Mrs. Dalloway
bleeding text box
Dec 7, 2012 5:55 PM
Tags: #text #box
How do I make a text book with edges that bleed into the background?
    Dec 8, 2012 6:51 AM   in reply to Mrs. Dalloway
    You can try this until you are pleased with the result.
    1. Open the image.
    2. Select text tool and create the text.
    3. Simply the text layer .Choose "Layer Menu>Simplify layer".
    4. Go to "Window Menu>Layers" and try different blending modes until you get teh result you want.  Some of the blending modes like "Overlay" can give you good results.
    Dec 8, 2012 6:59 AM   in reply to Mrs. Dalloway
    Or, after step 3 in 27Prac's instructions:
    4. Make sure the text layer is the active layer, use one of the marquee tools to make a selection, add a largish feather, select>Inverse, Delete.
    There are several ways to do this, but it depends on what you want to do.
    Note that once you simplify the text, it's just a bunch of pixels and you can't edit it anymore, or resize it more than you can any other pixel image.
    Dec 8, 2012 8:54 AM   in reply to Barbara B.
    Depending on what you want, here is another suggestion:
    http://www.pixentral.com/show.php?picture=1RCfmt27SeSAqQOC4aScVCeppXCA v1
    • Open picture file
    • Open Effects palette. In the drop down, go to Frame, then select "Text Panel". Apply
    • Under Layer styles, go to Visibility>Ghosted. Apply
    • Access the type tool and type the text.
    • Position text and text panel with move tool
    Dec 8, 2012 9:57 AM   in reply to hatstead
    That's a very good suggestion, hatstead. That way the text remains editable text.
    Dec 8, 2012 12:25 PM   in reply to Barbara B.
    Thanks, Barbara.
    Dec 8, 2012 1:42 PM   in reply to Mrs. Dalloway
    I don't see anything that says picture file, or text panel
    Picture file means an image. We were assuming you wanted to add this to a photo. Text panel means the text box, the layer with the text on it.
    To edit a layer style after you've applied, go over to that layer in the layers panel and you will see a little script "fx" there. Double click it to bring up the style settings and you can change many things about the style.
