I would like to generate the line chart with a dynamic updates from slider values..Kindly help me to do that..Thanks in advance
Your chart has only one line or multiple lines? If you can ellaborate little more or paste your sample code here, that would help to understand your problem precisely.
It mainly depends on your data, it's attributes to dynamically assign these attributes based on slider selection, at runtime.
My problem is to change the existing linechart values(i.e series1) to the current value shown in the slider.just i put one slider and one linechart component in my project.one more thing is slider value updated in my xml file.Initially the slider pointed the values which taken from my xml file.Hope you understand that what i conclude .Kindly help me to do that..Thanks in advance
Hopefully, this shall solve your purpose. This gets your line series dynamically:
<?xml version="1.0"?>
<!-- charts/BasicLineStroke.mxml -->
<s:Application
xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:mx="library://ns.adobe.com/flex/mx"
creationComplete="drawChart()"
height="100%" width="100%">
<fx:Script>
<![CDATA[
import mx.charts.series.LineSeries;
import mx.events.FlexEvent;
import mx.events.SliderEvent;
import mx.rpc.events.ResultEvent;
import spark.events.IndexChangeEvent;
protected function drawChart():void
// TODO Auto-generated method stub
var ls:LineSeries = new LineSeries();
ls.yField='@'+String(cb.selectedItem.@attributeName);
ls.displayName=String(cb.selectedItem.@desc);
var seriesArray:Array = []; // you can push all your line series here, if you have more than one also
seriesArray.push(ls);
myChart.series = seriesArray;
</fx:Script>
<fx:Declarations>
<fx:XML id="myXML" xmlns="">
<root>
<row month="Jan" seriesA="200" seriesB="545" seriesC="234"/>
<row month="Feb" seriesA="234" seriesB="123" seriesC="865"/>
<row month="Mar" seriesA="753" seriesB="456" seriesC="345"/>
<row month="Apr" seriesA="123" seriesB="322" seriesC="846"/>
</root>
</fx:XML>
</fx:Declarations>
<s:layout>
<s:VerticalLayout/>
</s:layout>
<s:Panel title="Line Chart" width="100%" height="100%">
<s:layout>
<s:VerticalLayout/>
</s:layout>
<s:ComboBox id="cb" change="drawChart()" selectedIndex="0" labelField="@desc">
<s:dataProvider>
<s:XMLListCollection>
<fx:XMLList xmlns="">
<row attributeName="seriesA" desc="Series A"/>
<row attributeName="seriesB" desc="Series B"/>
<row attributeName="seriesC" desc="Series C"/>
</fx:XMLList>
</s:XMLListCollection>
</s:dataProvider>
</s:ComboBox>
<mx:LineChart id="myChart"
dataProvider="{myXML.row}"
showDataTips="true" width="100%" height="100%">
<mx:horizontalAxis>
<mx:CategoryAxis categoryField="@month"/>
</mx:horizontalAxis>
</mx:LineChart>
<mx:Legend dataProvider="{myChart}"/>
</s:Panel>
</s:Application>
hi,
Thanks for your help..I have one more issue in the variable radius pie chart .The problem is that when we running my code the chart is in initial state (no changes in my chart) if once i switch to some other state and come back to my old page(i.e my chart page ),the corresponding values plotted and shows the correct value.Can you please take a quick look and reply.
<mx:Application
xmlns:mx="http://www.adobe.com/2006/mxml"
layout="absolute"
width="1116"
height="722"
xmlns:qc="qs.charts.*" xmlns:ns="source_lib.qs.charts.*" xmlns:local="*" xmlns:charts="charts.*" >
<mx:Script>
<![CDATA[
</mx:Script>
<mx:states>
<mx:State name="old">
<mx:RemoveChild target="{chart}"/>
<mx:RemoveChild target="{button1}"/>
<mx:AddChild relativeTo="{canvas1}" position="lastChild">
<!-- button for navigate old state(base state) -->
<mx:Button x="100" y="286" label="Old state" click="this.currentState =''"/>
</mx:AddChild>
<mx:Label x="194" y="320" text="This is new state, whenever we clicking on old state btn we can navigate to basestate but in size changes in piechart" fontSize="14" width="782"/>
</mx:AddChild>
</mx:State>
</mx:states>
<mx:XML id="assessment" source="Assessment.xml" />
<mx:Canvas width="1092" height="702">
<mx:Panel width="1029" height="644" id="panel1" x="45" y="16">
<mx:Canvas width="1016" height="595" id="canvas1">
<!-- piechart -->
<mx:PieChart id="chart" width="534" height="413"
dataProvider="{assessment.assessment_parameter}" visible="true" x="344" y="10">
<mx:series >
<qc:SizedPieSeries id="series_1" width="100%" height="100%" field="radius" radiusField="score"
nameField="paramname"
</qc:SizedPieSeries>
</mx:series>
</mx:PieChart>
<!-- button for navigate new state -->
<mx:Button x="94" y="254" label="NewState" id="button1" click="this.currentState ='old'" />
<!-- data grid -->
<mx:DataGrid dataProvider="{assessment.assessment_parameter}" id="datagrid1" x="42" y="36">
<mx:columns >
<mx:DataGridColumn headerText="Column 1" dataField="score"/>
<mx:DataGridColumn headerText="Column 2" dataField="radius"/>
</mx:columns>
</mx:DataGrid>
</mx:Canvas>
</mx:Panel>
</mx:Canvas>
</mx:Application>
Thanks in advance..
