silverback7
Outlined logo needs to have an inner stroke - Resize
Dec 6, 2012 12:36 PM
Ok, I have checked everywhere and have done this many times over the past 25 years plus (but not enough obviously since I forgot)...I need to resize an object; let's just say it's a logo. I want to resize the logo inside of itself to create a double line as shown and it needs to proportionally resize itself without me having to fix either the horizontal and vertical on the object. By holding the Shift+Alt then dragging does not scale it proportionally within itself. I've check my Preferences and they seem to be ok...I am using CS5.5. What is it again that I need to check in order to make this happen? Thanks.
    Dec 6, 2012 12:48 PM   in reply to silverback7
    silverback,
    Do you mean Object>Path>Offset Path with a negative value (which is a constant distance, rather than proportional, change)?
    Dec 6, 2012 2:32 PM   in reply to silverback7
    You are welcome, silverback.
    I like the Alt/Option key combinations, because I am silly enough to feel they make sense enough to be remembered, so I use Alt/Option+O+P+O in this case.
    Your version may have an additional option.
    In any case, you can create custom key combinations.
    Dec 6, 2012 5:40 PM   in reply to silverback7
    If you build it as an Appearance stack, you won't have to remember it. You can store it as a Graphic Style and apply it anytime you want to live text.
    JET
    Dec 7, 2012 6:39 AM   in reply to silverback7
    For my part you are welcome, silverback.
