how in a canvas HTML5 I can add more than one image,... is any stack order
Dec 6, 2012 11:53 PM
Tags: #html5-canvas
how in a canvas HTML5 I can add more than one image,... is any stack order?
    Dec 7, 2012 3:12 AM   in reply to lsepolis123
    There's no z-index type stacking order for <canvas> and images are drawn accordeing to the code execution order. However you can use globalCompositeOperation to draw a shape underneath the existing elements:
    context.globalCompositeOperation = "destination-over"; // draw underneath
    Kenneth Kawamoto
    http://www.materiaprima.co.uk/
    Dec 7, 2012 7:24 AM   in reply to lsepolis123
    how many images overlap and seem all or part of them, can have in canvas?
    I don't think there's a limit for the number of elements you can darw in a <canvas> but I suppose your browser will eventually start complaining that your script is running slow and wants to abort it
    canvas or an image can saved in localStorage html5?
    You can generate an image data from <canvas> using toDataURL() method.
    Kenneth Kawamoto
    Dec 7, 2012 9:17 AM   in reply to lsepolis123
    Here I am converting the <canvas> to an image data, storing to the local storage, then displaying that in the same canvas:
    var canvas = document.getElementById("canvas");
    var context = canvas.getContext("2d");
    var canvasData = canvas.toDataURL();
    window.localStorage.canvasImage = canvasData;
    var img = new Image();
    img.src = window.localStorage.canvasImage;
    img.onload = function () {
         context.drawImage(img, 200, 0);
    Kenneth Kawamoto
    Dec 7, 2012 9:50 AM   in reply to lsepolis123
    You cannot set window.location to a data, you can only set it to an URL.
    Kenneth Kawamoto
    Dec 7, 2012 2:43 PM   in reply to lsepolis123
    this i want is appear a save as image dialog .... how do it?
    The short answer is: no, you can't do it. The long answer is: it's possible but it's not very straightforward and there's no cross-browser solution. These posts should get you started:
    http://hackworthy.blogspot.co.uk/2012/05/savedownload-data-generated-i n.html
    http://www.html5rocks.com/en/tutorials/file/filesystem/
    Re. globalCompositeOperation have a look at this page:
    https://developer.mozilla.org/en-US/docs/Canvas_tutorial/Compositing
    Kenneth Kawamoto
    Dec 8, 2012 6:38 AM   in reply to lsepolis123
    Shapes and texts are drawn instantaneously but images are drawn only after the data is loaded. Therefore even your code to draw shapes comes after your background image code, by the time the image is ready to be drawn your shapes are already on canvas so that the image will go on top.
    Call your shape drawing functions on image.onload.
    Kenneth Kawamoto
    Dec 8, 2012 8:24 AM   in reply to lsepolis123
    Not sure if I get your question but here's a simple example - it displays the background image and then draw a circle on top:
    var background = new Image();
    background.src = "image.jpg";
    background.onload = function() {
                context.drawImage(this, 0, 0);
                context.beginPath();
                context.arc(40, 40, 20, 0, Math.PI*2, true);
                context.fill();
    Kenneth Kawamoto
    Dec 8, 2012 9:47 AM   in reply to lsepolis123
    btw above you used:
    this is the same as:
    window.localStorage.getItem("canvasImage");
    or
    window.localStorage["canvasImage"];
    Yes those 3 are the same, I just used the shortest
    Kenneth Kawamoto
