mmady16
Why can't my CS4 do video frames to layers?!
Dec 1, 2012 10:13 AM
Tags: #cs4 #video #to #layers #frames #animation #animated #gifs
The above explains my concerns. On CS5 and CS6, I've easily been able to make gifs, but now in my CS4 extended, there is no option under IMport to do video frames to layers. I also can not open ay gifs or get the animation toolbar. How do I fix this?!
    Dec 3, 2012 5:27 AM   in reply to mmady16
    I don’t have CS4 installed anymore to test this, but what makes you think »Video Frames to Layers« should work there?
    Are you sure it did at some point?
    Dec 3, 2012 8:54 AM   in reply to mmady16
    As C.Pfaffenbichler said - unless you are sure it actualyl did work at some point, I'd consider it somewhat of a premature conclusion that it should work in CS4 just because it works in the other versions. There's so many variables with video... Your description also sounds liek your CS4 isn't actually the Extended version, so this could easily explain the absence of the timeline...
    Mylenium
  • Noel Carboni
    Dec 23, 2006
    Dec 3, 2012 10:55 AM   in reply to mmady16
    The feature was in Photoshop CS4, but near as I can tell, it was only available in the 32 bit version.  Is it possible you're running the 64 bit version?
    64 bit:
    32 bit:
    -Noel
