elmop2005
drag and drop to target simple errors, expecting identifier?
Dec 8, 2012 6:07 AM
Tags: #and #drop #cs5 #action_script_3 #drag #target
im creating a drag and drop. moving a guitarest name to a target e.g draging a movieclip called slash to a dynamic text box called box_slash this is my code and i get 2 stupid errors but have been up all night and cant figure it out!
flash cs5 actionscript 3, is this code for actionscript3 i found the base for it here: http://edutechwiki.unige.ch/en/Flash_drag_and_drop_tutorial any help would be incredible as it for an assignment and im new to flash
var hits = 0;
// Register mouse event functions
slash.addEventListener(MouseEvent.MOUSE_DOWN, mouseDownHandler);
slash.addEventListener(MouseEvent.MOUSE_UP, mouseUpHandler);
clapton.addEventListener(MouseEvent.MOUSE_DOWN, mouseDownHandler);
clapton.addEventListener(MouseEvent.MOUSE_UP, mouseUpHandler);
hendrix.addEventListener(MouseEvent.MOUSE_DOWN, mouseDownHandler);
hendix.addEventListener(MouseEvent.MOUSE_UP, mouseUpHandler);
// Define a mouse down handler (user is dragging)
function mouseDownHandler(evt:MouseEvent):void {
          var object = evt.target;
          // we should limit dragging to the area inside the canvas
          object.startDrag();
function mouseUpHandler(evt:MouseEvent):void {
          var obj = evt.target;
          // obj.dropTarget will give us the reference to the shape of
          // the object over which we dropped the circle.
          var target = obj.dropTarget;
          // If the target object exists the we ask the test_match function
          // to compare moved obj and target where it was dropped.
          if (target != null)
                    test_match(target, obj);
          obj.stopDrag();
function test_match(target,obj) {
          // test if either one of the four pairs match
          if ( (target == box_slash && obj == slash) ||
             (target == box_clapton && obj == clapton) ||
               (target == box_hendrix && obj == hendrix) || )
                    // we got a hit
                    hits = hits+1;
                    textField.text = "Correct! :)";
                    // make the object transparent
                    obj.alpha = 0.5;
                    // kill its event listeners - object can't be moved anymore
                    obj.removeEventListener(MouseEvent.MOUSE_DOWN, mouseDownHandler);
                    obj.removeEventListener(MouseEvent.MOUSE_UP, mouseUpHandler);
                    // Test if we are done
                    if (hits == 3)
                              textField.text = "Well Done";
          else
                    textField.text = "wrong! :(";
the errors are: i have highlighted the lines
Scene 1, Layer 'Actions', Frame 1, Line 391084: Syntax error: expecting rightparen before leftbrace.
Scene 1, Layer 'Actions', Frame 1, Line 381084: Syntax error: expecting identifier before rightparen.
  • kglad
    Jul 21, 2002
    Dec 8, 2012 6:16 AM   in reply to elmop2005
    has a syntax error.  that should be:
        (target == box_hendrix && obj == hendrix)  )
  • kglad
    Jul 21, 2002
    Dec 8, 2012 6:32 AM   in reply to elmop2005
    that's not the best choice for a flash variable but, if you had a textfield named textField in the scope of your code when that code executed, you would not see an error message.
    so, change the name to something else (eg, feedback_tf) and make sure that variable name matches your code and the instance name in the properties panel.
  • kglad
    Jul 21, 2002
    Dec 8, 2012 7:00 AM   in reply to elmop2005
    copy and paste your edited code and attach a screen shot that shows your selected on-stage textfield and the properties panel.
  • kglad
    Jul 21, 2002
    Dec 8, 2012 7:09 AM   in reply to elmop2005
    sprites and movieclips can be dragged/dropped, not simple buttons.
    either use a movieclip button (so you can use startDrag with it) or use an enterframe loop that causes your simple button to follow the mouse (which will look like a startDrag).
  • kglad
    Jul 21, 2002
    Dec 8, 2012 7:32 AM   in reply to elmop2005
    no text should be in entered in a on-stage textfield unless you use static text.  ie, the only text in dynamic and input textfields should be added using actionscript.
  • kglad
    Jul 21, 2002
    Dec 8, 2012 9:02 AM   in reply to elmop2005
    on your last main timeline frame attach:
    gotoAndStop(1);
