How to link audio layer of audio spectrum?
Dec 5, 2012 6:26 AM
I have a couple of audio spectrums and I was wandering if I could link the audio layers of all the audio spectrums so I didn't have to manually choose each audio layer when it's the same. Thanks!
    Dec 4, 2012 11:07 PM   in reply to Cosmic Poptart
    Nope. Since that particular control doesn't have a stopwatch, it can't be linked with expressions. Still, nothing stops you from having audio in a pre-comp, referencing that pre-comp in the effects and swapping the audio in the pre-comp when needed...
    Mylenium
    Dec 5, 2012 8:23 AM   in reply to Cosmic Poptart
    You can also prerender the alpha-channeled audio spectrum effect with the audio layer, resulting in a clip that you can use over and over again.
    Dec 5, 2012 6:57 PM   in reply to Cosmic Poptart
    Select all of your audio clips and press Command + Shift + C to pre-comp your audio clips together.  Then go back to your main composition and change whatever you'd like on the pre-comp.  Think of this as your master mix controller as it will effect all of the audio clips inside the pre-comp at once.
