PlacoLL
Me crea una copia al abrir un fichero de idesign
Dec 7, 2012 3:47 AM
Hola a todos,
Tengo instalado mountain lion con cs5.5, el problema que tengo es cuando abro un fichero de indesign me crea una copia de este en la misma ubicación, ¿ que puede estar pasando?
Gracias
    Dec 7, 2012 4:30 AM   in reply to PlacoLL
    You're really giving my Spanish a workout.
    Were these files created in CS5.5? Did you recently update to a new patch for InDesign? Are the files stored on your hard drive or a network? Do you see a regular Save dialog, or the Save AS dialog?
    Dec 7, 2012 4:36 AM   in reply to Peter Spier
    And perhaps I misread what you were saying. Does the second file appear as soon as you open the original file? Is the name exactly the same? Does it have the same file extension?
    Dec 7, 2012 5:14 AM   in reply to PlacoLL
    I don't think I've ever seen a report like this before. Do you have any non-Adobe plugins installed or do you use some sort of content management system?
    Dec 7, 2012 5:15 AM   in reply to Peter Spier
    It could also be a setting in Mountain Lion itself.
    Dec 7, 2012 7:29 AM   in reply to PlacoLL
    I do actually think this is a setting in the OS system prefs that needs changing, but I'm a windows user...
    We've had som posts about other annoyances, files reopening automatically, I think, that has to do with a preference setting that remembers what was open when you quit.
    Dec 7, 2012 9:08 AM   in reply to PlacoLL
    If it is what I think it is then you need to uncheck this box
