I'm trying to set up a keyboard shortcut in Illustrator using the "control" key and I get the error message "The key pressed cannot be used as a shortcut." I really want to use the control key because, 1) it matches a similar shortcut that I use in Photoshop, and 2) all similar shortcuts are already in use. I'm confused as to why Illustrator won't allow me to use the ctl key in shortcuts, yet in Photoshop it works fine. I'm using CS6 with OSX Mountain Lion.
Any suggestions or explanations are much appreciated.
The Control Key in Illustrator cannot be used on the Mac as a keyboard shortcut.
The reason is that the Adobe team or at least the old Adobe team is convince that it will interfere with the shortcuts provided by the system.
Even though it is pointed out that those shortcuts cn be disabled.
Unless things have changed you can argue till you are blue in the face but you will not get the Team to reconsider inplementing the use of the control key in Illustrator for keyboard shortcuts.
Try it you'll see what I mean Iargued this when AI 9 was out. Igot respnses from Adobe but all I got for the responses were arguments
I just love it when a good idea is passed over because "that's the way we've always done it." :-/ Time for some new thinking in that "team" then.
Turning off system keyboard shortcuts is ESSENTIAL with MANY applications (especially in the 3D world), and so it should not be a problem for Ai either.
But oh well.
North America
Asia Pacific
