I am creating an reference for a document and I need to set up tabs in the third character. This is how it looks
1 xxxxx fsffd sfssdfsa
25 csfwafs sfsfsaf sdfsd gs asfas
325 sdfsdfsd fsgv as gsad ags asfsad
This is how I need it to look
I need the numbers to line up on the third character and then the text to line up after the tab. I knw how to do the second part but I am having issues lining uo the numbers?
Any ideas are really appreciated.
- Dolph
This link may help :-
http://blogs.adobe.com/indesigndocs/2010/02/aligning_punctuation_in_bu llet.html
http://indesignsecrets.com/decimal-align-numbered-lists.php
also, you can add the first line indent tab from Type->Tabs and can work on the each number in the list manually, however this is not a good option is the list is too long.
This helps, the only issue occurs when the text is more than one line and it looks like this
1 gds bdfdfg dgsdsgds
325 dfsdfgsdfafsa safsafsa
sdfsf sdfasdf fsgsdgsd asgsdfg
25 fsdfgsdf fsafgaf af
so the second and following lines are indented with the number. Any solution for this? Pretty much it should look like this
Speaking of screenshots:
You need to make sure that your first tab is a right-align tab, and that your second tab is a left-align tab.
Do you see how the tab markers show their alignment direction by which way the "tail" points? Do you see the second tab on top of the indent-marker-triangle thing? That should get you what you want.
North America
Asia Pacific
