I have a contact form with the usual fields required (name, address, city, etc.). I'm adding a Country pull-down list to the form, which will default to the US being selected. Since a "State" field is not relevant for anyone filling out the form from another country, I'd like to make the State field required only if the country selected is United States, and not required for any other country. Is there a way to do this?
R-Co
JavaScript.
<select name="country" id="country">
<option value="Algeria">Algeria</option>
<option value="US" selected>US</option>
<option value="Zimbabwe">Zimbabwe</option><!--- Yes, I do not know what is last, alphabetically.. or first.. just for placement --->
</select>
function validateData(){
/* typical validation stuff */
if(document.getElementById("country").value == "US"){ // If country is US
if(document.getElementById("state").selectedIndex == 0){ // If a state is not selected - assumes first option is <option value="">State</option> or similar
// throw alert, or whatever to indicate state is needed
^_^
What you need is to be able to create a required textfield when the first textfield shows USA and destroy the required field when another country is selected.
The following may help to understand create and destroy
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<title>Deleting and rebuilding validations</title>
<link href="http://labs.adobe.com/technologies/spry/widgets/textfieldvalidation/Sp ryValidationTextField.css" rel="stylesheet">
</head>
<body>
<form id="form1" method="post" action="#">
<p>
<input type="radio" name="radio" id="Married" value="Married" onclick="val(this);">
<label for="Married">Married</label>
</p>
<p>
<input type="radio" name="radio" id="Defacto" value="Defacto" onclick="val(this);">
<label for="Defacto">Defacto</label>
</p>
<p>
<input type="radio" name="radio" id="Single" value="Single" onclick="val(this);">
<label for="radio">Single</label>
</p>
<hr>
<span id="sprytextfield1">
<label for="f_married">Married</label>
<input name="married" id="f_married" type="text" value="">
<span class="textfieldRequiredMsg">A value is required.</span>
</span>
<span id="sprytextfield2">
<label for="f_defacto">Defacto</label>
<input name="defacto" id="f_defacto" type="text" value="">
</span>
<span id="sprytextfield3">
<label for="f_single">Single</label>
<input name="single" id="f_single" type="text" value="">
</span>
<hr>
<input type="submit" value="Submit" />
</form>
<script src="http://labs.adobe.com/technologies/spry/includes_minified/SpryValidati onTextField.js"></script>
<script>
var sprytextfield1,
sprytextfield2,
sprytextfield3;
// build validations and delete / destroy them
function val(e){
// get the value
value = e.value;
// see what radion button we have
if(value == "Married"){
// if there inst a validaton build one
if(!sprytextfield1){
sprytextfield1 = new Spry.Widget.ValidationTextField("sprytextfield1");
// if there is a validaiton in sprytextfield destory it, and clear the variable
if(sprytextfield2 && sprytextfield2.destroy){
sprytextfield2.resetClasses();
sprytextfield2.destroy();
sprytextfield2 = null;
// same as the rest
if(sprytextfield3 && sprytextfield3.destroy){
sprytextfield3.resetClasses();
sprytextfield3.destroy();
sprytextfield3 = null;
} else if(value == 'Defacto'){
if(!sprytextfield2){
sprytextfield2 = new Spry.Widget.ValidationTextField("sprytextfield2");
if(sprytextfield1 && sprytextfield1.destroy){
sprytextfield1.resetClasses();
sprytextfield1.destroy();
sprytextfield1 = null;
} else if(value == 'Single'){
if(!sprytextfield3){
sprytextfield3 = new Spry.Widget.ValidationTextField("sprytextfield3");
// proceed with the rest as normal
return true;
</script>
</body>
</html>
Okay, so I'm trying to figure out how to customize your code to work with my form. Here are my two fields:
<p>
<label for="state">STATE</label>
<span id="spryselect2">
<select name="state" id="state">
<option value='' selected="selected">---Choose One---</option>
<option value="Alabama">Alabama</option>
<option value="moreStates">etc. etc.</option>
<option value="Wyoming">Wyoming</option>
</select>
<span class="selectRequiredMsg">Please select a state if you live in the US</span></span>
</p>
<p><span id="spryselect1">
<label for="country">COUNTRY <span class="asterisk">*</span></label>
<option value='' selected='selected'>Select Country</option>
<option value='United States'>United States</option>
<option value='Afghanistan'>Afghanistan</option>
<option value='moreCountries'>etc. etc.</option>
<option value='Zimbabwe'>Zimbabwe</option>
</select>
<span class="selectRequiredMsg">Country is required</span></span>
</p>
I want to tell the form "if the Country selected is United States, require that a State be selected."
and
"If the Country selected is other than United States, destroy the requirement for the State field."
So, I take it I need to refer to those by their span ID (spryselect1 and spryselect2), but I'm still not sure how to modify your code to fit.
Thanks for the help.
R-Co
I think it is better to swap the country and state around, have the state hidden until the value of country is United States. You can then un-hide states and create the validation. When the value of country changes away from United States, destroy the validation and hide the select.
I do not have a ready made solution to show you, but there is plenty of assistance on line; just Google the subject
North America
Asia Pacific
