umamaheswararao4
why i am unable to select between 2 anchor points with in a object while dragging with direct select
Dec 5, 2012 10:30 AM
why i am unable to select between 2 anchor points with in a object while dragging with direct selection tool instead it moves
    Dec 5, 2012 10:48 AM   in reply to umamaheswararao4
    In Preferences > Selection check "Select object by path only"
    Dec 5, 2012 8:56 PM   in reply to umamaheswararao4
    Another option is to temporarily change your view to outline mode, when your done switch back to preview mode. Ctrl-Y or View>Outline {View>Preview} The menu option will change depending on which mode you are in.
    And another option, double click on the object in question to place it in Isolation mode. You can now edit to your hearts content. When done, click on the gray border at top of document.
    So as you can see there are multiple ways of accomplishing the same thing.
