biggupp
Probable CSS Issue
Dec 5, 2012 3:50 AM
Tags: #css_properties
http://ahy4life.com/press.php
http://ahy4life.com/resources.php
Can't quite fathom in the css what is causing the lists– bulleted & non-bulleted– to appear white.
How can I fix this?
    Dec 5, 2012 4:02 AM   in reply to biggupp
    div a {
        color: #FFFFFF;
    Give the <ul> of your bulleted lists a class and style on that:
    <ul class="myclass">
    ul.myclass li a {
    color: #01559B;
    On the the other page, you haven't used an unordered list.  If it were me, I think I would but if you don't you would need a different way to style the non-list listed items.
    div#watermark p a {
    color: #01559B;
    Might do it.
    Martin
  • Sudarshan Thiagarajan
    Oct 15, 2010
    Dec 5, 2012 8:36 AM   in reply to biggupp
    Lines 568-574 in your press.php page:
    <style type="text/css">
    div a{
    color:#FFFFFF;
    </style>
    This makes any a tags (hyperlink markup) to appear in white. Remove this.
    You also have another place where you've defined for hyperlinks to show in white.
    Lines 548-554 - same code, repeated:
    div a{
    color:#FFFFFF;
    </style>
    If you remove both these bits of code, your hyperlinks (now showing in white) will show in black as defined in styleSheet.css file, line 41:
    a {
        color: #000;
        text-decoration:none;
    Resources page, same thing, Lines 414-420 as well as 434-440:
    div a{
    color:#FFFFFF;
    </style>
    -ST