hi deepak,
I have a doubt on the barchart..I want to make a series with a current value from xml when ever change the slider value that makes a changes in current series..can u please help me to do that..I am new to design flex chart..Hope you have the experience ..Thanks in advance
Regards,
siva.
hi,
<ROOTS>
<ROOT>
<name>Assignment</name>
<TXTA>30</TXTA>
</ROOT>
<ROOT>
<name>Discussion</name>
<TXTA>20</TXTA>
</ROOT>
<ROOT>
<name>class</name>
<TXTA>10</TXTA>
</ROOT>
<ROOT>
<name>Co-study</name>
<TXTA>50</TXTA>
</ROOT>
<ROOT>
<name>Self-study</name>
<TXTA>60</TXTA>
</ROOT>
<ROOT>
<name>Exam</name>
<TXTA>25</TXTA>
</ROOT>
<ROOT>
<name>Journal</name>
<TXTA>30</TXTA>
</ROOT>
<ROOT>
<name>Lab</name>
<TXTA>60</TXTA>
</ROOT>
<ROOT>
<name>Paper</name>
<TXTA>80</TXTA>
</ROOT>
<ROOT>
<name>Patent</name>
<TXTA>60</TXTA>
</ROOT>
<ROOT>
<name>Presentation</name>
<TXTA>70</TXTA>
</ROOT>
<ROOT>
<name>Project</name>
<TXTA>50</TXTA>
</ROOT>
<ROOT>
<name>Report</name>
<TXTA>30</TXTA>
</ROOT>
<ROOT>
<name>Test</name>
<TXTA>40</TXTA>
</ROOT>
</ROOTS>
Here i attached my xml..
<mx:BarChart x="427" y="53" id="barchart1" type="stacked" height="122" dataProvider="{xml2}" >
<mx:verticalAxis>
<mx:CategoryAxis categoryField="name"/>
</mx:verticalAxis>
<mx:series>
<mx:BarSeries displayName="value1" xField="TXTA"/>
</mx:series>
</mx:BarChart>
<mx:Legend dataProvider="{barchart1}"/>
Try this. I hope this is what you wanted.
