Broadcast live in rmtp and http in parallel
Dec 4, 2012 9:03 AM
Tags: #flash #server #ios #fms #4.5 #h264 #streaming #rtmp #stream #4.5.1 #live_streaming
Hello
i have a web internet live cams aplication and i am using adobe media server 5
most of my users using regular pc computer with common windows web browser
but around quarter of my users using web browser on mobile devices
so i need to broadcast from the same web cam at the same time in parallel
both to pc windows web browsers and mobile web browsers.
The important point is to pc windows web browsers i need to broadcast
using only rmtp (http live streaming is not Considerble...)
and to mobile web browsers using http live streaming
So the question is what is the best way to broadcast live from the same web cam
at the same time in parallel in those to methods?
is it possible in one net conection or i must open one for each?
is it to one livepkgr apliction or each method
is to different madia server aplication?
thanks
cheinan
    Dec 5, 2012 3:57 AM   in reply to cheinan
    See you can publish single stream to AMS and that same stream can be recorded in f4f format by livepkgr and can be avaliable for all RTMP live, HDS and HLS. The only problem in your case might come if you use case revolves around Flash Player publishing the web cam feed. FP allows only Nellymoser and Speex and right now AMS cannot transcode them and audio needs to be in AAC or MP3 format for http streaming. Can you confirm how do you plan to publish your live feed?
    Dec 5, 2012 11:19 PM   in reply to cheinan
    For RTMP MBR please read this document to understand how it works you can refer here: http://help.adobe.com/en_US/adobemediaserver/devguide/WS5b3ccc516d4fbf 351e63e3d11a0773d56e-7feaDev.2.3.html
    But i don't think you have to build your own player - if you have StrobeMediaPlayback player or any other OSMF based player - you should be able to play RTMP as well HDS using same player.
    Sep 23, 2013 9:18 AM   in reply to cheinan
    YES
    livestream for livestream
    livestream1 for livestream%i
    livestreamN for livestream%i
    N is the maximum number of streams you are sending. I think you have asked this in another thread.
