I have written just a simple test project that sends a request to a CFC, which queries my DB, and sends the results back my mxml page.
I'm using Eclipse (4.2.1 Juno), and the Flex 4.6 SDK. I have the CFEclipse plug in installed. I hvae installed the developer version of ColdFusion 10 server, and am working in an instance I created (so the URL is localhost:8501)
I wrote a build file:
<!-- compile application -->
<target name="compileApplication">
<echo>Compiling SWF To Deploy</echo>
<mxmlc file="${Src.dir}/main.mxml" actionscript-file-encoding="UTF-8"
output="${Deploy.dir}/main.swf" debug="false" keep-generated-actionscript="true" services="${services.path}" context-root=" ">
<load-config filename="${FLEX_HOME}/frameworks/flex-config.xml" />
<default-background-color>0xFFFFFF</default-background -color>
<compiler.source-path path-element="${FLEX_HOME}/frameworks" />
</mxmlc>
<echo>Compiled SWF To Deploy</echo>
</target>
The page loads, but then I get the following error: Channel.Security.Error error Error #2048 url: 'http://127.0.0.1:8501/flex2gateway'
Does anyone know what I'm missing? I've looked thru all sorts of sites about eding the config files and opening my firewall. I have compared my config files (messaging-config, remoting-config, and services-config) best I can to the exisitng ones that are working on the CF8 install we are replacing, and other than the new stuff in 10, I can't see any differences!
Help!
Jenn
North America
Asia Pacific
