Oregoner
Content scrolling over fixed content: What am I doing wrong?
Dec 6, 2012 4:09 PM
Doing this for my friend for free while learning Dreamweaver.
My fixed elements refuse to stay on top of my scrolling elements. I have asked nicely.
I tried the z-index:100;
I could use a hint or 2.
I also can't get my page to center. Might thses troubles be related?
I'd appreciate it if you would have a look: http://h2o-test.businesscatalyst.com/Brenda_test.htm
No hair left to pull. I have tried the z-index to no avail.
Oregoner
    Dec 6, 2012 5:09 PM   in reply to Oregoner
    Ditch the absolute positioning.  It removes content from the normal document flow.
    View source in browser to see the code in this example:
    http://alt-web.com/TEMPLATES/FixedLayout.shtml
    Nancy O.
  • Sudarshan Thiagarajan
    Oct 15, 2010
    Dec 6, 2012 7:57 PM   in reply to Oregoner
    Lot of things don't look right on that page.
    1. You've defined your Div Classes & IDs with background-image instead of actually just defining them as a placeholder, then adding the image within it with <img src..>. This is bad practice!
    2. Lot of the divs are 'fixed' in position - make them relative to their parent containers - this way you can control them from 1 main div (to aid positioning)
    3. Every element has a top and left spacing defined - this means you have to change these values for each and every div to get the content aligned properly -  time consuming
    4. Even though you've defined lot of classes & IDs in your markup, you still have inline styling in some of them - for example <h1> still has a font-color and font-size attribute
    5. Overall, the code is malformed
    Fix all of the things I've mentioned and run your site through http://validator.w3.org/ to check for errors and fix them too.
    Do post back if you're puzzled about how you can fix the pointers I've given!
    -ST
    Dec 7, 2012 4:16 AM   in reply to Oregoner
    I had a look at the validation as Sudershan quite rightly suggested, but do not believe that they contribute to your problem.
    Nancy's suggestion certainly does make a difference.
    Have a look at the markup for the problem lines
    <div class="container"><h1 class="h2o_title"><font style="font-size: 72px;" color="#08087f">H2O Visions Bonaire</font> </h1><br>
    <h2 class="h2">Guided Snorkel &amp; Photo Tours</h2></div>
    <!--div Style="position: fixed; top: 200px; left: 70px;"-->
    </div>
    <div class="h2o_navbar"></div>
    and the corresponding style rules
    h2 {
        font-family:Verdana, Geneva, sans-serif;
        font-size:36px;
        color: #08087f;
        text-shadow: 0px 0px 30px #FFFFFF;
        line-height: 1.1;
        position: fixed;
        top: 100px;
        left: 70px;
    .h2o_title    {
        font-family:Tahoma, Geneva, sans-serif;
        font-weight:bold;
        text-shadow: 2px 2px 20px #FFFFFF;
        position: fixed;
        top: 20px;
        left: 70px;
    .h2o_navbar {
        width: 960px;
        height: 60px;
        background-image:url(images/Yellow_Navbar.jpg);
       position: fixed;
        top: 200px;
        left: 70px;
        -moz-border-radius: 10px;
        -webkit-border-radius: 10px;
        -khtml-border-radius: 10px;
        border-radius:10px;
    I suggest that you remove the highlighted style rules and position the elements using widths, floats and/or margins
    Oct 15, 2010
    Dec 7, 2012 11:42 AM   in reply to Oregoner
    Oregoner.
    I knew this was coming!
    It's pretty simple. Add a class selector to your <img..> tag itself and define it in CSS:
    CSS:
    .round{
    border-radius: 20px;
    -webkit-border-radius: 20px;
    HTML:
    <div class="topr_image">
    <img class="round" src="images/TopR_fish.png">
    </div>
    Remove the background-image definition from the topr_image class.
    -ST
