numbering properties
Dec 6, 2012 4:33 AM
Tags: #page_numbers
[FM 10 on Windows 7]
Starting from a .book file, I …
  1. select all but the first chapter, right click and select Numbering
  2. select the Page tab, select Continue from previous page
  3. click Set
So far so good, except that nothing useful happens in terms of page numbers that run from the start of the book to the end: each chapter steadfastly and persistently starts page numbering at 1. I don't remember having this much trouble with earlier versions, and it's frustrating!
Thanks in advance for help and tips
N
    Dec 6, 2012 5:33 AM   in reply to Niels Grundtvig Nielsen
    Update the book, N.
    Van
    Dec 6, 2012 5:57 AM   in reply to Niels Grundtvig Nielsen
    > Starting from a .book file ...
    I recommend setting the numbering properties from within each open component file, then setting the book menu clones to "Read from File".
    See: Why does my numbering keep resetting to roman numerals??
    And I concur that you may see no changes until Update Book.
    Dec 6, 2012 10:29 AM   in reply to Error7103
    For what it is worth, I have never had a problem setting the numbering from the book file. I find it easier than setting each file within the file.
    Van
    Dec 6, 2012 11:06 AM   in reply to Reviewer1066
    It only causes us a problem when FM (7.1/Unix) crashes, which, alas, it does, a lot.
    And because unexplained crashes seem to still be an undocumented feature, even in FM11, the risk of book/file numbering de-sync might still lurk.
    But for anyone who is not experiencing frequent crashes, setting props from Book might be just fine.
    Dec 6, 2012 11:31 AM   in reply to Error7103
    @Error,
    I always recommend setting the numbering at the book level as sometimes files can be common to multiple books and their position within a book would be different in each book. The book settings always trump the file settings anyway and you have easier control over the book's collection of files that way. If I have to rearrange files in a book.
    @Niels,
    In FM10 and later, one can turn off FM's error/warning notifications, so in some cases when the book has to silently open files to perform the updates, you won't see the errors/warnings (like missing fonts or inconsistent properties) that can stop FM from automatically completing the renumbering of a book.
    Also, when changing the setting for a single file in a book, the status line in the book pane doesn't automatically update until you come back to the file (i.e. select another file and the re-select the file that you just updated). This might be what you're seeing and I think it's a "buglet".
