Geolaf
Dec 7, 2012 8:41 AM
I supported Pshop for Adobe when 4 came out (1997) and STILL I have to delete the automatic insertion of 'copy' into the filename when I save a layered .psd as a .jpg. There is NO reason for this piece of code anymore. As I understand it, there was some weird concern that, since layers were new, people wouldn't realize that saving as a .jpg wouldn't preserve them and they would also have to save the .psd as well - which you are warned about anyway on close.
Can ANYONE tell me why this piece of code is still there? Can ANYONE concoct a reason I have had to delete 'copy' on save as .jpg for FIFTEEN years now? Just for my sanity - make something up that sounds good. PLEASE!
    Dec 7, 2012 8:46 AM   in reply to Geolaf
    This has be a topic of numerous threads.  Here is a long one that covers most bases.  http://forums.adobe.com/message/4189806#4189806
  • Noel Carboni
    Dec 23, 2006
    Dec 7, 2012 8:52 AM   in reply to Geolaf
    I haven't seen "copy" added to a filename in a very long time, and I do do a lot of File - Save As - JPEG operations.  I'm with you - constantly having to delete that would drive me nuts.
    I honestly can't say what I've done to avert it, though.  I'll be interested to see what it works out to be.
    I'm on Windows 7 by the way.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Dec 7, 2012 9:00 AM   in reply to Geolaf
    Mac or PC, Geolaf?
    -Noel
    Dec 7, 2012 9:01 AM   in reply to Geolaf
    I also do not see a copy added.  Win 7 also.  I have done nothing to modify default settings.
    Just made a layered PSD and saved it as a jpeg.  I noticed when I clicked save as the box that came up had a check mark next to copy.  When I changed the save as box to jpeg the copy box was grayed out.
    Dec 7, 2012 9:21 AM   in reply to Geolaf
    I don't get that when saving a psd as a jpg. It just saves with same file name but with the jpg extension. No "copy" is added.
    Dec 7, 2012 9:24 AM   in reply to Geolaf
    Geolaf,
    Here is a tip that might get you a new version of PS, if you act quick.  Right now you can upgade to CS6 for the upgrade price (in US $200).  After Dec 31 that offer goes over the fiscal cliff and you have to pay full version price (US$700).  Be aware however it really needs 64 bit OS and 8 gig or ram with a good video card.
    CS3 Bridge has a trouble ridden version.
    Dec 7, 2012 9:46 AM   in reply to Geolaf
    There is a purpose for Save As Copy.
    Saving as a copy keeps the original file open in photoshop.
    If you were to flatten your jpeg before saving you shouldn't get the copy added to the file name.
    Dec 7, 2012 10:07 AM   in reply to Geolaf
    Shift + Ctrl+ S which is "Save as" will not add "copy" to the file name and if the name and location is not changed by the user after a warning, will replace the file on disk and thus the currently open file.
    Ctrl + Alt + S which is "Save a copy" will add "copy" to the file name and will save another file on disk leaving the original file and thus the open file unchanged.
    Dec 7, 2012 10:04 AM   in reply to Geolaf
    Geolaf wrote:
    Also - it happens with no other save as format - even all the other ones that get rid of the layers, etc. Maybe it was a legal deal with jpg?
    It is the same for any format
    Dec 7, 2012 10:12 AM   in reply to Geolaf
    read my post #10 and realize how you "save as"
    Dec 7, 2012 10:14 AM   in reply to Geolaf
    I believe the behavior was changed starting with cs5 so layered files don't get the copy added to the name when saving jpegs.
    Dec 7, 2012 10:30 AM   in reply to Geolaf
    In cs3 it's not a problem when saving layered files to jpegs (except for the added copy), but if you flatten the layered psd file before saving or open a psd with only the background layer and then save to jpeg, when
    you use File>Revert, the file reverts to the saved jpeg instead of the original psd.
    Dec 7, 2012 10:42 AM   in reply to Geolaf
    Oh, sorry I was answering to your first messages where it appears that you were talking about the latest versions. I missed CS3 mentioned later in the thread.
    Dec 7, 2012 11:14 AM   in reply to Geolaf
    Geolaf wrote:
    Sorry - been using shift+control S forever - doesn't offer the option to NOT save as a cop
    I really don't think my workflow is at all unusual. I would just like it to save the jpeg as a flattened jpg (since all jpgs ARE flat) and leave the psd open - just as it does - and prompt me to save the psd as it does. But I would be happy if there WAS a keycombo that made that happen.
    Nevertheless - I guess this is the definitive 'thinking' behind the code - even though it doesn't offer a choice (which is where I think the flaw is - since the only thing that happens to the workflow is that I have to remove - or leave - copy in the filename.)
    It's not as if it's preventing anything. They could have put in a dialog that says: "Saving in another format with layers will leave the author file in psd format and save a copy so that you can maintain your layers." with a checkbox that says: Don't show me this again.
    May be good ideas, but I can assure you that they are not going to make any code changes for CS3 and your problem doesn't exist in the latest versions.