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" minWidth="955" minHeight="600"
width="100%" height="100%" layout="vertical" horizontalAlign="left" verticalAlign="middle"
creationComplete="application1_creationCompleteHandler(event)">
<mx:Script>
<![CDATA[
[Bindable]private var dataValues:Array = [];
protected function application1_creationCompleteHandler(event:FlexEvent):void
for each(var node:XML in xml.ROOT)
dataValues.push(String(node.TXTA));
dataValues.sort(Array.NUMERIC);
hSlider.values = dataValues;
hSlider.minimum = dataValues[0];
hSlider.maximum = dataValues[dataValues.length-1];
hSlider.labels = dataValues;
hSlider.snapInterval = 10;
hSlider.tickInterval = 10;
hSlider_changeHandler();
protected function hSlider_changeHandler():void
if(Number(node.TXTA) == hSlider.value)
sliderXML = new XML('<ROOTS>'+node.toXMLString()+'</ROOTS>');
break;
barchart2.dataProvider = sliderXML.ROOT;
</mx:Script>
<mx:HSlider id="hSlider" width="100%" change="hSlider_changeHandler()" />
<mx:HBox width="100%" height="100%">
<mx:VBox width="50%" height="100%">
<mx:BarChart id="barchart1" type="stacked" showDataTips="true" dataProvider="{xml.ROOT}" >
<mx:verticalAxis>
</mx:verticalAxis>
<mx:series>
<mx:BarSeries xField="TXTA" />
</mx:series>
</mx:BarChart>
</mx:VBox>
<mx:BarChart id="barchart2" type="stacked" showDataTips="true" >
<mx:verticalAxis>
</mx:verticalAxis>
<mx:series>
</mx:series>
</mx:BarChart>
</mx:VBox>
</mx:HBox>
<mx:XML id="sliderXML"/>
<mx:XML id="xml" xmlns="">
<ROOTS>
<ROOT>
<TXTA>10</TXTA>
</ROOT>
<ROOT>
<TXTA>20</TXTA>
</ROOT>
<ROOT>
<name>class</name>
<TXTA>30</TXTA>
</ROOT>
<ROOT>
<TXTA>40</TXTA>
</ROOT>
<ROOT>
<TXTA>50</TXTA>
</ROOT>
</ROOTS>
</mx:XML>
</mx:Application>
hi ,
thanks for your reply..ya it's working but i need changes happened in the same chart ..let as assume slider value 10,20,30,40 ..barchart contains one series that is study ..Initially the chart point out the value that is from xml for example that is 20..now i'm going drag my slider value from 20 to 30 on that time the bar series (i.e study) value will be changed .one more thing is when the slider value exceed the default value that shown in different color when it is below the default value it shows in some other color..try this challenge..i m also trying this .once you get idea about those stuffs reply .Thanks in advance..One more thing how to enable the multi browser support for flex application..how to design the application that suitable to all monitor size ?
Add fill function for your bar series for colour change:
private static const DEFAULT_VALUE:Number = 30;
private function barSeries_fillFunc(item:ChartItem, index:Number):IFill {
var currItem:BarSeriesItem = BarSeriesItem(item);
if(Number(currItem.item.TXTA) >= DEFAULT_VALUE)
return new SolidColor(0xFF0000, 1.0);//if TXTA value is 30 or more, show in RED
}else
return new SolidColor(0x00FF00, 1.0);// if TXTA value is less than 30, show in GREEN
<mx:verticalAxis>
</mx:verticalAxis>
<mx:series>
<mx:BarSeries xField="TXTA" fillFunction="barSeries_fillFunc" />
</mx:series>
</mx:BarChart>
Flex application depends on flash player, whichever browser has flash player, flex application works on it. This feature is what makes it browser independent.
For this you need to specify your containers' size in terms of percentage(width = "25%" height="80%")
thanks a lot..i have a one more doubt in slider code..consider this is my script
private function fnAddItem():void
var newXmlRow:XML=<ROOT1>
<TXTA1>{hval.value}</TXTA1>
</ROOT1>;
//xmlData=xmlData.appendChild(newXmlRow);
xml2=xml2.appendChild(newXmlRow);
barchart1.dataProvider=xml2.ROOT1;
<mx:XML id="xml2" source="root.xml"/>
slider-->
<mx:HSlider id="hval" x="121" y="393" minimum="10" maximum="60" tickInterval="10" change="fnAddItem()" />
root.xml-->
<ROOTS>
<ROOT1>
<TXTA1></TXTA1>
</ROOT1>
<ROOT>
<TXTA2></TXTA2>
</ROOT>
<ROOT>
<name>class</name>
<TXTA3></TXTA3>
</ROOT>
</ROOTS>
TXT values are empty now i want to update my slider value in <TXTA1>...i dont want to add more child for <TXTA1>tag..the values only updated and displayed dynamically can u pls help me to do that?Now the values are plotted in my barchart but dynalically series added..one by one i dont need that ..changes happening in single bar.
hi deepak,
thanks a lot for your help while i got struggled to develop ..i got a good examples from you..now i planned to create a project that is also related to chart components..the overview of this project is predicting the values that in future.I'll explain it clearly..consider the student and subject let us assume one subject here.(y-axis as a subject name and x-axis as a student marks)ok..
But the problem is ,
initially the color is filled by orange,when my slider got updated the color 'll change but my old one is merged with new color and generate some other color
My goal is to student can predict the future values from this project..if student got high marks from existing means that shows green..if they got low means shows red or some colors..
Is there any components available in flex for showing the differnce(prediction)
Hope you are understanding what i am trying to say.Help me to do that and suggest some components
Thanks in advance..
Saisiva
North America
Asia Pacific
