Mountain Man1
PS Elements 11 Organizer - Importing a Pic New File?
Dec 3, 2012 5:59 AM
If I import a pic into PS Elements 11 Organizer, does it create a new pic file?  Thereby doubling the space on my hard drive for that pic?
  • 99jon
    Jan 6, 2010
    Dec 3, 2012 6:03 AM   in reply to Mountain Man1
    No it simply makes a link to your original on the hard drive. The thumbnails are simple previews.
    Dec 3, 2012 8:43 AM   in reply to Mountain Man1
    About backups :
    http://www.johnrellis.com/psedbtool/photoshop-elements-faq.htm#_Backin g_up_your
    It's important to backup your media files and your catalogs(s).
    You find the location of your catalogs in the help menu, system info.
    All your organization, tags, ratings, captions, albums, creations... are saved in the catalogs. So being able to restore your media is not enough.
    Another good safety measure is to 'write metadata to tags' so that your keywords are saved in the media files themselves.
  • 99jon
    Jan 6, 2010
    Dec 3, 2012 9:01 AM   in reply to Mountain Man1
    The path to the catalog (database) on Windows is normally:
    C:\ProgramData\Adobe\Elements Organizer\Catalogs\My Catalog\
    The catalofg file is named
    catalog.pse11db
    If you cant find program data then you may need to reveal hidden system files.
    http://windows.microsoft.com/en-GB/windows-vista/Show-hidden-files
  • 99jon
    Jan 6, 2010
    Dec 3, 2012 9:11 AM   in reply to Mountain Man1
    Yes. The file path for the Mac can be found under the help menu.
    Don’t overlook the system built into Organizer which works well with an external hard drive. It backs up the catalog and all the individual media files. It creates a reference file (TLY) from which everything can be restored onto a new machine in the event of a crash. By all means use your own backup system and make a copy of the database as suggested by Michel but that involves reconnecting all the file paths manually.
    Dec 3, 2012 9:14 AM   in reply to Mountain Man1
    The one time it's not true is when you import from iphoto. Then the organizer does make copies to avoid writing to the iphoto library, which can easily be corrupted by poking at it from outside iphoto itself.
    The file path for the catalog on a mac is your username>library>application support>adobe>catalogs. This library is hidden in lion. To see it, click the Go menu in the finder and hold down the option key. It will appear below the little house for your user account.
    Dec 3, 2012 9:17 AM   in reply to 99jon
    Good point, 99jon.
    If I may add...
    The catalog is not only the database catalog.pse11db, it's the whole folder containing it, with all accessory files and subfolders.
    If you have several catalogs (usually not recommended), you should include the \Catalogs\folder in your personal backups
    Even if you have a good personal backup scheme, keep in mind that the included backup/restore in the Organizer is the best way to 'migrate' both catalog and media to another drive, computer, OS or PSE version... may be useful some day!
