wflex
Error decompressing - now AME and Premiere freeze during import
Dec 7, 2012 1:36 PM
Tags: #mp4 #codec_not_installed #codec_missing_or_unavailable #mpeg-ps
The person who gave me this footage compressed it from an AVI. I'm not very good with codecs and what not, so I hope y'all can point me in the right direction.
Playback is fine, just no import. Other MP4s play and import fine.
Running CS6 and just purchased QuickTime Pro 7 in hopes it would help, but no luck. With the long list of InstalledCodecs (report below), I'm hesitant to disable any because as I said I'm not sure which are what. I would love to just re-install this entire damn OS and Suite and hope for the best - but I really just want to work with this clip already.
InstalledCodec report: http://www.secularuh.org/hosted/report.html
GSpot:
http://secularuh.org/hosted/gspot.png
MediaInfo:
Complete name                            : C:UserstlowDocumentsEnvoyMPV2012_12RAWEnvoy Nov 2012_PGM_0001.mp4
Format                                   : MPEG-PS
File size                                : 19.1 GiB
Duration                                 : 26mn 26s
Overall bit rate mode                    : Variable
Overall bit rate                         : 104 Mbps
Video
Format                                   : MPEG Video
Format version                           : Version 2
Format profile                           : Main@High
Format settings, BVOP                    : No
Format settings, Matrix                  : Default
Format settings, GOP                     : N=1
Duration                                 : 26mn 26s
Bit rate mode                            : Variable
Bit rate                                 : 100.0 Mbps
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 29.970 fps
Standard                                 : NTSC
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Interlaced
Scan order                               : Top Field First
Compression mode                         : Lossy
Bits/(Pixel*Frame)                       : 1.609
Stream size                              : 18.6 GiB (97%)
Audio #1
Format                                   : MPEG Audio
Format version                           : Version 1
Format profile                           : Layer 2
Duration                                 : 26mn 26s
Bit rate mode                            : Constant
Bit rate                                 : 384 Kbps
Channel(s)                               : 2 channels
Sampling rate                            : 48.0 KHz
Stream size                              : 72.6 MiB (0%)
Audio #2
Format                                   : MPEG Audio
Duration                                 : 26mn 26s
Bit rate                                 : 384 Kbps
    Dec 7, 2012 2:46 PM   in reply to wflex
    Your problem MAY be the variable bit rate mode... there have been other messages about problems with trying to edit anything other than a constant bit rate file
    Dec 7, 2012 3:57 PM   in reply to wflex
    just no import.
    What exactly happens when you try?
    Dec 7, 2012 5:49 PM   in reply to wflex
    Weird.
    Can you get the original AVI file instead?
    Dec 8, 2012 12:46 PM   in reply to wflex
    I use this for problem file conversion.  (Get 5, not the 6 beta.)
    http://www.videohelp.com/tools/XviD4PSP
    Dec 12, 2012 1:59 PM   in reply to wflex
    You're welcome.
