This package ran okay on my Windows 7 64 bit PC. I upgraded the Windows 7 PC to 64 bit Windows 8. Reinstalled all software including CS6. Dreamweaver will not start and comes up with a Error 7b. I have updated all the drivers including the graphics card. It seems that all CS6 programs that load up in a 32 bit mode are suspect in Windows 8. I have downloaded and updated all Adobe programs but still a problem. Looking for ideas as Adobe help is only Monday to Friday.
7b is a hardware related STOP error from Windows.
Usually caused due to faulty installations.
Instead of re-installing, can you try cleaning all traces of installations of Adobe CS6 using CS Cleaner: http://www.adobe.com/support/contact/cscleanertool.html
Then, install CS6 afresh? See if this fixes it.
Other than that, there have been no official reports of DW not running on 64bit Win 8.
-ST
Thanks for the suggestion, I did try the CS cleaner and actually went through the registry deleting all bits of Adobe. Did a clean install with no luck. If it is a "hardware" fault, would it not have shown up when running 64 bit windows 7.
I have looked at which of the Adobe apps (CS6) do not run and it seems that any loaded as 32 bit are possible problems.
Is there a way to tell which piece of hardware is stopping dreamweaver (like what does it need to start up).
I also started windows 8 in "Safe Mode" and still the same problem so it does not seem to be a driver conflict.
More thoughts please
When you upgraded Win7 to Win8, was that process itself a clean install - meaning did you reformat the hard drive (or use a separate hard drive) thereby installing a fresh copy of Win 8?
I recently upgraded to Win 8 64bit as well, and from Win7 64bit, but I didn't want to run the risk of loosing access to any of my Win7 Apps or files should I find Win8 unbearable, so I ran the upgrade on a separate hard drive, which gave me the option to boot into either 7 or 8. Actually, Vista is on a third drive, left over from my Win7 upgrade in 2009. ;-)
I'm about 3 weeks in, and so far I have had no problems at all with any CS6 app on Windows 8. 8 seems faster, more responsive, but that could be because it's a new installation.
When I said earlier 7b is a hardware related error, it may also be a I/O control issue on your memory. We don't know where Windows is going wrong.
Can you try to see if there is an error report/ crash report from Event Viewer in Windows for DW? If so, can you post that here?
No error report I can find showing a DW error.
I have formatted a separate drive and installed a clean install of win 8 loaded CS6 and all seems good at the moment. As this drive is a small drive I will image it over to a larger drive now that it works.
I will not chase down the problem any further unless the image does not work on the drive that is currently the version that has a problem.
Thanks for the help
North America
Asia Pacific
