y88cdw
CS6 on W8, black screen on nvidia drivers 310.70 (gtx 690)
Dec 6, 2012 12:18 AM
Have to roll back to 306 to get screen back!
    Dec 6, 2012 1:10 AM   in reply to y88cdw
    Not here. No problems with 310.70 on Win8 and with CS6.03
    Dec 6, 2012 8:11 AM   in reply to y88cdw
    Same here, no issues with 310.70 on Win 8 and PP 6.0.3.  (560 Ti)
    Dec 12, 2012 8:07 PM   in reply to Jim Simon
    This is also happening to me when I use driver 310.70 and set it to SLI. I have two 680's. Premeire works fine when SLI is not enabled. But enabled is shows the black video preview screen of the timeline. Any fix
    Dec 12, 2012 9:11 PM   in reply to Geekdll
    PPro does not work with SLI
    Dual Card SLI http://forums.adobe.com/thread/872941
    -problem http://forums.adobe.com/thread/872103
    Dec 13, 2012 1:39 PM   in reply to Geekdll
    Any fix
    Yes.  Do not edit on your gaming rig.  Do not game on your edit rig.
    Dec 13, 2012 2:43 PM   in reply to Harm Millaard
    Still on 280.26 myself...the only one that doesn't wreak havoc on my win 7 system.  My advice is to stick with what works.
    Jan 4, 2013 2:54 PM   in reply to y88cdw
    FYI we (NVIDIA) have a bug filed on this issue (SLI being on my default) are working on a fix for GTX 690 SLI with Premiere Pro.
    Jan 10, 2013 7:08 PM   in reply to y88cdw
    We haven't been able to reproduce this bug after having multiple people try on multiple systems.
    If you would like us to continue to work on it, we'll need to get some additional information from you. If you send me a note to gestes at nvidia dot com I will connect you to the right people at NVIDIA.
    Greg
    Jan 20, 2013 9:03 AM   in reply to Greg_Estes
    I was able to get MPE (Premiere 6.0.3) running perfectly with my GTX 690 (310.90 driver) by going into the:
    • NVIDIA control panel
    • Manage 3D setting
    • Find Premiere in the "program settings" tab
    • Change "CUDA" to either of the GPUs (not both)
    • Change "Multi-GPU Rendering" to single GPU
    • Change "Multi-Display/Mixed GPU acceleration" to single display performance
    • Save changes and hope for the best!
    Hope that helps!
    (Edit: the reason that 680s won't work in SLI is because Premiere won't/can't use two GPUs - After Effects will, so hopefully Adobe will update this soon)
    -Keith
    Jan 20, 2013 9:45 AM   in reply to WhiteoutMedia
    Tell Adobe what you want here https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Feb 19, 2013 11:00 AM   in reply to y88cdw
    New 314.07 drivers seem to have fixed the problem for me, everything works just like before 310.70. That is unless I didn't notice some Premiere update.
    Unfortunately the fix suggested here didn't work for me, I guess it was because I'm running multi-monitor setup and only way I got Premiere working again was to use Software rendering or switching back to 306.97 drivers.
    According to NVIDIA program settings Premiere is using "All" CUDA-GPUs now and GPU usage hops up and down synchronously in PrecisionX, so perhaps there is some truth in it.
