cl0ne^
Flash gallery site - two gallery malfunction?
Dec 6, 2012 10:46 AM
Tags: #cs5 #flash #xml #actionscript #photography #gallery
Hello all!
Just wanted to run this by some flash pros out there. I have a flash photograph gallery but two of the galleries for some reason are not "functioning".
Please go to http://photography.khangp.com
When it opens, you will see "Portrait" and "Product" on top along with other galleries. But these two are the only ones that are not working.
In a local environment, they are functioning as they should but not on the web. I have no idea what is causing this.  I thought maybe it had something to do with the XML file but I've gone over it a dozen times and everything checks out! Again, the same gallery functions fully in a local environment but I don't know what is up with these two in particular.
I would appreciate it if someone can shed some light on this.  By the way, I know almost nothing about flash and this was simply a template that I bought.
Thanks!
  • kglad
    Jul 21, 2002
    Dec 6, 2012 11:37 AM   in reply to cl0ne^
    your first error is:
    TypeError: Error #1010: A term is undefined and has no properties.
        at com.flashgallerynet::MP3Player/playlistLoaderCompleteHandler()
        at flash.events::EventDispatcher/dispatchEventFunction()
        at flash.events::EventDispatcher/dispatchEvent()
        at flash.net::URLLoader/onComplete()
    the first problem with your portrait gallery is there is no:
    http://photography.khangp.com/bin/data/images/portrait/children/thumb/ 01.jpg
    the first problem with your product gallery is there is no:
    http://photography.khangp.com/bin/data/images/product/jewelry/thumb/01 .jpg
    p.s. case counts onliine.  ie,
    http://photography.khangp.com/bin/data/images/product/jewelry/thumb/01 .jpg is not the same as http://photography.khangp.com/bin/data/images/product/jewelry/thumb/01 .JPG
  • kglad
    Jul 21, 2002
    Dec 6, 2012 8:54 PM   in reply to cl0ne^
    you need to fix all the errors but the first line will only be seen by users that have the debug flash player version.
    the file extension problems where the cause of the gallery problems you noticed and that everyone else would notice.
  • kglad
    Jul 21, 2002
    Dec 6, 2012 9:07 PM   in reply to cl0ne^
    to debug actionscript errors, click file>publish settings>swf and tick "permit debugging".  retest.
    the problematic line number will be in the error message.  if you still don't understand the problem after doing that, copy and paste the first line of code mentioned in the error message.
