Am using PrE 10. Have a project with ~500 clips (son's hockey season). Lots of problems. First, it takes 10 minutes to launch the program as it 'loads' all the clips. Then when I try to edit, the audio will cut out randomly, the playback video will freeze or play in a jerky manner. Am using an iMac. Specs as follows on the computer and the video files: Mac OS X version 10.7.5. Intel processor 2.93 GHz. Memory - 4GB 1333 MHz DDR3. Have a 1TB hard drive with about 250GB free. All of the files are saved to the internal hard drive. Using a Canon T3i DSLR camera to take the video. All the video viles are .MOV format. The problem exists even when there are only a few clips in the timeline. There are many clips filed in the 'library', but even if I go to start a new movie and add only 5 clips, it won't play back properly. Have also started a completely new project and imported only 50 clips. Same problem. HELP!
DSLR is a highly compressed codec, which requires a "strong" computer to decode the compression for editing... an i7 is usually recommended
Also, only one hard drive causes a data flow bottleneck
Trying to use only ONE Hard Drive for Video Editing
You are a music conductor, with a baton that you use to point to various parts of the orchestra... this is like Windows pointing to various parts of the hard drive to do Windows housekeeping or to load program segments for various functions
Now, at the same time and with the same hand... while still using the baton to conduct the orchestra... pick up a bow and play a fiddle... this would be doing something with your video file at the same time as all the other work
You as a person cannot do both at the same time with the same hand
A computer is a LITTLE better, in that it can switch from one kind of task to another very quickly... but not quickly enough for EASY video editing
You need AT LEAST two hard drives (separate drives, never a partition http://forums.adobe.com/thread/650708 for more) with Windows (or Mac OS) and software on your boot drive, and video files on a 2nd drive so the boot drive is not slowed down by trying to do everything
North America
Asia Pacific
