, Steve. We all know that we know how to do this... anything posted may simply come down to syntax used when posting due to speed of posting, missed words, a cat walking across your desk, the wife yelling at you, a hurricaine, the local shop being out of Red Vines...... Pointing fingers does no one any good. It doesn't matter as long as Sandi got what she needed.
North America
Asia Pacific
