How do I do a starburst with Illustrator
Dec 8, 2012 7:30 AM
Hi
I have to recreate a "starburst" for a graphic and am not sure how to do it and where to start.
Attached is an image of the type of starbrust I am trying to recreate.
Any suggestions?  Or Illustrator "brush"?   Using Illustrator CS5 for the PC.
    Dec 8, 2012 12:02 PM   in reply to rowby
    Some bold people would take Illustrator's indispensable Flare tool.
    Dec 8, 2012 3:03 PM   in reply to rowby
    You make a straight vertical path and use the wifth to taper it and you use the transform Effect to rotate it you copy and apste a couple of times and use the transform effect to rotate each of the copied art
    But before you do that once you have the stroke of the original path adjusted with the width tool then you apply a gradient to the stroke so it goes from white 100% to White 0%
    Gice it a inner glow and perhaps a slight blur depending on what you think looks good.
    the center you have to make a circle with a blur and a solid white to a transparent white radial gradient fill.
    Adjust the transparency of each copy of the transformed stroke
    Draw a cicle beyond the edges of the burst and fill it with a radial gradient, select the three paths for the burst and gradient filled circle and make it a clipping path
    Dec 8, 2012 3:05 PM   in reply to Wade_Zimmerman
    To can put a blue stroke around the center circle with some transparency for the look of the one you posted.
    Dec 9, 2012 9:05 PM   in reply to rowby
    You're welcome! If you need help I or someone else will chime in.
    Dec 10, 2012 6:59 AM   in reply to rowby
    Gradient stroke is only for cs6. Expand strokes and apply gradation instead.
    And 'object->compound path->make' expanded strokes so you don't apply gradation on every stroke(try it without making compound path for better understanding).
    Dec 10, 2012 7:19 AM   in reply to rowby
    Effects>Stylize>Outer Glow
    Effects>Stylize>Feather
    Effects>Blur>Gausian Blur
    Explore the Effects Menu and the appearance panel to add fills and to vary the adjustments.
    Maybe I will do a video later.
    Dec 10, 2012 7:53 AM   in reply to rowby
    I guess I gave it an inner nd outer glow
    Dec 10, 2012 9:08 AM   in reply to Wade_Zimmerman
    Here is a video with the use of a gasian blur instead of a inner or outer glow
    http://www.wadezimmerman.com/videos/Starburst.mov
