CS6 Audio corrupted on M2TS H264/MPEG2 + AC3 TS Streams Encoding
Dec 7, 2012 7:53 AM
Tags: #error #audio #export #digital #cs6 #dolby #m2ts
Hello,
while encoding in Blu Ray H264 or MPEG2 with Dolby Digital (in this case 224 Kbits) for a multiplexed TS Stream the audio seems to be corrupted. Strangely plays in Windows Media Player but stutters in VLC Player and after re-import in CS6 (6.0.3) there is no audio hearable although listed in the properties of the file.
The Export Settings are almost the standard ones, except for setting to AC3 224 Kbits and TS output.
anyone having the same problems?
    Dec 7, 2012 9:56 AM   in reply to pinklemos
    For a single file output, try using the normal H.264 presets instead of the H.264 Blu-ray.
    Dec 7, 2012 4:08 PM   in reply to pinklemos
    Authoring normally uses two files, separate audio and video.  So for authoring, don't multiplex.
    Dec 8, 2012 12:54 PM   in reply to pinklemos
    some customers need multiplexed files for their workflow.
    Check that.  Authoring as standard industry practice uses separate files.  It's more likely they just want one file, in which case you might convince them of the better way (which as it happens, does work)
    Dec 9, 2012 9:52 AM   in reply to pinklemos
    It does not solve the problem, that the Encoder Export is not working.
    Granted, but I'm not an Adobe programmer, so I can't really help with that.  All I can do is suggest other means to get the job done and the paycheck in.
